6605 Discussions
make Errors W/ ncappzoo/tensorflow/facenet/
Trial Environment:
1 NCS device
1 linux camera
NCSDK1.12
root@ubuntu:~/workspace/ncsdk/ncappzoo/tensorflow/facenet# ls
20170512-110547.zip get_zipped_facenet_model.sh Makefile README.md validated_images
convert_facenet.py inception_resnet_v1.py neal_2017-12-19-155037.jpg run.py valid.jpg
root@ubuntu:~/workspace/ncsdk/ncappzoo/tensorflow/facenet# make all
making pictures
wget -c --no-cache -P . https://raw.githubusercontent.com/nealvis/media/master/face_pics/licenses.txt; wget -c --no-cache -P . https://raw.githubusercontent.com/nealvis/media/master/face_pics/elvis-presley-401920_640.jpg; wget -c --no-cache -P . https://raw.githubusercontent.com/nealvis/media/master/face_pics/trump.jpg; wget -c --no-cache -P . https://raw.githubusercontent.com/nealvis/media/master/face_pics/president-67550_640.jpg;
--2018-06-14 19:25:55-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/licenses.txt
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.0.133, 151.101.64.133, 151.101.128.133, …
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.0.133|:443… connected.
HTTP request sent, awaiting response… 416 Range Not Satisfiable
The file is already fully retrieved; nothing to do.
--2018-06-14 19:25:56-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/elvis-presley-401920_640.jpg
--2018-06-14 19:25:57-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/trump.jpg
--2018-06-14 19:25:58-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/president-67550_640.jpg
making prereqs
inception_resnet_v1.py exists, not regetting it.
making zipped model
Zipped model already exists, skipping download
making model
Zip file exists.
Unzipping.
Archive: 20170512-110547.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of 20170512-110547.zip or
20170512-110547.zip.zip, and cannot find 20170512-110547.zip.ZIP, period.
/bin/sh: 12: cd: can't cd to 20170512-110547
mv: cannot stat 'model-20170512-110547.ckpt-250000.data-00000-of-00001': No such file or directory
mv: cannot stat 'model-20170512-110547.ckpt-250000.index': No such file or directory
mv: cannot stat 'model-20170512-110547.meta': No such file or directory
Converted directory does not exist, doing conversion
python3: can't open file '../convert_facenet.py': [Errno 2] No such file or directory
making compile
/bin/sh: 7: cd: can't cd to 20170512-110547/facenet_celeb_ncs
Command line: mvNCCompile facenet_celeb_ncs.meta -w facenet_celeb_ncs -s 12 -in input -on output -o facenet_celeb_ncs.graph
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:766: DeprecationWarning: builtin type EagerTensor has no module attribute
EagerTensor = c_api.TFE_Py_InitEagerTensor(_EagerTensorBase)
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 213, in parse_tensor
saver = tf.train.import_meta_graph(path, clear_devices=True)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1803, in import_meta_graph
meta_graph_def = meta_graph.read_meta_graph_file(meta_graph_or_file)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/meta_graph.py", line 555, in read_meta_graph_file
raise IOError("File %s does not exist." % filename)
OSError: File facenet_celeb_ncs.meta does not exist.
cp: cannot stat 'facenet_celeb_ncs.graph': No such file or directory
@ideallyworld Seems like the system is having issues unzipping one of the compressed files. I can see that the file is there in your log, but maybe it could be corrupted. Can you try doing a make clean and then a make all again?
