Model Optimizing SSD Mobilenet model
Nemes__Adam
Hey
I want to run the model optimizer on my tensorflow model. But it doesnt work.
This is my command:
python mo.py --input_model C:\Code\OpenVINO\mo\model\frozen_inference_graph.pb^
    --tensorflow_object_detection_api_pipeline_config C:\Code\OpenVINO\mo\model\pipeline.config^
    --transformations_config "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\extensions\front\tf\ssd_v2_support.json"^
    --input_shape [1,224,224,1] --input image_tensor^
    --log_level=DEBUG
Here is my config:
model {
  ssd {
    num_classes: 1
    image_resizer {
      fixed_shape_resizer {
        height: 224
        width: 224
    feature_extractor {
      type: "ssd_mobilenet_v2"
      depth_multiplier: 1.0
      min_depth: 16
      conv_hyperparams {
        regularizer {
          l2_regularizer {
            weight: 4e-05
        initializer {
          truncated_normal_initializer {
            mean: 0.0
            stddev: 0.03
        activation: RELU_6
        batch_norm {
          decay: 0.9997
          center: true
          scale: true
          epsilon: 0.001
          train: true
    box_coder {
      faster_rcnn_box_coder {
        y_scale: 10.0
        x_scale: 10.0
        height_scale: 5.0
        width_scale: 5.0
    matcher {
      argmax_matcher {
        matched_threshold: 0.5
        unmatched_threshold: 0.5
        ignore_thresholds: false
        negatives_lower_than_unmatched: true
        force_match_for_each_row: true
    similarity_calculator {
      iou_similarity {
    box_predictor {
      convolutional_box_predictor {
        conv_hyperparams {
          regularizer {
            l2_regularizer {
              weight: 4e-05
          initializer {
              mean: 0.0
              stddev: 0.03
          activation: RELU_6
          batch_norm {
            decay: 0.9997
            center: true
            scale: true
            epsilon: 0.001
            train: true
        min_depth: 0
        max_depth: 0
        num_layers_before_predictor: 0
        use_dropout: false
        dropout_keep_probability: 0.8
        kernel_size: 1
        box_code_size: 4
        apply_sigmoid_to_scores: false
    anchor_generator {
      ssd_anchor_generator {
        num_layers: 6
        min_scale: 0.15
        max_scale: 0.95
        aspect_ratios: 0.7
        aspect_ratios: 1.0
    post_processing {
      batch_non_max_suppression {
        score_threshold: 1e-08
        iou_threshold: 0.3
        max_detections_per_class: 100
        max_total_detections: 100
      score_converter: SIGMOID
    normalize_loss_by_num_matches: true
    loss {
      localization_loss {
        weighted_smooth_l1 {
      classification_loss {
        weighted_sigmoid {
      hard_example_miner {
        num_hard_examples: 3000
        iou_threshold: 0.99
        loss_type: CLASSIFICATION
        max_negatives_per_positive: 3
        min_negatives_per_image: 3
      classification_weight: 1.0
      localization_weight: 1.0
train_config {
  batch_size: 36
  data_augmentation_options {
    random_horizontal_flip {
    random_pixel_value_scale {
      minval: 0.8
      maxval: 1.1
    random_rgb_to_gray {
      probability: 0.1
    random_adjust_brightness {
      max_delta: 0.25
    random_adjust_contrast {
      min_delta: 0.7
      max_delta: 1.2
  optimizer {
    adam_optimizer {
      learning_rate {
        manual_step_learning_rate {
          initial_learning_rate: 0.0004
          schedule {
            step: 1000
            learning_rate: 0.0001
          schedule {
            step: 3500
            learning_rate: 1e-05
    use_moving_average: false
  fine_tune_checkpoint: "ssd_mobilenet_v2_coco_2018_03_29/model.ckpt"
  num_steps: 10000
  fine_tune_checkpoint_type: "detection"
train_input_reader {
  label_map_path: "label_map.pbtxt"
  tf_record_input_reader {
    input_path: "tf_zone/tfr_summ/train.tfrecord"
eval_config {
  num_visualizations: 100
  use_moving_averages: false
eval_input_reader {
  shuffle: false
  num_readers: 1
    input_path: "tf_zone/tfr_summ/val.tfrecord"
And i got the following result:
c:\Code\OpenVINO\mo>mo.bat
c:\Code\OpenVINO\mo>cd "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer"
C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer>python mo.py --input_model C:\Code\OpenVINO\mo\224_fine_tuned_model\frozen_inference_graph.pb    --tensorflow_object_detection_api_pipeline_config C:\Code\OpenVINO\mo\224_fine_tuned_model\pipeline.config    --transformations_config "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\extensions\front\tf\ssd_v2_support.json"    --input_shape [1,224,224,1] --input image_tensor    --log_level=DEBUG
[ 2020-05-06 17:08:37,086 ] [ DEBUG ] [ main:117 ]  Namespace(batch=None, blobs_as_inputs=True, caffe_parser_path='mo\\front\\caffe\\proto', counts=None, data_type='float', disable_fusing=None, disable_gfusing=None, disable_nhwc_to_nchw=False, disable_omitting_optional=False, disable_resnet_optimization=False, enable_concat_optimization=False, enable_flattening_nested_params=False, enable_ssd_gluoncv=False, extensions='C:\\Program Files (x86)\\IntelSWTools\\openvino_2020.1.033\\deployment_tools\\model_optimizer\\extensions', finegrain_fusing=None, framework='tf', freeze_placeholder_with_value=None, generate_deprecated_IR_V2=False, generate_deprecated_IR_V7=False, generate_experimental_IR_V10=True, input='image_tensor', input_checkpoint=None, input_meta_graph=None, input_model='C:\\Code\\OpenVINO\\mo\\224_fine_tuned_model\\frozen_inference_graph.pb', input_model_is_text=False, input_proto=None, input_shape='[1,224,224,1]', input_symbol=None, k='extensions\\front\\caffe\\CustomLayersMapping.xml', keep_quantize_ops_in_IR=True, keep_shape_ops=False, legacy_mxnet_model=False, log_level='DEBUG', mean_file=None, mean_file_offsets=None, mean_values=(), model_name=None, move_to_preprocess=False, nd_prefix_name=None, output=None, output_dir='C:\\Program Files (x86)\\IntelSWTools\\openvino_2020.1.033\\deployment_tools\\model_optimizer\\.', pretrained_model_name=None, progress=False, remove_memory=False, remove_output_softmax=False, reverse_input_channels=False, save_params_from_nd=False, saved_model_dir=None, saved_model_tags=None, scale=None, scale_values=(), silent=False, stream_output=False, tensorboard_logdir=None, tensorflow_custom_layer_libraries=None, tensorflow_custom_operations_config_update=None, tensorflow_object_detection_api_pipeline_config='C:\\Code\\OpenVINO\\mo\\224_fine_tuned_model\\pipeline.config', tensorflow_operation_patterns=None, tensorflow_subgraph_patterns=None, tensorflow_use_custom_operations_config=None, transformations_config='C:\\Program Files (x86)\\IntelSWTools\\openvino_2020.1.033\\deployment_tools\\model_optimizer\\extensions\\front\\tf\\ssd_v2_support.json')
[ 2020-05-06 17:08:37,086 ] [ DEBUG ] [ main:118 ]  Model Optimizer started
[ 2020-05-06 17:08:37,088 ] [ DEBUG ] [ main:133 ]  Output model name would be frozen_inference_graph{.xml, .bin}
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      C:\Code\OpenVINO\mo\224_fine_tuned_model\frozen_inference_graph.pb
        - Path for generated IR:        C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\.
