Cython >= 0.23 not found; falling back to pre-built _hoghistogram.c
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-hjm9ug4p/scikit-image/
Installation failed: Command ' pip3 install --trusted-host files.pythonhosted.org Cython graphviz scikit-image' return code=1. Error on line 308 in ./install-utilities.sh. Will exit
Makefile:47: recipe for target 'install' failed
Manually installing cython before rerun install seems fix.
- Tags:
- Raspberry Pi
Hi and thank you, I am having the same problem, how did you installed cython manually? with apt-get or pip?
Thank you very much, this fixed it:
sudo apt-get install cython3
@saveriop @fgerard Thanks for reporting this. If anyone else is trying to install on Raspberry Pi, please use fgerard and saveriop's solution by installing cython3 before the NCSDK installation.
Thanks for posting this! I had the same issue and now it's fixed :)
Collecting scikit-image
Exception:
Traceback (most recent call last):
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
six.raise_from(e, None)
File "", line 2, in raise_from
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 387, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
response.begin()
File "/usr/lib/python3.5/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 353, in run
wb.build(autobuilding=True)
File "/usr/lib/python3/dist-packages/pip/wheel.py", line 749, in build
self.requirement_set.prepare_files(self.finder)
File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file
require_hashes
File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages
page = self._get_page(location)
File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File "/usr/lib/python3/dist-packages/pip/index.py", line 792, in get_page
"Cache-Control": "max-age=600",
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
return self.request('GET', url, **kwargs)
File "/usr/lib/python3/dist-packages/pip/download.py", line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
timeout=timeout
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
Installation failed: Command 'sudo -H -E pip3 install --trusted-host files.pythonhosted.org Cython graphviz scikit-image' return code=2. Error on line 308 in ./install-utilities.sh. Will exit
make: *** [install] Error 131
i tried using fgerard's solution fixex but not successful
@star50037 Hi Star, is this on a fresh RPi? Can you try installing the dependencies independently (graphviz, scikit-image, Cython) and then try installing the NCSDK again and see if that fixes the issue?
I successfully installed Cython and graphviz but cannot install scikit-image
I use command _pip install scikit-image_
Should I install other dependencies?
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 215, in main
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 353, in run
File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 749, in build
File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 380, in prepare_files
File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 620, in _prepare_file
session=self.session, hashes=hashes)
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 821, in unpack_url
hashes=hashes
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 659, in unpack_http_url
hashes)
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 853, in _download_http_url
stream=True,
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 386, in request
timeout=timeout
total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'~~~~~~~~
@star50037 Try installing matplotlib first using pip --no-cache-dir install matplotlib and then try pip install -U scikit-image. Let me know if that works.