@Tome_at_Intel Thanks,I try the make cleanand make all again. It's still the same error result.
convert_facenet.py get_zipped_facenet_model.sh Makefile neal_2017-12-19-155037.jpg README.md run.py validated_images valid.jpg
root@ubuntu:~/workspace/ncsdk/ncappzoo/tensorflow/facenet# make clean
making clean
rm -f facenet_celeb_ncs.graph
rm -f licenses.txt
rm -rf 20170512-110547
rm -f 20170512-110547.zip
rm -f inception_resnet_v1.py
making pictures
--2018-06-17 00:19:46-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/licenses.txt
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.52.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.52.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 452 [text/plain]
Saving to: ‘./licenses.txt’
licenses.txt 100%[===============================================================>] 452 --.-KB/s in 0s
2018-06-17 00:19:48 (53.8 MB/s) - ‘./licenses.txt’ saved [452/452]
2018-06-17 00:19:49 (128 KB/s) - ‘./elvis-presley-401920_640.jpg’ saved [55773/55773]
--2018-06-17 00:19:49-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/trump.jpg
Length: 18375 (18K) [image/jpeg]
Saving to: ‘./trump.jpg’
trump.jpg 100%[===============================================================>] 17.94K 82.0KB/s in 0.2s
2018-06-17 00:19:51 (82.0 KB/s) - ‘./trump.jpg’ saved [18375/18375]
--2018-06-17 00:19:51-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/president-67550_640.jpg
Length: 82670 (81K) [image/jpeg]
Saving to: ‘./president-67550_640.jpg’
president-67550_640.jpg 100%[===============================================================>] 80.73K 153KB/s in 0.5s
2018-06-17 00:19:52 (153 KB/s) - ‘./president-67550_640.jpg’ saved [82670/82670]
making prereqs
--2018-06-17 00:19:52-- https://raw.githubusercontent.com/davidsandberg/facenet/361c501c8b45183b9f4ad0171a9b1b20b2690d9f/src/models/inception_resnet_v1.py
Length: 11772 (11K) [text/plain]
Saving to: ‘./inception_resnet_v1.py’
inception_resnet_v1.py 100%[===============================================================>] 11.50K --.-KB/s in 0.02s
2018-06-17 00:19:53 (540 KB/s) - ‘./inception_resnet_v1.py’ saved [11772/11772]
making zipped model
Attempting to download 20170512-110547.zip from this url:
https://drive.google.com/file/d/0B5MzpY9kBtDVZ2RpVDYwWmxoSUk
--2018-06-17 00:19:55-- https://docs.google.com/uc?export=download&confirm=1eTC&id=0B5MzpY9kBtDVZ2RpVDYwWmxoSUk
Resolving docs.google.com (docs.google.com)… 172.217.5.110, 2607:f8b0:4005:808::200e
Connecting to docs.google.com (docs.google.com)|172.217.5.110|:443… connected.
Length: unspecified [text/html]
Saving to: ‘20170512-110547.zip’
20170512-110547.zip [ ] 3.40K --.-KB/s in 0.01s
2018-06-17 00:19:56 (281 KB/s) - ‘20170512-110547.zip’ saved [3481]
making model
Zip file exists.
Unzipping.
making compile
@ideallyworld Looks like you're having issues downloading the facenet file. If the facenet model zip file became corrupted or the download was interrupted, but the incomplete zip file still saved, subsequent attempts will not replace the file if the corrupted zip file exists. You can try deleting the 20170512.110547.zip file and try running the make run command again.
Alternatively, you can try manually downloading the file from https://drive.google.com/file/d/0B5MzpY9kBtDVZ2RpVDYwWmxoSUk, placing the zip file in the facenet directory and trying make run again. Let me know if this works for you. Thanks.
@Tom_at_Intel The first comment( try deleting the 20170512.110547.zip file and try ) result is as follow, It gets another error. I check it but don't understand why could get that error.
root@ubuntu:~/workspace/ncsdk/ncappzoo/tensorflow/facenet# rm -rf 20170512-110547.zip
root@ubuntu:~/workspace/ncsdk/ncappzoo/tensorflow/facenet# make run
making prereqs
making zipped model
--2018-06-18 23:40:43-- https://docs.google.com/uc?export=download&confirm=HNTO&id=0B5MzpY9kBtDVZ2RpVDYwWmxoSUk
Resolving docs.google.com (docs.google.com)… 172.217.0.46, 2607:f8b0:4005:802::200e
Connecting to docs.google.com (docs.google.com)|172.217.0.46|:443… connected.
