make install error
Hi experts
When I ran make install I got the following error(below. Any hints?
Fetched 107 kB in 2s (53.0 kB/s)
Reading package lists…
W: file:///var/cuda-repo-8-0-local/Release.gpg: Signature by key 889BEE522DA690103C4B085ED88C3D385C37D3BE uses weak digest algorithm (SHA1)
W: Invalid 'Date' entry in Release file /var/lib/apt/lists/_var_cuda-repo-8-0-local_Release
W: Invalid 'Date' entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
E: Failed to fetch http://dk.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 2001:878:346::116 80]
E: Failed to fetch http://dk.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 2001:878:346::116 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1560:8001::11 80]
E: Failed to fetch http://dk.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 2001:878:346::116 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Installation failed: Command 'sudo apt-get update' return code=100. Error on line 308 in ./install-utilities.sh. Will exit
Makefile:47: recipe for target 'install' failed
make: *** [install] Error 131
@sojohan The NCSDK installation script runs the command sudo apt-get update during the install process. It looks like you have some broken packages on your system that are causing this step to fail. I suggest googling the 404 error for the files above and seeing if any of the solutions work for you.
Hi Tome_at_Intel
I did already. Before I did make Install.
Also I does NCSDK install Cuda?
sojohan
@sojohan The NCSDK doesn't install CUDA. You can check the install script and the requirements.txt and requirements-apt.txt files to see the packages the NCSDK installs. In any case, it seems like you might have some out-dated package sources on your machine.
Hi Tome_at_Intel
I got it work now…..
Next step is Make Examples
Thanks, sojohan