        - IR output name:       frozen_inference_graph
        - Log level:    DEBUG
        - Batch:        Not specified, inherited from the model
        - Input layers:         image_tensor
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         [1,224,224,1]
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  C:\Code\OpenVINO\mo\224_fine_tuned_model\pipeline.config
        - Operations to offload:        None
        - Patterns to offload:  None
        - Use the config file:  None
Model Optimizer version:        2020.1.0-61-gd349c3ba4a
[ 2020-05-06 17:08:38,128 ] [ DEBUG ] [ main:211 ]  Placeholder shapes : {'image_tensor': array([  1, 224, 224,   1], dtype=int64)}
[ INFO ]  Importing extensions from: C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo
[ INFO ]  New subclass: <class 'mo.ops.const.Const'>
[ INFO ]  Registered a new subclass with key: Const
[ INFO ]  New subclass: <class 'extensions.ops.gather.Gather'>
[ INFO ]  Registered a new subclass with key: Gather
[ INFO ]  New subclass: <class 'extensions.ops.gather.AttributedGather'>
[ INFO ]  Registered a new subclass with key: AttributedGather
[ INFO ]  New subclass: <class 'extensions.ops.split.VariadicSplitBase'>
[ INFO ]  New subclass: <class 'extensions.ops.split.SplitBase'>
[ INFO ]  New subclass: <class 'extensions.ops.parameter.Parameter'>
[ INFO ]  Registered a new subclass with key: Parameter
[ INFO ]  New subclass: <class 'extensions.ops.tensor_iterator.TensorIterator'>
[ INFO ]  Registered a new subclass with key: TensorIterator
[ INFO ]  New subclass: <class 'extensions.ops.transpose.Transpose'>
[ INFO ]  Registered a new subclass with key: Transpose
[ INFO ]  New subclass: <class 'mo.ops.clamp.Clamp'>
[ INFO ]  Registered a new subclass with key: Clamp
[ INFO ]  New subclass: <class 'extensions.ops.activation_ops.Activation'>
[ INFO ]  New subclass: <class 'extensions.ops.activation_ops.LeakyReLU'>
[ INFO ]  Registered a new subclass with key: LeakyReLU
[ INFO ]  New subclass: <class 'mo.ops.concat.Concat'>
[ INFO ]  Registered a new subclass with key: Concat
[ INFO ]  New subclass: <class 'mo.ops.convolution.Convolution'>
[ INFO ]  Registered a new subclass with key: Convolution
[ INFO ]  New subclass: <class 'mo.ops.crop.Crop'>
[ INFO ]  Registered a new subclass with key: Crop
[ INFO ]  New subclass: <class 'mo.ops.reshape.Reshape'>
[ INFO ]  Registered a new subclass with key: Reshape
[ INFO ]  New subclass: <class 'mo.ops.softmax.Softmax'>
[ INFO ]  Registered a new subclass with key: SoftMax
[ INFO ]  New subclass: <class 'extensions.ops.Cast.Cast'>
[ INFO ]  Registered a new subclass with key: Cast
[ INFO ]  New subclass: <class 'mo.ops.activation.Activation'>
[ INFO ]  Registered a new subclass with key: Activation
[ INFO ]  New subclass: <class 'mo.ops.broadcast.Broadcast'>
[ INFO ]  Registered a new subclass with key: Broadcast
[ INFO ]  New subclass: <class 'mo.ops.constant_of_shape.ConstantOfShape'>
[ INFO ]  Registered a new subclass with key: ConstantOfShape
[ INFO ]  New subclass: <class 'mo.ops.deconvolution.Deconvolution'>
[ INFO ]  Registered a new subclass with key: Deconvolution
[ INFO ]  New subclass: <class 'mo.ops.deformable_convolution.DeformableConvolution'>
[ INFO ]  Registered a new subclass with key: DeformableConvolution
[ INFO ]  New subclass: <class 'mo.ops.eltwise.Eltwise'>
[ INFO ]  Registered a new subclass with key: Eltwise
[ INFO ]  New subclass: <class 'mo.ops.eltwise_n.EltwiseN'>
[ INFO ]  Registered a new subclass with key: EltwiseN
[ INFO ]  New subclass: <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'>
[ INFO ]  Registered a new subclass with key: EltwiseNin1
[ INFO ]  New subclass: <class 'mo.ops.expand_dims.ExpandDims'>
[ INFO ]  Registered a new subclass with key: ExpandDims
[ INFO ]  New subclass: <class 'mo.ops.fill.Fill'>
[ INFO ]  Registered a new subclass with key: Fill
[ INFO ]  New subclass: <class 'mo.ops.flatten.Flatten'>
[ INFO ]  Registered a new subclass with key: Flatten
[ INFO ]  New subclass: <class 'mo.ops.flatten.FlattenONNX'>
[ INFO ]  Registered a new subclass with key: FlattenONNX
[ INFO ]  New subclass: <class 'mo.ops.group_norm.GroupNorm'>
[ INFO ]  Registered a new subclass with key: GroupNorm
[ INFO ]  New subclass: <class 'mo.ops.lrn.LRN'>
[ INFO ]  Registered a new subclass with key: LRN
[ INFO ]  New subclass: <class 'mo.ops.lrn.AttributedLRN'>
[ INFO ]  Registered a new subclass with key: AttributedLRN
[ INFO ]  New subclass: <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'>
[ INFO ]  Registered a new subclass with key: LstmNonLinearity
[ INFO ]  New subclass: <class 'mo.ops.memory.Memory'>
[ INFO ]  Registered a new subclass with key: Memory
[ INFO ]  New subclass: <class 'mo.ops.memoryoffset.MemoryOffset'>
[ INFO ]  Registered a new subclass with key: MemoryOffset
[ INFO ]  New subclass: <class 'mo.ops.pad.Pad'>
[ INFO ]  Registered a new subclass with key: Pad
[ INFO ]  New subclass: <class 'mo.ops.permute.Permute'>
[ INFO ]  Registered a new subclass with key: Permute
[ INFO ]  New subclass: <class 'mo.ops.pooling.Pooling'>
[ INFO ]  Registered a new subclass with key: Pooling
[ INFO ]  New subclass: <class 'mo.ops.power.AttributedPower'>
[ INFO ]  Registered a new subclass with key: AttributedPower
[ INFO ]  New subclass: <class 'mo.ops.result.Result'>
[ INFO ]  Registered a new subclass with key: Result
[ INFO ]  New subclass: <class 'mo.ops.roipooling.ROIPooling'>
[ INFO ]  Registered a new subclass with key: ROIPooling
[ INFO ]  New subclass: <class 'mo.ops.scale_shift.ScaleShiftOp'>
[ INFO ]  Registered a new subclass with key: ScaleShift
[ INFO ]  New subclass: <class 'mo.ops.shape.Shape'>
[ INFO ]  Registered a new subclass with key: ShapeOf
[ INFO ]  New subclass: <class 'mo.ops.slice.Slice'>
[ INFO ]  Registered a new subclass with key: Slice
[ INFO ]  New subclass: <class 'mo.ops.squeeze.Squeeze'>
[ INFO ]  Registered a new subclass with key: Squeeze
[ INFO ]  New subclass: <class 'mo.ops.strided_slice.StridedSlice'>
[ INFO ]  Registered a new subclass with key: StridedSlice
[ INFO ]  New subclass: <class 'mo.ops.tile.Tile'>
[ INFO ]  Registered a new subclass with key: Tile
[ INFO ]  New subclass: <class 'mo.ops.tile.AttributedTile'>
[ INFO ]  Registered a new subclass with key: AttributedTile
[ INFO ]  New subclass: <class 'mo.ops.unsqueeze.Unsqueeze'>
[ INFO ]  Registered a new subclass with key: Unsqueeze
[ INFO ]  New subclass: <class 'mo.utils.model_analysis.AnalysisCollectorAnchor'>
[ INFO ]  New subclass: <class 'mo.front.common.replacement.FrontReplacementSubgraph'>
[ INFO ]  New subclass: <class 'extensions.front.user_data_repack.UserDataRepack'>
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileGeneral'>
[ INFO ]  New subclass: <class 'mo.front.common.replacement.FrontReplacementOp'>
[ INFO ]  Registered a new subclass with key: UnknownOp
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileSubGraph'>
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileOp'>
[ WARNING ]  Skipped <class 'mo.front.common.replacement.FrontReplacementSubgraph'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.user_data_repack.UserDataRepack'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileGeneral'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.common.replacement.FrontReplacementOp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileSubGraph'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileOp'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.PreMiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.MiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.MiddleFinish'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.PostMiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'>
[ INFO ]  New subclass: <class 'extensions.back.pass_separator.BackStart'>
[ INFO ]  New subclass: <class 'extensions.back.pass_separator.BackFinish'>
[ INFO ]  New subclass: <class 'extensions.back.SpecialNodesFinalization.RemoveConstOps'>
[ INFO ]  New subclass: <class 'extensions.back.SpecialNodesFinalization.CreateConstNodesReplacement'>
[ INFO ]  New subclass: <class 'extensions.back.SpecialNodesFinalization.RemoveOutputOps'>
[ INFO ]  New subclass: <class 'extensions.back.SpecialNodesFinalization.NormalizeTI'>
[ INFO ]  New subclass: <class 'extensions.back.RemoveUselessConvert.RemoveUselessConvert'>
[ INFO ]  New subclass: <class 'extensions.back.op_versioning.OpVersioning'>
[ INFO ]  New subclass: <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'>
[ INFO ]  Importing extensions from: C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\extensions
[ WARNING ]  Skipped <class 'mo.ops.const.Const'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.gather.Gather'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.gather.AttributedGather'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.split.VariadicSplitBase'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.split.SplitBase'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.parameter.Parameter'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.tensor_iterator.TensorIterator'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.transpose.Transpose'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.clamp.Clamp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.activation_ops.Activation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.activation_ops.LeakyReLU'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.concat.Concat'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.convolution.Convolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.crop.Crop'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.reshape.Reshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.softmax.Softmax'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.Cast.Cast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.activation.Activation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.broadcast.Broadcast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.constant_of_shape.ConstantOfShape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.deconvolution.Deconvolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.deformable_convolution.DeformableConvolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise.Eltwise'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise_n.EltwiseN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.expand_dims.ExpandDims'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.fill.Fill'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.flatten.Flatten'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.flatten.FlattenONNX'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.group_norm.GroupNorm'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lrn.LRN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lrn.AttributedLRN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.memory.Memory'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.memoryoffset.MemoryOffset'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.pad.Pad'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.permute.Permute'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.pooling.Pooling'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.power.AttributedPower'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.result.Result'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.roipooling.ROIPooling'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.scale_shift.ScaleShiftOp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.shape.Shape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.slice.Slice'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.squeeze.Squeeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.strided_slice.StridedSlice'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.tile.Tile'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.tile.AttributedTile'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.unsqueeze.Unsqueeze'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.ops.BlockLSTM.BlockLSTM'>
