6595 Discussions
libcoreDlaRuntimePlugin.so: cannot open share object file
STATEABC
When I run build_demos.sh in open_model_zoo, some executable files are generated. However, when running an executable file, such as object_detection_demo, some errors occur:
Cannot load library 'libcoreDlaRuntimePlugin.so:libcoreDlaRuntimePlugin.so: cannot open share object file: No such file or directory
Any help would be greatly appreciated, thank you
Aznie_Intel
Hi Stateabc,
Did you run the executable file demo in OpenVINO environment and what is your OpenVINO version?
Aznie
STATEABC
Yes I activated the openvino environment, my openvino version is 2022.3.
ABC
Aznie_Intel
Hi Stateabc,
The error is because the library cannot be found. This can happen when there is a conflict between OpenVINO and OpenCV libraries. I would recommend you to permanently set the environment variables as follow:
vi <user_home_directory>/.bashrc
source <INSTALL_DIR>/setupvars.sh
You may refer to Get Ready for Running the Demo Applications on Linux*
Aznie
STATEABC
I don't know why my reply is always invalid
Aznie_Intel
Hi Stateabc,
Does my recommendation work for you? Do you still need help with this?
Aznie
Aznie_Intel
Hi Stateabc,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
