model optimizer error
Vedansh_Surjan
I got the followinf error while converting a caffe model into IR format..Not sure what the error is for.
Can anyone please let me know how to rectify this
JAIVIN_J_Intel
Hi Vedansh,
Could you please provide information about the following?
  • Which caffe model are you using? Is it a public model or a custom trained model?
  • What Model Optimizer command have you used?
  • Also, could you please verify that you are using one of the Supported Topologies and has Supported Caffe Layers?
Jaivin
Vedansh_Surjan
Hi Jalvin,
I have used the model files from the link https://github.com/liuziwei7/fashion-landmarks
I have used command
python mo_caffe.py --input_model /home/vedanshsurjan/Projects/Fashion/Landmark_detection/fashion-landmarks/models/FLD_upper/FLD_upper_models/stage3_easy.caffemodel --input_proto /home/vedanshsurjan/Projects/Fashion/Landmark_detection/fashion-landmarks/models/FLD_upper/cascade.prototxt --output_dir /home/vedanshsurjan/Desktop/openvino/models_ir/landmark_detection/upper/stage3 --model_name upper_model_s3_easy
JAIVIN_J_Intel
Hi Vedansh,
Thanks for sharing the information.
To use the Model Optimizer for a multi-input model with two inputs, provide a new shape for each input in the order they are passed to the Model Optimizer. Please refer the documentation for using Caffe*-Specific Conversion Parameters.
You may also refer Examples of CLI Commands and use the parameters accordingly.
Jaivin
Vedansh_Surjan
Hi Jalvin
I included the input shape command but it did not resolve the issue
Command code :
python mo_caffe.py --input_model /home/vedanshsurjan/Projects/Fashion/Landmark_detection/fashion-landmarks/models/FLD_upper/FLD_upper_models/stage3_easy.caffemodel --input_proto /home/vedanshsurjan/Projects/Fashion/Landmark_detection/fashion-landmarks/models/FLD_upper/cascade.prototxt --output_dir /home/vedanshsurjan/Desktop/openvino/models_ir/landmark_detection/upper/stage3/ --model_name upper_model_s3_easy --input data,last_stage_data --input_shape [1,3,224,224],[1,1,1,12]