[ INFO ]  Registered a new subclass with key: BlockLSTM
[ INFO ]  New subclass: <class 'extensions.ops.DetectionOutput.DetectionOutput'>
[ INFO ]  Registered a new subclass with key: DetectionOutput
[ INFO ]  New subclass: <class 'extensions.ops.Enter.Enter'>
[ INFO ]  Registered a new subclass with key: Enter
[ INFO ]  New subclass: <class 'extensions.ops.Exit.Exit'>
[ INFO ]  Registered a new subclass with key: Exit
[ INFO ]  New subclass: <class 'extensions.ops.RNN.RNN'>
[ INFO ]  Registered a new subclass with key: RNN
[ INFO ]  New subclass: <class 'extensions.ops.GRU.GRU'>
[ INFO ]  Registered a new subclass with key: GRU
[ INFO ]  New subclass: <class 'extensions.ops.GRUCell.GRUCell'>
[ INFO ]  Registered a new subclass with key: GRUCell
[ INFO ]  New subclass: <class 'extensions.ops.GatherNd.GatherNd'>
[ INFO ]  Registered a new subclass with key: GatherNd
[ INFO ]  New subclass: <class 'extensions.ops.GatherTree.GatherTree'>
[ INFO ]  Registered a new subclass with key: GatherTree
[ INFO ]  New subclass: <class 'extensions.ops.LSTM.LSTM'>
[ INFO ]  Registered a new subclass with key: LSTM
[ INFO ]  New subclass: <class 'extensions.ops.Log.LogOp'>
[ INFO ]  Registered a new subclass with key: Log
[ INFO ]  New subclass: <class 'extensions.ops.MatMul.MatMul'>
[ INFO ]  Registered a new subclass with key: MatMul
[ INFO ]  New subclass: <class 'extensions.ops.MatMul.GemmONNX'>
[ INFO ]  Registered a new subclass with key: Gemm
[ INFO ]  New subclass: <class 'extensions.ops.MatMul.FullyConnected'>
[ INFO ]  Registered a new subclass with key: FullyConnected
[ INFO ]  New subclass: <class 'extensions.ops.NextIteration.NextIteration'>
[ INFO ]  Registered a new subclass with key: NextIteration
[ INFO ]  New subclass: <class 'extensions.ops.RNNCell.RNNCell'>
[ INFO ]  Registered a new subclass with key: RNNCell
[ INFO ]  New subclass: <class 'extensions.ops.ReduceOps.ReduceOp'>
[ INFO ]  New subclass: <class 'extensions.ops.Reverse.Reverse'>
[ INFO ]  Registered a new subclass with key: Reverse
[ INFO ]  New subclass: <class 'extensions.ops.TensorArray.TensorArray'>
[ INFO ]  Registered a new subclass with key: TensorArrayV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayGather.TensorArrayGather'>
[ INFO ]  Registered a new subclass with key: TensorArrayGatherV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayRead.TensorArrayReader'>
[ INFO ]  Registered a new subclass with key: TensorArrayReadV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayScatter.TensorArrayScatter'>
[ INFO ]  Registered a new subclass with key: TensorArrayScatterV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArraySize.TensorArraySize'>
[ INFO ]  Registered a new subclass with key: TensorArraySizeV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayWrite.TensorArrayWriter'>
[ INFO ]  Registered a new subclass with key: TensorArrayWriteV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorInput'>
[ INFO ]  Registered a new subclass with key: TensorIteratorInput
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorOutput'>
[ INFO ]  Registered a new subclass with key: TensorIteratorOutput
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorCondition'>
[ INFO ]  Registered a new subclass with key: TensorIteratorCondition
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorBackEdge'>
[ INFO ]  Registered a new subclass with key: TensorIteratorBackEdge
[ INFO ]  New subclass: <class 'extensions.ops.accum.AccumOp'>
[ INFO ]  Registered a new subclass with key: Accum
[ INFO ]  New subclass: <class 'extensions.ops.adaptive_avg_pooling.AdaptiveAvgPooling'>
[ INFO ]  Registered a new subclass with key: AdaptiveAvgPooling
[ INFO ]  New subclass: <class 'extensions.ops.argmax.ArgMaxOp'>
[ INFO ]  Registered a new subclass with key: ArgMax
[ INFO ]  New subclass: <class 'extensions.ops.assert_op.Assert'>
[ INFO ]  Registered a new subclass with key: Assert
[ INFO ]  New subclass: <class 'extensions.ops.axpy.AxpyOp'>
[ INFO ]  Registered a new subclass with key: Axpy
[ INFO ]  New subclass: <class 'extensions.ops.binarization.Binarization'>
[ INFO ]  Registered a new subclass with key: Binarization
[ INFO ]  New subclass: <class 'extensions.ops.bn.BNOp'>
[ INFO ]  Registered a new subclass with key: BN
[ INFO ]  New subclass: <class 'extensions.ops.box_nms.BoxNms'>
[ INFO ]  Registered a new subclass with key: _contrib_box_nms
[ INFO ]  New subclass: <class 'extensions.ops.bucketize.Bucketize'>
[ INFO ]  Registered a new subclass with key: Bucketize
[ INFO ]  New subclass: <class 'extensions.ops.constant_fill.ConstantFill'>
[ INFO ]  Registered a new subclass with key: ConstantFill
[ INFO ]  New subclass: <class 'extensions.ops.copyop.CopyOp'>
[ INFO ]  Registered a new subclass with key: copy
[ INFO ]  New subclass: <class 'extensions.ops.correlation.CorrelationOp'>
[ INFO ]  Registered a new subclass with key: Correlation
[ INFO ]  New subclass: <class 'extensions.ops.ctc_greedy_decoder.CTCGreedyDecoderOp'>
[ INFO ]  Registered a new subclass with key: CTCGreedyDecoder
[ INFO ]  New subclass: <class 'extensions.ops.data_augmentation.DataAugmentationOp'>
[ INFO ]  Registered a new subclass with key: DataAugmentation
[ INFO ]  New subclass: <class 'extensions.ops.depth_to_space.DepthToSpaceOp'>
[ INFO ]  Registered a new subclass with key: DepthToSpace
[ INFO ]  New subclass: <class 'extensions.ops.detectionoutput_onnx.ExperimentalDetectronDetectionOutput'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronDetectionOutput
[ INFO ]  New subclass: <class 'extensions.ops.elementwise.Elementwise'>
[ INFO ]  New subclass: <class 'extensions.ops.exp.ExpOp'>
[ INFO ]  New subclass: <class 'extensions.ops.fakequantize.FakeQuantize'>
[ INFO ]  Registered a new subclass with key: FakeQuantize
[ INFO ]  New subclass: <class 'extensions.ops.grn.GRNOp'>
[ INFO ]  Registered a new subclass with key: GRN
[ INFO ]  New subclass: <class 'extensions.ops.hard_sigmoid.HardSigmoid'>
[ INFO ]  Registered a new subclass with key: HardSigmoid
[ INFO ]  New subclass: <class 'extensions.ops.identity.IdentityOp'>
[ INFO ]  Registered a new subclass with key: Identity
[ INFO ]  New subclass: <class 'extensions.ops.instance_normalization.InstanceNormalization'>
[ INFO ]  Registered a new subclass with key: InstanceNormalization
[ INFO ]  New subclass: <class 'extensions.ops.interp.InterpOp'>
[ INFO ]  Registered a new subclass with key: Interp
[ INFO ]  New subclass: <class 'extensions.ops.interpolate.Interpolate'>
[ INFO ]  Registered a new subclass with key: Interpolate
[ INFO ]  New subclass: <class 'extensions.ops.lstm_cell.LSTMCell'>
[ INFO ]  Registered a new subclass with key: LSTMCell
[ INFO ]  New subclass: <class 'extensions.ops.lstm_sequence.LSTMSequence'>
[ INFO ]  Registered a new subclass with key: LSTMSequence
[ INFO ]  New subclass: <class 'extensions.ops.merge.Merge'>
[ INFO ]  Registered a new subclass with key: Merge
[ INFO ]  New subclass: <class 'extensions.ops.mvn.MVN'>
[ INFO ]  Registered a new subclass with key: MVN
[ INFO ]  New subclass: <class 'extensions.ops.mxrepeat.MXRepeat'>
[ INFO ]  Registered a new subclass with key: MXRepeat
[ INFO ]  New subclass: <class 'extensions.ops.mxslice.MXSlice'>
[ INFO ]  Registered a new subclass with key: MXSlice
[ INFO ]  New subclass: <class 'extensions.ops.non_max_suppression.NonMaxSuppression'>
[ INFO ]  Registered a new subclass with key: NonMaxSuppression
[ INFO ]  New subclass: <class 'extensions.ops.non_zero.NonZero'>
[ INFO ]  Registered a new subclass with key: NonZero
[ INFO ]  New subclass: <class 'extensions.ops.normalize.NormalizeOp'>
[ INFO ]  Registered a new subclass with key: Normalize
[ INFO ]  New subclass: <class 'extensions.ops.normalize_l2.NormalizeL2Op'>
[ INFO ]  Registered a new subclass with key: NormalizeL2
[ INFO ]  New subclass: <class 'extensions.ops.one_hot.OneHot'>
[ INFO ]  Registered a new subclass with key: OneHot
[ INFO ]  New subclass: <class 'extensions.ops.pack.PackOp'>
[ INFO ]  Registered a new subclass with key: Pack
[ INFO ]  New subclass: <class 'extensions.ops.pnorm.PNormOp'>
[ INFO ]  Registered a new subclass with key: pnorm
[ INFO ]  New subclass: <class 'extensions.ops.power_file.PowerFileOp'>
[ INFO ]  Registered a new subclass with key: PowerFile
[ INFO ]  New subclass: <class 'extensions.ops.prediction_heatmap.PredictionHeatmapOp'>
[ INFO ]  Registered a new subclass with key: PredictionHeatmap
[ INFO ]  New subclass: <class 'extensions.ops.prelu.PreluOp'>
[ INFO ]  Registered a new subclass with key: PReLU
[ INFO ]  New subclass: <class 'extensions.ops.priorbox.PriorBoxOp'>
[ INFO ]  Registered a new subclass with key: PriorBox
[ INFO ]  New subclass: <class 'extensions.ops.priorbox_clustered.PriorBoxClusteredOp'>
[ INFO ]  Registered a new subclass with key: PriorBoxClustered
[ INFO ]  New subclass: <class 'extensions.ops.priorgridgenerator_onnx.ExperimentalDetectronPriorGridGenerator'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronPriorGridGenerator
[ INFO ]  New subclass: <class 'extensions.ops.proposal.ProposalOp'>
[ INFO ]  Registered a new subclass with key: Proposal
[ INFO ]  New subclass: <class 'extensions.ops.proposal_onnx.ExperimentalDetectronGenerateProposalsSingleImage'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronGenerateProposalsSingleImage
[ INFO ]  New subclass: <class 'extensions.ops.psroipooling.PSROIPoolingOp'>
[ INFO ]  Registered a new subclass with key: PSROIPooling
[ INFO ]  New subclass: <class 'extensions.ops.range.Range'>
[ INFO ]  Registered a new subclass with key: Range
[ INFO ]  New subclass: <class 'extensions.ops.rank.Rank'>
[ INFO ]  Registered a new subclass with key: Rank
[ INFO ]  New subclass: <class 'extensions.ops.regionyolo.RegionYoloOp'>
[ INFO ]  Registered a new subclass with key: RegionYolo