HTTP request sent, awaiting response… 302 Moved Temporarily
Location: https://doc-0c-7k-docs.googleusercontent.com/docs/securesc/ha0ro937gcuc7l7deffksulhg5h7mbp1/v475u6s2vp67qutdc098vfqhjdkohvgm/1529388000000/18056234690049221457/_/0B5MzpY9kBtDVZ2RpVDYwWmxoSUk?e=download [following]
Warning: wildcards not supported in HTTP.
--2018-06-18 23:40:44-- https://doc-0c-7k-docs.googleusercontent.com/docs/securesc/ha0ro937gcuc7l7deffksulhg5h7mbp1/v475u6s2vp67qutdc098vfqhjdkohvgm/1529388000000/18056234690049221457/_/0B5MzpY9kBtDVZ2RpVDYwWmxoSUk?e=download
Resolving doc-0c-7k-docs.googleusercontent.com (doc-0c-7k-docs.googleusercontent.com)… 172.217.0.33, 2607:f8b0:4005:802::2001
Connecting to doc-0c-7k-docs.googleusercontent.com (doc-0c-7k-docs.googleusercontent.com)|172.217.0.33|:443… connected.
Length: unspecified [application/zip]
20170512-110547.zip [ ] 183.08M 358KB/s in 9m 32s
2018-06-18 23:50:18 (327 KB/s) - ‘20170512-110547.zip’ saved [191972345]
making model
Zip file exists.
Unzipping.
inflating: 20170512-110547/20170512-110547.pb
inflating: 20170512-110547/model-20170512-110547.ckpt-250000.data-00000-of-00001
inflating: 20170512-110547/model-20170512-110547.ckpt-250000.index
inflating: 20170512-110547/model-20170512-110547.meta
model base file name is: facenet_celeb
2018-06-18 23:50:35.312668: I tensorflow/core/platform/cpu_feature_guard.cc:137] Your CPU supports instructions that this TensorFlow binary was not compiled to use: SSE4.1 SSE4.2 AVX AVX2 FMA
Restoring facenet_celeb
making compile
Layer InceptionResnetV1/Repeat/block35_1/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat/block35_2/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat/block35_3/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat/block35_4/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat/block35_5/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Mixed_6a/Branch_0/Conv2d_1a_3x3/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_1/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_2/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_3/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_4/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_5/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_6/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_7/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_8/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_9/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_1/block17_10/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Mixed_7a/Branch_0/Conv2d_1a_3x3/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Mixed_7a/Branch_1/Conv2d_1a_3x3/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Mixed_7a/Branch_2/Conv2d_1a_3x3/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_2/block8_1/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_2/block8_2/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_2/block8_3/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_2/block8_4/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Repeat_2/block8_5/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
Layer InceptionResnetV1/Block8/Branch_0/Conv2d_1x1/Relu forced to im2col_v2, because its output is used in concat
making run
python3 ./run.py
File "./run.py", line 239, in
sys.exit(main())
NameError: name 'sys' is not defined
Makefile:144: recipe for target 'run' failed
make: *** [run] Error 1
20170512-110547 elvis-presley-401920_640.jpg inception_resnet_v1.py neal_2017-12-19-155037.jpg README.md validated_images
20170512-110547.zip facenet_celeb_ncs.graph licenses.txt president-67550_640.jpg run.py valid.jpg
@Tom_at_Intel Thanks. The first comment( try deleting the 20170512.110547.zip file and try ) result is OK and I got a GUI window that shows the test images and match/not match status. But when I double-check and retry the trial make clean and make run . I got follow error result.
making run
python3 ./run.py
File "./run.py", line 240, in
sys.exit(main())
File "./run.py", line 209, in main
device.OpenDevice()
File "/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py", line 147, in OpenDevice
raise Exception(Status(status))
Exception: mvncStatus.ERROR
@ideallyworld Make sure that only one app is using the device at a time. You can encounter an error if you try to open the device while another app is using the device.
@Tom_at_Intel Got it,Thanks. It works OK and I get the right result.
