model optimizer converting tensorflow slim fine-tuned inception v3
cfu__cfu
I fine tuned the tensorflow slim inception v3 image classification model by running the script
https://github.com/tensorflow/models/blob/master/research/slim/scripts/finetune_inception_v3_on_flowers.sh
Then, I try to freeze the graph by running
python3 /tensorflow/tensorflow/python/tools/freeze_graph.py --input_graph=/tmp/flowers-models/inception_v3/graph.pbtxt  --input_checkpoint=/tmp/flowers-models/inception_v3/model.ckpt-1000 --input_binary=false --output_graph=/tmp/frozen_inception_v3.pb --output_node_names=InceptionV3/Predictions/Reshape_1
and got the ifle
Then I try to convert the model by running
python3 mo_tf.py --input_model /tmp/frozen_inception_v3.pb -b 1 --mean_value [127.5,127.5,127.5] --scale 127.5
and got the error:
Model Optimizer arguments:
Common parameters:
    - Path to the Input Model:     /data/train/frozen_inception_v3.pb
    - Path for generated IR:     /opt/intel/openvino_2019.1.094/deployment_tools/model_optimizer/.
    - IR output name:     frozen_inception_v3
    - Log level:     ERROR
    - Batch:     1
    - Input layers:     Not specified, inherited from the model
    - Output layers:     Not specified, inherited from the model
    - Input shapes:     Not specified, inherited from the model
    - Mean values:     [127.5,127.5,127.5]
    - Scale values:     Not specified
    - Scale factor:     127.5
    - Precision of IR:     FP32
    - Enable fusing:     True
    - Enable grouped convolutions fusing:     True
    - Move mean values to preprocess section:     False
    - Reverse input channels:     False
TensorFlow specific parameters:
    - Input model in text protobuf format:     False
    - Path to model dump for TensorBoard:     None
    - List of shared libraries with TensorFlow custom layers implementation:     None
    - Update the configuration file with input/output node names:     None
    - Use configuration file used to generate the model with Object Detection API:     None
    - Operations to offload:     None
    - Patterns to offload:     None
    - Use the config file:     None
Model Optimizer version:     2019.1.0-341-gc9b66a2
WARNING: Logging before flag parsing goes to stderr.
E0414 10:12:34.278545 140149041551104 main.py:317] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.input_cut.InputCut'>): Graph contains 0 node after executing <class 'extensions.front.input_cut.InputCut'>. It considered as error because resulting IR will be empty which is not usual
any suggestion?
SuryaPSC_Intel
Hi cfu,
As your model is a Tensorflow*- Slim Image classification model.
Please follow the steps at Converting TensorFlow*-Slim Image Classification Model.
Surya
cfu__cfu
Hi Chauhan,
I could convert the pre-trained slim image classification model without any issue.
However, after I fine-tune and freeze the model, I am not able to convert it to IR.
SuryaPSC_Intel
Hi cfu,
Did you generate the inference graph for inception v3 using the following command(for inception v1) given in the documentation.
python3 tf_models/research/slim/export_inference_graph.py \
    --model_name inception_v1 \
    --output_file inception_v1_inference_graph.pb
Did you try passing the ckpt file to the model optimizer as given in the documentation?
<MODEL_OPTIMIZER_INSTALL_DIR>/mo_tf.py --input_model ./inception_v1_inference_graph.pb --input_checkpoint ./inception_v1.ckpt -b 1 --mean_value [127.5,127.5,127.5] --scale 127.5
Also, please share the output you get on passing the model to summarize_graph.py
Surya
cfu__cfu
Hi Chauhan,
Thanks for the reply, instead of fine-tune inception v3, I try to start with inception v1 first.
I follow the script https://github.com/tensorflow/models/blob/master/research/slim/scripts/finetune_inception_v1_on_flowers.sh
to fine-tune a pre-retrained model, you can find the files under folder fine-tune through below link:
https://drive.google.com/drive/folders/1zFJwYAZSj-aII4wbDqpoQq8_L0ynV6m0?usp=sharing ;
Then, I freeze the model by running
python3 tensorflow/python/tools/freeze_graph.py --input_graph graph.pbtxt --input_checkpoint model.ckpt-3000 --output_graph /tmp/inception_v1_freeze.pb --output_node_names InceptionV1/Logits/Predictions/Softmax
Then, I try to convert the freezed model to IR by running
python3 mo_tf.py --input_model /tmp/inception_v1_freeze.pb -b 1 --mean_value [127.5,127.5,127.5] --scale 127.5
but got the error, the tensorflow version is 1.15.2
Common parameters:
	- Path to the Input Model: 	/tmp/inception_v1_freeze.pb
	- Path for generated IR: 	/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/.
	- IR output name: 	inception_v1_freeze
	- Log level: 	ERROR
	- Batch: 	1
Model Optimizer version: 	2020.2.0-60-g0bc66e26ff
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.output_cut.OutputCut'>): Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual
SuryaPSC_Intel
Hi cfu,
Can you please attached the ckpt file also in the above mentioned drive link. So, that we may replicate at our end.
Surya
cfu__cfu
Hi Chauhan,
I have attached the ckpt file inception_v1.ckpt
SuryaPSC_Intel
Hi cfu,
Please use the following command to generate IR.
sudo python3 mo.py --input_model /home/surya/Downloads/inception_v1_inference_graph.pb --input_checkpoint /home/surya/Downloads/inception_v1.ckpt -b 1 --mean_value [127.5,127.5,127.5] --scale 127.5
Common parameters:
	- Path to the Input Model: 	/home/surya/Downloads/inception_v1_inference_graph.pb
	- IR output name: 	inception_v1_inference_graph
	- Log level: 	ERROR
	- Batch: 	1
[ SUCCESS ] Generated IR version 10 model.
[ SUCCESS ] XML file: /opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/./inception_v1_inference_graph.xml
[ SUCCESS ] BIN file: /opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/./inception_v1_inference_graph.bin
[ SUCCESS ] Total execution time: 13.22 seconds.
[ SUCCESS ] Memory consumed: 491 MB.
cfu__cfu
Hi Chauhan,
I can produce the IR model with inception_v1.ckpt. However, I am not able to convert the fine-tune model to IR.
SuryaPSC_Intel
Hi cfu,
Can you please confirm you are generating the inference graph for inception v3 using:
    --model_name inception_v3 \
    --output_file inception_v3_inference_graph.pb
Please share the output on passing the inference_graph to summarize_graph.py and model optimizer.
Surya