[ INFO ]  New subclass: <class 'extensions.ops.reorgyolo.ReorgYoloOp'>
[ INFO ]  Registered a new subclass with key: ReorgYolo
[ INFO ]  New subclass: <class 'extensions.ops.resample.ResampleOp'>
[ INFO ]  Registered a new subclass with key: Resample
[ INFO ]  New subclass: <class 'extensions.ops.resize.ResizeOp'>
[ INFO ]  Registered a new subclass with key: Resize
[ INFO ]  New subclass: <class 'extensions.ops.reverse_sequence.ReverseSequence'>
[ INFO ]  Registered a new subclass with key: ReverseSequence
[ INFO ]  New subclass: <class 'extensions.ops.roifeatureextractor_onnx.ExperimentalDetectronROIFeatureExtractor'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronROIFeatureExtractor
[ INFO ]  New subclass: <class 'extensions.ops.select.Select'>
[ INFO ]  Registered a new subclass with key: Select
[ INFO ]  New subclass: <class 'extensions.ops.shufflechannel.ShuffleChannelOp'>
[ INFO ]  Registered a new subclass with key: ShuffleChannel
[ INFO ]  New subclass: <class 'extensions.ops.simplernms.SimplerNMSOp'>
[ INFO ]  Registered a new subclass with key: SimplerNMS
[ INFO ]  New subclass: <class 'extensions.ops.size.Size'>
[ INFO ]  Registered a new subclass with key: Size
[ INFO ]  New subclass: <class 'extensions.ops.space_to_depth.SpaceToDepth'>
[ INFO ]  Registered a new subclass with key: SpaceToDepth
[ INFO ]  New subclass: <class 'extensions.ops.sparse_fill_empty_rows.SparseFillEmptyRows'>
[ INFO ]  Registered a new subclass with key: SparseFillEmptyRows
[ INFO ]  New subclass: <class 'extensions.ops.sparse_reshape.SparseReshape'>
[ INFO ]  Registered a new subclass with key: SparseReshape
[ INFO ]  New subclass: <class 'extensions.ops.sparse_segment_mean.SparseSegmentMean'>
[ INFO ]  Registered a new subclass with key: SparseSegmentMean
[ INFO ]  New subclass: <class 'extensions.ops.sparse_segment_sqrtn.SparseSegmentSqrtN'>
[ INFO ]  Registered a new subclass with key: SparseSegmentSqrtN
[ INFO ]  New subclass: <class 'extensions.ops.sparse_segment_sum.SparseSegmentSum'>
[ INFO ]  Registered a new subclass with key: SparseSegmentSum
[ INFO ]  New subclass: <class 'extensions.ops.sparse_to_dense.SparseToDense'>
[ INFO ]  Registered a new subclass with key: SparseToDense
[ INFO ]  New subclass: <class 'extensions.ops.sparse_weighted_sum.ExperimentalSparseWeightedSum'>
[ INFO ]  Registered a new subclass with key: ExperimentalSparseWeightedSum
[ INFO ]  New subclass: <class 'extensions.ops.spatial_transformer.SpatialTransformOp'>
[ INFO ]  Registered a new subclass with key: SpatialTransformer
[ INFO ]  New subclass: <class 'extensions.ops.splice.Splice'>
[ INFO ]  Registered a new subclass with key: Splice
[ INFO ]  New subclass: <class 'extensions.ops.stop_gradient.StopGradientOp'>
[ INFO ]  Registered a new subclass with key: StopGradient
[ INFO ]  New subclass: <class 'extensions.ops.swapaxis.SwapAxis'>
[ INFO ]  Registered a new subclass with key: SwapAxis
[ INFO ]  New subclass: <class 'extensions.ops.switch.Switch'>
[ INFO ]  Registered a new subclass with key: Switch
[ INFO ]  New subclass: <class 'extensions.ops.topk.TopK'>
[ INFO ]  Registered a new subclass with key: TopK
[ INFO ]  New subclass: <class 'extensions.ops.topkrois_onnx.ExperimentalDetectronTopKROIs'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronTopKROIs
[ INFO ]  New subclass: <class 'extensions.ops.unique.Unique'>
[ INFO ]  Registered a new subclass with key: Unique
[ INFO ]  New subclass: <class 'extensions.ops.upsample.UpsampleOp'>
[ INFO ]  Registered a new subclass with key: Upsample
[ WARNING ]  Skipped <class 'mo.utils.model_analysis.AnalysisCollectorAnchor'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.analysis.boolean_input.TrainingPhaseAnalysis'>
[ INFO ]  New subclass: <class 'extensions.analysis.inputs.InputsAnalysis'>
[ INFO ]  New subclass: <class 'extensions.analysis.json_print.AnalysisJSONPrint'>
[ INFO ]  New subclass: <class 'extensions.analysis.nodes.IntermediatesNodesAnalysis'>
[ INFO ]  New subclass: <class 'extensions.analysis.tf_od_api.TensorFlowObjectDetectionAPIAnalysis'>
[ INFO ]  New subclass: <class 'extensions.analysis.tf_retinanet.TensorFlowRetinaNet'>
[ INFO ]  New subclass: <class 'extensions.analysis.tf_yolo.TensorFlowYOLOV1V2Analysis'>
[ INFO ]  New subclass: <class 'extensions.analysis.tf_yolo.TensorFlowYOLOV3Analysis'>
[ WARNING ]  Skipped <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.AttributedGatherNormalizer.AttributedGatherNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.LRNReplacer.LRNReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.Log1p.Log1p'>
[ INFO ]  Registered a new subclass with key: Log1p
[ INFO ]  New subclass: <class 'extensions.front.Pack.Pack'>
[ INFO ]  New subclass: <class 'extensions.front.PowerToEltwises.PowerToEltwises'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'>
[ INFO ]  Registered a new subclass with key: FakeQuantWithMinMaxVars
[ INFO ]  New subclass: <class 'extensions.front.div.Div'>
[ INFO ]  Registered a new subclass with key: Div
[ INFO ]  New subclass: <class 'extensions.front.eltwise_n.EltwiseNReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.rank_decomposer.RankDecomposer'>
[ INFO ]  New subclass: <class 'extensions.front.image_scaler.ImageScaler'>
[ INFO ]  Registered a new subclass with key: ImageScaler
[ INFO ]  New subclass: <class 'extensions.front.instance_normalization.InstanceNormalization'>
[ INFO ]  New subclass: <class 'extensions.front.reciprocal.ReciprocalReplacer'>
[ INFO ]  Registered a new subclass with key: Reciprocal
[ INFO ]  New subclass: <class 'extensions.front.sub.Sub'>
[ INFO ]  Registered a new subclass with key: Sub
[ INFO ]  New subclass: <class 'extensions.front.softsign_replacer.SoftSign'>
[ INFO ]  Registered a new subclass with key: Softsign
[ INFO ]  New subclass: <class 'extensions.front.split_normalizer.SqueezeAxis'>
[ INFO ]  New subclass: <class 'extensions.front.squared_difference.SquaredDifference'>
[ INFO ]  Registered a new subclass with key: SquaredDifference
[ INFO ]  New subclass: <class 'extensions.front.ChangePlaceholderTypes.ChangePlaceholderTypes'>
[ INFO ]  New subclass: <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'>
[ INFO ]  New subclass: <class 'extensions.front.FillToBroadcast.FillToBroadcast'>
[ INFO ]  New subclass: <class 'extensions.front.pass_separator.FrontStart'>
[ INFO ]  New subclass: <class 'extensions.front.pass_separator.FrontFinish'>
[ INFO ]  New subclass: <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.TopKNormalize.TopKNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'>
[ INFO ]  New subclass: <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'>
[ INFO ]  New subclass: <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'>
[ INFO ]  New subclass: <class 'extensions.front.global_pooling_to_reduce.GlobalPoolingToReduce'>
[ INFO ]  New subclass: <class 'extensions.front.input_cut.InputCut'>
[ INFO ]  New subclass: <class 'extensions.front.output_cut.OutputCut'>
[ INFO ]  New subclass: <class 'extensions.front.override_batch.OverrideBatch'>
[ INFO ]  New subclass: <class 'extensions.front.transformations_config.TransformationsConfig'>
[ INFO ]  New subclass: <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'>
[ INFO ]  New subclass: <class 'extensions.front.ChangeCastOutputType.ChangeCastOutputType'>
[ INFO ]  New subclass: <class 'extensions.front.MatMul_normalizer.FullyConnectedDecomposer'>
[ INFO ]  New subclass: <class 'extensions.front.MatMul_normalizer.GemmDecomposer'>
[ INFO ]  New subclass: <class 'extensions.front.restore_ports.RestorePorts'>
[ INFO ]  New subclass: <class 'extensions.front.MoveEmbeddedInputsToInputs.MoveEmbeddedInputsToInputs'>
[ INFO ]  New subclass: <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.no_op_eraser.NoOpEraser'>
[ INFO ]  New subclass: <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'>
[ INFO ]  New subclass: <class 'extensions.front.flatten_to_reshape.FlattenToReshape'>
[ INFO ]  New subclass: <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'>
[ INFO ]  New subclass: <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.softmax.SoftmaxFromKeras'>
[ INFO ]  New subclass: <class 'extensions.front.split_normalizer.SplitInputsReconnect'>
[ INFO ]  New subclass: <class 'extensions.front.split_normalizer.AttributedSplitToSplit'>
[ INFO ]  New subclass: <class 'extensions.front.split_normalizer.AttributedVariadicSplitToVariadicSplit'>
[ INFO ]  New subclass: <class 'extensions.front.split_normalizer.VariadicSplitInputsSwap'>
[ INFO ]  New subclass: <class 'extensions.front.YOLO.YoloRegionAddon'>
[ INFO ]  New subclass: <class 'extensions.front.YOLO.YoloV3RegionAddon'>
[ INFO ]  New subclass: <class 'extensions.front.tf.BatchMatMul_ext.BatchMatMulExtractor'>
[ INFO ]  Registered a new subclass with key: BatchMatMul
[ INFO ]  New subclass: <class 'extensions.front.tf.BatchMatMul_ext.BatchMatMulV2Extractor'>
[ INFO ]  Registered a new subclass with key: BatchMatMulV2
[ INFO ]  New subclass: <class 'extensions.front.tf.BlockLSTM_ext.BlockLSTMExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CTCGreedyDecoder_ext.CTCCGreedyDecoderFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.Cast_ext.CastFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FakeQuantWithMinMaxVars_ext.FakeQuantWithMinMaxVarsExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.GatherTree_ext.GatherTreeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.LoopCond_ext.LoopCondFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LoopCond
[ INFO ]  New subclass: <class 'extensions.front.tf.TensorArrayExtractors.TensorArrayExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.TensorArrayGatherV3.TensorArrayGatherV3Exteractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.AbsExtractor'>
[ INFO ]  Registered a new subclass with key: Abs
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.EluFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Elu
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.ErfFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Erf
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.ExpExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.LeakyReLUFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LeakyRelu
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.LogicalNotFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalNot
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.Relu6FrontExtractor'>
[ INFO ]  Registered a new subclass with key: Relu6
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.ReluFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.SigmoidFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sigmoid
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.CosFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Cos
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.CoshFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Cosh
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.SinFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sin
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.SinhFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sinh
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.TanFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Tan
[ INFO ]  New subclass: <class 'extensions.front.tf.activation_ext.TanhFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Tanh
[ INFO ]  New subclass: <class 'extensions.front.tf.argmax_ext.ArgMaxFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.bucketize_ext.BucketizeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.concat_ext.ConcatFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.const_ext.ConstExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.Conv2DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv2D
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.DepthwiseConv2dNativeFrontExtractor'>
[ INFO ]  Registered a new subclass with key: DepthwiseConv2dNative
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.Conv3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv3D
[ INFO ]  New subclass: <class 'extensions.front.tf.crop_and_resize_ext.CropAndResizeFrontExtractor'>
[ INFO ]  Registered a new subclass with key: CropAndResize
[ INFO ]  New subclass: <class 'extensions.front.tf.deconv_ext.Conv2DBackpropInputFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv2DBackpropInput
[ INFO ]  New subclass: <class 'extensions.front.tf.deconv_ext.Conv3DBackpropInputV2InputFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv3DBackpropInputV2
[ INFO ]  New subclass: <class 'extensions.front.tf.depth_to_space.DepthToSpaceFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddExtractor'>
[ INFO ]  Registered a new subclass with key: Add
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddV2Extractor'>
[ INFO ]  Registered a new subclass with key: AddV2
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddNExtractor'>
[ INFO ]  Registered a new subclass with key: AddN
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.BiasAddExtractor'>
[ INFO ]  Registered a new subclass with key: BiasAdd
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MulExtractor'>
[ INFO ]  Registered a new subclass with key: Mul
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SubExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.DivExtractor'>
[ INFO ]  Registered a new subclass with key: RealDiv
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SquaredDifferenceExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SqrtExtractor'>
[ INFO ]  Registered a new subclass with key: Sqrt
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.RsqrtExtractor'>
[ INFO ]  Registered a new subclass with key: Rsqrt
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SquareExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.NegExtractor'>
[ INFO ]  Registered a new subclass with key: Neg
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.ZerosLike'>
[ INFO ]  Registered a new subclass with key: ZerosLike
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MaximumExtractor'>
[ INFO ]  Registered a new subclass with key: Maximum
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MinimumExtractor'>
[ INFO ]  Registered a new subclass with key: Minimum
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.PowExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LogicalAndFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalAnd
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LogicalOrFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalOr
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.EqualExtractor'>
[ INFO ]  Registered a new subclass with key: Equal
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LessEqualExtractor'>
[ INFO ]  Registered a new subclass with key: LessEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LessExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.GreaterExtractor'>
[ INFO ]  Registered a new subclass with key: Greater
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.GreaterEqualExtractor'>
[ INFO ]  Registered a new subclass with key: GreaterEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.NotEqualExtractor'>
[ INFO ]  Registered a new subclass with key: NotEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.FloorModFrontExtractor'>
[ INFO ]  Registered a new subclass with key: FloorMod
[ INFO ]  New subclass: <class 'extensions.front.tf.expand_dims_ext.ExpandDimsExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.extract_image_patches_ext.ExtractImagePatchesExtractor'>
[ INFO ]  Registered a new subclass with key: ExtractImagePatches
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_queue_v2_ext.FIFOQueueV2Extractor'>
[ INFO ]  Registered a new subclass with key: FIFOQueueV2
[ INFO ]  New subclass: <class 'extensions.front.tf.fill_ext.FillExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.GatherFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.ResourceGatherFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResourceGather
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.GatherV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: GatherV2
[ INFO ]  New subclass: <class 'extensions.front.tf.identity_ext.IdentityFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.identity_ext.ReadVariableOpFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ReadVariableOp
[ INFO ]  New subclass: <class 'extensions.front.tf.identity_ext.StopGradientExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.lrn_ext.LRNExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.matmul_ext.MatMulExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.next_iteration_ext.NextIterationExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.non_max_suppression_ext.NonMaxSuppressionV3Extractor'>
[ INFO ]  Registered a new subclass with key: NonMaxSuppressionV3
[ INFO ]  New subclass: <class 'extensions.front.tf.non_max_suppression_ext.NonMaxSuppressionV4Extractor'>
[ INFO ]  Registered a new subclass with key: NonMaxSuppressionV4
[ INFO ]  New subclass: <class 'extensions.front.tf.non_max_suppression_ext.NonMaxSuppressionV5Extractor'>
[ INFO ]  Registered a new subclass with key: NonMaxSuppressionV5
[ INFO ]  New subclass: <class 'extensions.front.tf.one_hot_ext.OneHotFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.PadFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.PadV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: PadV2
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.MirrorPadFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MirrorPad
[ INFO ]  New subclass: <class 'extensions.front.tf.placeholder_ext.PlaceholderFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Placeholder
[ INFO ]  New subclass: <class 'extensions.front.tf.placeholder_with_default_ext.PlaceholderWithDefaultExtractor'>
[ INFO ]  Registered a new subclass with key: PlaceholderWithDefault
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.AvgPoolFrontExtractor'>
[ INFO ]  Registered a new subclass with key: AvgPool
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.MaxPoolFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MaxPool
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.MaxPool3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MaxPool3D
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.AvgPool3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: AvgPool3D
[ INFO ]  New subclass: <class 'extensions.front.tf.reduce_ext.AllFrontExtractor'>
[ INFO ]  Registered a new subclass with key: All
[ INFO ]  New subclass: <class 'extensions.front.tf.reduce_ext.MaxFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reduce_ext.MeanExtractor'>
[ INFO ]  Registered a new subclass with key: Mean
[ INFO ]  New subclass: <class 'extensions.front.tf.reduce_ext.ProdFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Prod
[ INFO ]  New subclass: <class 'extensions.front.tf.reduce_ext.SumFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sum
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_related_ext.RankFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_related_ext.ReshapeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_related_ext.ShapeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_related_ext.SizeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_related_ext.SqueezeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.resize_bilinear.ResizeBilinearFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResizeBilinear
[ INFO ]  New subclass: <class 'extensions.front.tf.resize_nearest_neighbor.ResizeNearestNeighborFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResizeNearestNeighbor
[ INFO ]  New subclass: <class 'extensions.front.tf.reverse_sequence.ReverseSequenceFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reverse_v2.ReverseV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: ReverseV2
[ INFO ]  New subclass: <class 'extensions.front.tf.select_ext.SelectExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sign_ext.SignExtractor'>
[ INFO ]  Registered a new subclass with key: Sign
[ INFO ]  New subclass: <class 'extensions.front.tf.slice_ext.SliceExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.softmax_ext.SoftmaxFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Softmax
[ INFO ]  New subclass: <class 'extensions.front.tf.space_to_depth_ext.SpaceToDepthFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_fill_empty_rows_ext.SparseFillEmptyRowsFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_segment_mean_ext.SparseSegmentMeanFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_segment_sqrtn_ext.SparseSegmentSqrtNFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_segment_sum_ext.SparseSegmentSumFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_to_dense_ext.SparseToDenseFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.split_ext.SplitVExtractor'>
[ INFO ]  Registered a new subclass with key: SplitV
[ INFO ]  New subclass: <class 'extensions.front.tf.split_ext.UnpackExtractor'>
[ INFO ]  Registered a new subclass with key: Unpack
[ INFO ]  New subclass: <class 'extensions.front.tf.split_ext.SplitExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tile_ext.TileExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.topk_ext.TopKExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.topk_ext.TopKV2Extractor'>
[ INFO ]  Registered a new subclass with key: TopKV2
[ INFO ]  New subclass: <class 'extensions.front.tf.transpose_ext.TransposeFrontExtractorTF'>
[ INFO ]  New subclass: <class 'extensions.front.tf.unique_ext.UniqueFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.variable_ext.VariableExtractor'>
[ INFO ]  Registered a new subclass with key: Variable
[ INFO ]  New subclass: <class 'extensions.front.tf.variable_ext.VariableV2Extractor'>
[ INFO ]  Registered a new subclass with key: VariableV2
[ WARNING ]  Skipped <class 'extensions.front.AttributedGatherNormalizer.AttributedGatherNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.LRNReplacer.LRNReplacer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.Log1p.Log1p'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.Pack.Pack'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.PowerToEltwises.PowerToEltwises'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.div.Div'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.eltwise_n.EltwiseNReplacement'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.rank_decomposer.RankDecomposer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.image_scaler.ImageScaler'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.instance_normalization.InstanceNormalization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reciprocal.ReciprocalReplacer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.sub.Sub'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.softsign_replacer.SoftSign'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.split_normalizer.SqueezeAxis'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.squared_difference.SquaredDifference'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.BlockLSTM.BlockLSTM'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CropAndResizeReplacement.CropAndResizeReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.LogSoftmax.LogSoftmaxFrontReplacer'>
[ INFO ]  Registered a new subclass with key: LogSoftmax
[ INFO ]  New subclass: <class 'extensions.front.tf.SizeReplacer.SizeFrontReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignElimination'>
[ INFO ]  Registered a new subclass with key: Assign
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignSubElimination'>
[ INFO ]  Registered a new subclass with key: AssignSub
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignAddElimination'>
[ INFO ]  Registered a new subclass with key: AssignAdd
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssertElimination'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fake_const_ext.FakeConstToConst'>
[ INFO ]  Registered a new subclass with key: FakeConst
[ INFO ]  New subclass: <class 'extensions.front.tf.swish.Swish'>
[ INFO ]  Registered a new subclass with key: swish_f32
[ WARNING ]  Skipped <class 'extensions.front.ChangePlaceholderTypes.ChangePlaceholderTypes'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.FillToBroadcast.FillToBroadcast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.pass_separator.FrontStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.pass_separator.FrontFinish'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.TopKNormalize.TopKNormalize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.global_pooling_to_reduce.GlobalPoolingToReduce'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.input_cut.InputCut'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.output_cut.OutputCut'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.override_batch.OverrideBatch'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.transformations_config.TransformationsConfig'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.GNMT_DynamicSequenceLengths.GNMT_sequence_lengths'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_patterns.TensorflowSubgraphPatterns'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_patterns.TensorflowOperationPatterns'>
[ INFO ]  New subclass: <class 'extensions.front.tf.variables_values_freezing.VariablesToConstants'>
[ WARNING ]  Skipped <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.ChangeCastOutputType.ChangeCastOutputType'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.MatMul_normalizer.FullyConnectedDecomposer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.MatMul_normalizer.GemmDecomposer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.restore_ports.RestorePorts'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.MoveEmbeddedInputsToInputs.MoveEmbeddedInputsToInputs'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.no_op_eraser.NoOpEraser'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.flatten_to_reshape.FlattenToReshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.softmax.SoftmaxFromKeras'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.split_normalizer.SplitInputsReconnect'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.split_normalizer.AttributedSplitToSplit'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.split_normalizer.AttributedVariadicSplitToVariadicSplit'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.split_normalizer.VariadicSplitInputsSwap'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.BatchToSpaceNDToUpsample.BatchToSpaceNDToUpsample'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CTCGreedyDecoder.CTCGreedyDecoderReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.nearest_neighbor_upsampling.NearestNeighborUpsampling'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FlattenToReshape.FlattenToReshapeableReshape'>
[ INFO ]  New subclass: <class 'extensions.front.tf.SwitchMergeOptimization.SwitchMergeOptimization'>
[ INFO ]  New subclass: <class 'extensions.front.tf.UnpackPackReverseInputChannels.UnpackPackReverseInputChannels'>
[ INFO ]  New subclass: <class 'extensions.front.tf.basic_lstm_cell.BasicLSTMCell'>
[ INFO ]  New subclass: <class 'extensions.front.tf.bucketize.BucketizeFrontReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.tf.concat.Concat'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_replacer.FIFOQueue'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_replacer.QueueDequeueManyV2'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mvn.MVNReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mvn_unrolled.MVNUnrolled'>
[ INFO ]  New subclass: <class 'extensions.front.tf.non_max_suppression_normalize.TFNonMaxSuppressionNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.tf.prelu.PReLU'>
[ INFO ]  New subclass: <class 'extensions.front.tf.prelu.PReLUWithAbs'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_weighted_sum.ExperimentalSparseWeightedSumFrontReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sparse_weighted_sum.ExperimentalSparseWeightedSumFrontReplacer2'>
[ INFO ]  New subclass: <class 'extensions.front.tf.swap_deconv_inputs.SwapDeconvInputs'>
[ INFO ]  New subclass: <class 'extensions.front.tf.transposed_mvn_unrolled.TransposedMVNUnrolled'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessorReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIProposalReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPSROIPoolingReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.RetinaNetFilteredDetectionsReplacement.RetinaNetFilteredDetectionsReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.SSDToolboxDetectionOutput.SSDToolboxDetectionOutputReplacement'>
[ WARNING ]  Skipped <class 'extensions.front.YOLO.YoloRegionAddon'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.YOLO.YoloV3RegionAddon'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.InterpolateTransposes.InterpolateTranspose'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNSigmoidReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIConstValueOverride'>
[ WARNING ]  Skipped <class 'extensions.middle.pass_separator.PreMiddleStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.pass_separator.MiddleStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.pass_separator.MiddleFinish'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.pass_separator.PostMiddleStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.LoopConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.SimpleConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.DynamicDecoderConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.MulFakeQuantizeFuse.MulFakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.AddFakeQuantizeFuse.AddFakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.AddIsCyclicAttribute.AddIsCyclicAttribute'>
[ INFO ]  New subclass: <class 'extensions.middle.AddMeanScaleValues.AddMeanScaleValues'>
[ INFO ]  New subclass: <class 'extensions.middle.AnchorToPriorBox.AnchorToPriorBoxes'>
[ INFO ]  New subclass: <class 'extensions.middle.LayoutChangeForConstantShapePaths.LayoutChangeForConstantShapePaths'>
[ INFO ]  New subclass: <class 'extensions.middle.ApplyNHWCtoNCHWpermutation.ApplyNHWCtoNCHWpermutation'>
[ INFO ]  New subclass: <class 'extensions.middle.ApplyPermutations.ApplyPermutation'>
[ INFO ]  New subclass: <class 'extensions.middle.ArgMaxToTopK.ArgMaxToTopK'>
[ INFO ]  New subclass: <class 'extensions.middle.AttributedTileNormalizer.AttributedTileNormalizer'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseChecker.EltwiseChecker'>
[ INFO ]  New subclass: <class 'extensions.middle.BiasAddBroadcasting.BiasAddInputBroadcasting'>
[ INFO ]  New subclass: <class 'extensions.middle.CheckForCycle.CheckForCycle'>
[ INFO ]  New subclass: <class 'extensions.middle.DeleteNotExecutable.DeleteNotExecutable'>
[ INFO ]  New subclass: <class 'extensions.middle.BinarizeWeightsM1P1.BinarizeWeightsM1P1'>
[ INFO ]  New subclass: <class 'extensions.middle.BlockLSTMtoLSTMSequence.BlockLSTMtoLSTMSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputReshape.Eltwise1DInputReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputReshape.EltwiseInputReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputNormalization.EltwiseInputNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.FuseReshapesSequence.FuseReshapesSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveRedundantReshapes.RemoveRedundantReshapes'>
[ INFO ]  New subclass: <class 'extensions.middle.DeleteControlFlowEdges.DeleteControlFlowEdges'>
[ INFO ]  New subclass: <class 'extensions.middle.quantize_fuses.MarkNodesToFuseUpToFakeQuantize'>
[ INFO ]  New subclass: <class 'extensions.middle.quantize_fuses.FakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.fusings.Fusing'>
[ INFO ]  New subclass: <class 'extensions.middle.ConcatOptimization.ConcatOptimization'>
[ INFO ]  New subclass: <class 'extensions.middle.ConstSwitchResolver.ConstSwitchEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvToBinaryConv.ConvToBinaryConv'>
[ INFO ]  New subclass: <class 'extensions.middle.SliceConverter.ConvertSlice'>
[ INFO ]  Registered a new subclass with key: Slice
[ INFO ]  New subclass: <class 'extensions.middle.ConvertGroupedStridedSlice.ConvertGroupedStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertLayoutDependentOperations.ConvertLayoutDependentOperations'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertMultiInputConv.ConvertMultiInputConv'>
[ INFO ]  New subclass: <class 'extensions.middle.CustomSubgraphCall.CustomSubgraphCall'>
[ INFO ]  New subclass: <class 'extensions.middle.DecomposeBias.DecomposeBias'>
[ INFO ]  New subclass: <class 'extensions.middle.DecomposeBidirectionalRNNSequence.DecomposeBidirectionalRNNSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.Deconvolution3rdInputNormalization.Deconvolution3rdInputNormalization'>
[ INFO ]  New subclass: <class 'extensions.middle.DepthToSpace.DepthToSpace'>
[ INFO ]  New subclass: <class 'extensions.middle.DilatedConvolution.DilatedConvolutionConverter'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorMerge.TensorIteratorMerge'>
[ INFO ]  New subclass: <class 'extensions.middle.FakeSplitOutputs.AddFakeOutputsToSplit'>
[ INFO ]  New subclass: <class 'extensions.middle.FakeSplitOutputs.AddFakeOutputsToVariadicSplit'>
[ INFO ]  New subclass: <class 'extensions.middle.FusedBatchNormNonConstant.FusedBatchNormNonConstant'>
[ INFO ]  New subclass: <class 'extensions.middle.FusedBatchNormTraining.FusedBatchNormTraining'>
[ INFO ]  New subclass: <class 'extensions.middle.GRURNNSequenceToTensorIterator.GRUAndRNNToTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.middle.GatherNdNormalizer.GatherNdNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.GroupNorm.GroupNormToMVN'>
[ INFO ]  Registered a new subclass with key: GroupNorm
[ INFO ]  New subclass: <class 'extensions.middle.InputCut.MiddleInputCut'>
[ INFO ]  New subclass: <class 'extensions.middle.InsertSelect.AddSelectBeforeMemoryNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.L2NormToNorm.L2NormToNorm'>
[ INFO ]  New subclass: <class 'extensions.middle.RNNSequenceNormalizeToIE.RNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.LSTMRNNSequenceToTensorIterator.LSTMToTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.middle.LeakyReluPattern.LeakyReLU'>
[ INFO ]  New subclass: <class 'extensions.middle.MXNetRNNSequenceNormalize.MXNetRNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.MXNetSplitMultiLayers.MXNetSplitLayersToRNNSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.MXRepeatReplacer.MXRepeatReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.MXTileReplacer.MXTileReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.MinimumMiddleReplacer.MinimumMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.MulAddToSS.MulAddToSS'>
[ INFO ]  New subclass: <class 'extensions.middle.NasNet.NasNet'>
[ INFO ]  New subclass: <class 'extensions.middle.NormalizePad.NormalizePad'>
[ INFO ]  New subclass: <class 'extensions.middle.ONNXRNNSequenceNormalize.ONNXRNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.PartialInfer.PartialInfer'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ReluFakeQuantizeMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ClampQuantizeMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ReluQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveDuplicationMemory.RemoveMemoryDuplicationPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveDuplicationMemory.MergeNeighborSplicePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveIdentity'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveDropout'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveNodesWithZeroPhase'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveRedundantReshapeAfterCropAndResize.RemoveRedundantReshapeAfterCropAndResize'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveUselessConcatSplit.RemoveUselessConcatSplitPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveUselessCrops.RemoveUselessCropsPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetWithMemoryNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplacePNorm.ReplacePNormNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceSpliceNodePattern.ReplaceSpliceNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReverseTransposeNormalization.ReverseTransposeNormalization'>
[ INFO ]  New subclass: <class 'extensions.middle.ReverseV2ToReverseSequence.ReverseToReverseSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.ScaleInput.ScaleInput'>
[ INFO ]  New subclass: <class 'extensions.middle.SharedWeightsDuplication.SharedWeightsDuplication'>
[ INFO ]  New subclass: <class 'extensions.middle.ShuffleChannel.ShuffleChannel'>
[ INFO ]  New subclass: <class 'extensions.middle.SwapAxesMiddleReplacer.SwapAxisMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.TF_lstm_cell_to_generic.TensorFlowLSTMtoGeneric'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorBackEdge.BackEdgesMatching'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorConditionChecker.ConditionChecks'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.SmartInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.SimpleInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.BackEdgeSimpleInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorLSTMToLSTMSequence.TensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorOutput.SmartOutputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorOutput.SimpleOutputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.UpsampleToResample.UpsampleToResample'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessMerge.UselessMergeEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessSplitEraser.UselessSplitEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessStridedSlice.UselessStridedSliceEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.permute_tensor_iterator.TransposeTensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.preprocessing.Preprocessing'>
[ INFO ]  New subclass: <class 'extensions.middle.preprocessing.CaffeMeanFileProcessing'>
[ INFO ]  New subclass: <class 'extensions.middle.reverse_tensor_iterator.ReverseTensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.space_to_depth.SpaceToDepth'>
[ INFO ]  New subclass: <class 'extensions.middle.sparse_reshape.SparseReshapeMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.ssd_anchors_to_const.SsdAnchorsMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.wights_permute_normalizer.WeightsPermuteNormalizer'>
[ WARNING ]  Skipped <class 'extensions.back.pass_separator.BackStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.pass_separator.BackFinish'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.SpecialNodesFinalization.RemoveConstOps'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.SpecialNodesFinalization.CreateConstNodesReplacement'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.SpecialNodesFinalization.RemoveOutputOps'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.SpecialNodesFinalization.NormalizeTI'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.RemoveUselessConvert.RemoveUselessConvert'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.op_versioning.OpVersioning'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.back.split_normalizer.SplitNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.split_normalizer.VariadicSplitNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.split_normalizer.PassVariadicSplitAsIs'>
[ INFO ]  New subclass: <class 'extensions.back.ReverseInputChannels.InsertReverseChannels'>
[ INFO ]  New subclass: <class 'extensions.back.ReverseInputChannels.ReverseChannelsPropagationDown'>
[ INFO ]  New subclass: <class 'extensions.back.ReverseInputChannels.ReverseChannelsPropagationUp'>
[ INFO ]  New subclass: <class 'extensions.back.ReverseInputChannels.DecomposeReverseChannels'>
[ INFO ]  New subclass: <class 'extensions.back.ReverseInputChannels.ApplyReverseChannels'>
[ INFO ]  New subclass: <class 'extensions.back.ActivationsNormalizer.ActivationsNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.AvgPool.AvgPool'>
[ INFO ]  New subclass: <class 'extensions.back.ForceStrictPrecision.ForceStrictPrecision'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.ReshapeMutation'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.DisableReshapeMutationInTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.ConvolutionNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.ConvolutionReshaper'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.ConvolutionWithGroupsResolver'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.PullReshapeThroughFQ'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.DeconvolutionNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.CropToStridedSlice.CropToStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.back.ParameterToPlaceholder.ParameterToInput'>
[ INFO ]  New subclass: <class 'extensions.back.CutMemory.CutMemory'>
[ INFO ]  New subclass: <class 'extensions.back.DumpFakeQuantStat.DumpFakeQuantStat'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.SimpleEltwiseToEltwiseOp'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.DivideToEltwises'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.SubtractToEltwises'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.EltwisesWithScalarInputToPower'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.AddPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.EnableConstantStridedSlice.EnableConstantStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.back.FuseTransposesSequence.FuseTransposesSequence'>
[ INFO ]  New subclass: <class 'extensions.back.GatherNormalizer.Gather0D'>
[ INFO ]  New subclass: <class 'extensions.back.GatherNormalizer.GatherNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.GatherNormalizer.GatherTreeNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.GroupedConvWeightsNormalize.GroupedConvWeightsNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.I64ToI32.I64ToI32'>
[ INFO ]  New subclass: <class 'extensions.back.ShapeOfToShape.ShapeOfToShape'>
[ INFO ]  New subclass: <class 'extensions.back.InterpolateToInterpOrResample.InterpolateToInterpOrResample'>
[ INFO ]  New subclass: <class 'extensions.back.LRNToNorm.LRN_normalization'>
[ INFO ]  New subclass: <class 'extensions.back.LSTMCellNormalizer.LSTMCellNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.LeakyReLUMutation.LeakyReLUMutation'>
[ INFO ]  New subclass: <class 'extensions.back.LeakyReluToReluWithNegativeSlope.LeakyReluToReluWithNegativeSlope'>
[ INFO ]  New subclass: <class 'extensions.back.OptimizeTransposeReshapeSequence.OptimizeTransposeReshapeSequence'>
[ INFO ]  New subclass: <class 'extensions.back.TransposeToPermute.TransposeToPermute'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.MatMulConstTransposesExtraction'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.MatMulToFullyConnected'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.SSBiasAddonForFC'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.BiasAddonForFC'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.FullyConnectedFinalization'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.PullTransposeThroughFQUp'>
[ INFO ]  New subclass: <class 'extensions.back.MaxPool.MaxPool'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.ScalarNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.ScalarNormalizeForSpecificOps'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.RangeInputNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.NonMaximumSuppressionNormalize.NonMaximumSuppressionNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.insert_compatibility_l2normalization.CompatibilityL2NormalizationPattern'>
[ INFO ]  New subclass: <class 'extensions.back.NormalizeToNormalizeL2.NormalizeToNormalizeL2'>
[ INFO ]  New subclass: <class 'extensions.back.OneHotNormalizer.OneHotNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.PackBinaryWeights.PackBinaryWeights'>
[ INFO ]  New subclass: <class 'extensions.back.PadNormalizer.PadNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.StridedSliceMasksNormalizer.StridedSliceMasksNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.ProposalMutation.ProposalMutation'>
[ INFO ]  New subclass: <class 'extensions.back.RNNSequenceTypeRename.RNNSequence'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceToPooling.ReduceReplacer'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceToPooling.ReduceLogicalReplacer'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceTransposeDimensions.ReduceTransposeDimensions'>
[ INFO ]  New subclass: <class 'extensions.back.Reshape0DToSqueeze.Reshape0DToSqueeze'>
[ INFO ]  New subclass: <class 'extensions.back.ResultNormalizer.ResultNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.SelectBroadcast.SelectBroadcast'>
[ INFO ]  New subclass: <class 'extensions.back.ShuffleChannelPatternOptimization.ShuffleChannelPatternOptimization'>
[ INFO ]  New subclass: <class 'extensions.back.ShufflenetReLUReorder.ShufflenetReLUReorder'>
[ INFO ]  New subclass: <class 'extensions.back.TileNormalizer.TileInputAlignment'>
[ INFO ]  New subclass: <class 'extensions.back.TileNormalizer.Tile3DReshaper'>
[ INFO ]  New subclass: <class 'extensions.back.TileNormalizer.TileMultipleAxisReplacer'>
[ INFO ]  New subclass: <class 'extensions.back.TileNormalizer.TileVersionDowngrader'>
[ INFO ]  New subclass: <class 'extensions.back.TopKNormalizer.TopKNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.UselessConcatRemoval.UselessConcatRemoval'>
[ INFO ]  New subclass: <class 'extensions.back.blob_normalizer.BlobNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.disable_unsupported_ND_operations.DisableUnsupportedNDOperations'>
[ INFO ]  New subclass: <class 'extensions.back.fuse_sub_div_min.Negate'>
[ INFO ]  New subclass: <class 'extensions.back.fuse_sub_div_min.EltwisesToSubtract'>
[ INFO ]  New subclass: <class 'extensions.back.fuse_sub_div_min.EltwisesToDiv'>
[ INFO ]  New subclass: <class 'extensions.back.kaldi_remove_memory_output.KaldiRemoveMemoryOutputBackReplacementPattern'>
[ INFO ]  New subclass: <class 'extensions.back.priorbox_mutation.PriorboxMutation'>
[ INFO ]  New subclass: <class 'extensions.back.remove_last_softmax_pattern.RemoveLastSoftMaxPattern'>
[ INFO ]  New subclass: <class 'extensions.back.remove_last_softmax_pattern.RemoveLastLogSoftMaxPattern'>
[ 2020-05-06 17:08:38,635 ] [ DEBUG ] [ class_registration:48 ]  All replacers has unique idxs.
[ 2020-05-06 17:08:38,984 ] [ DEBUG ] [ tf:72 ]  Number of nodes in graph_def: 2771
[ 2020-05-06 17:08:38,984 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry StridedSlice to extractors with custom extractor class <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'>.
[ 2020-05-06 17:08:38,985 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry BatchMatMul to extractors with custom extractor class <class 'extensions.front.tf.BatchMatMul_ext.BatchMatMulExtractor'>.
[ 2020-05-06 17:08:38,985 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry BatchMatMulV2 to extractors with custom extractor class <class 'extensions.front.tf.BatchMatMul_ext.BatchMatMulV2Extractor'>.
[ 2020-05-06 17:08:38,986 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry BlockLSTM to extractors with custom extractor class <class 'extensions.front.tf.BlockLSTM_ext.BlockLSTMExtractor'>.
[ 2020-05-06 17:08:38,986 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry CTCGreedyDecoder to extractors with custom extractor class <class 'extensions.front.tf.CTCGreedyDecoder_ext.CTCCGreedyDecoderFrontExtractor'>.
[ 2020-05-06 17:08:38,987 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Cast to extractors with custom extractor class <class 'extensions.front.tf.Cast_ext.CastFrontExtractor'>.
[ 2020-05-06 17:08:38,987 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry FakeQuantWithMinMaxVars to extractors with custom extractor class <class 'extensions.front.tf.FakeQuantWithMinMaxVars_ext.FakeQuantWithMinMaxVarsExtractor'>.
[ 2020-05-06 17:08:38,989 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry GatherTree to extractors with custom extractor class <class 'extensions.front.tf.GatherTree_ext.GatherTreeFrontExtractor'>.
[ 2020-05-06 17:08:38,989 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LoopCond to extractors with custom extractor class <class 'extensions.front.tf.LoopCond_ext.LoopCondFrontExtractor'>.
[ 2020-05-06 17:08:38,989 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry TensorArrayV3 to extractors with custom extractor class <class 'extensions.front.tf.TensorArrayExtractors.TensorArrayExtractor'>.
[ 2020-05-06 17:08:38,990 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry TensorArrayGatherV3 to extractors with custom extractor class <class 'extensions.front.tf.TensorArrayGatherV3.TensorArrayGatherV3Exteractor'>.
[ 2020-05-06 17:08:38,990 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Abs to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.AbsExtractor'>.
[ 2020-05-06 17:08:38,990 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Elu to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.EluFrontExtractor'>.
[ 2020-05-06 17:08:38,990 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Erf to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.ErfFrontExtractor'>.
[ 2020-05-06 17:08:38,991 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Exp to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.ExpExtractor'>.
[ 2020-05-06 17:08:38,991 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LeakyRelu to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.LeakyReLUFrontExtractor'>.
[ 2020-05-06 17:08:38,991 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LogicalNot to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.LogicalNotFrontExtractor'>.
[ 2020-05-06 17:08:38,992 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Relu6 to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.Relu6FrontExtractor'>.
[ 2020-05-06 17:08:38,992 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Relu to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.ReluFrontExtractor'>.
[ 2020-05-06 17:08:38,992 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sigmoid to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.SigmoidFrontExtractor'>.
[ 2020-05-06 17:08:38,992 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Cos to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.CosFrontExtractor'>.
[ 2020-05-06 17:08:38,993 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Cosh to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.CoshFrontExtractor'>.
[ 2020-05-06 17:08:38,993 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sin to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.SinFrontExtractor'>.
[ 2020-05-06 17:08:38,993 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sinh to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.SinhFrontExtractor'>.
[ 2020-05-06 17:08:38,994 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Tan to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.TanFrontExtractor'>.
[ 2020-05-06 17:08:38,995 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Tanh to extractors with custom extractor class <class 'extensions.front.tf.activation_ext.TanhFrontExtractor'>.
[ 2020-05-06 17:08:38,996 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ArgMax to extractors with custom extractor class <class 'extensions.front.tf.argmax_ext.ArgMaxFrontExtractor'>.
[ 2020-05-06 17:08:38,996 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Bucketize to extractors with custom extractor class <class 'extensions.front.tf.bucketize_ext.BucketizeFrontExtractor'>.
[ 2020-05-06 17:08:38,996 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Concat to extractors with custom extractor class <class 'extensions.front.tf.concat_ext.ConcatFrontExtractor'>.
[ 2020-05-06 17:08:38,997 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Const to extractors with custom extractor class <class 'extensions.front.tf.const_ext.ConstExtractor'>.
[ 2020-05-06 17:08:38,997 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Conv2D to extractors with custom extractor class <class 'extensions.front.tf.conv_ext.Conv2DFrontExtractor'>.
[ 2020-05-06 17:08:38,997 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry DepthwiseConv2dNative to extractors with custom extractor class <class 'extensions.front.tf.conv_ext.DepthwiseConv2dNativeFrontExtractor'>.
[ 2020-05-06 17:08:38,997 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Conv3D to extractors with custom extractor class <class 'extensions.front.tf.conv_ext.Conv3DFrontExtractor'>.
[ 2020-05-06 17:08:38,998 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry CropAndResize to extractors with custom extractor class <class 'extensions.front.tf.crop_and_resize_ext.CropAndResizeFrontExtractor'>.
[ 2020-05-06 17:08:38,998 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Conv2DBackpropInput to extractors with custom extractor class <class 'extensions.front.tf.deconv_ext.Conv2DBackpropInputFrontExtractor'>.
[ 2020-05-06 17:08:38,998 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Conv3DBackpropInputV2 to extractors with custom extractor class <class 'extensions.front.tf.deconv_ext.Conv3DBackpropInputV2InputFrontExtractor'>.
[ 2020-05-06 17:08:38,998 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry DepthToSpace to extractors with custom extractor class <class 'extensions.front.tf.depth_to_space.DepthToSpaceFrontExtractor'>.
[ 2020-05-06 17:08:38,999 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Add to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.AddExtractor'>.
[ 2020-05-06 17:08:38,999 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry AddV2 to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.AddV2Extractor'>.
[ 2020-05-06 17:08:38,999 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry AddN to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.AddNExtractor'>.
[ 2020-05-06 17:08:39,000 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry BiasAdd to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.BiasAddExtractor'>.
[ 2020-05-06 17:08:39,000 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Mul to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.MulExtractor'>.
[ 2020-05-06 17:08:39,000 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sub to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.SubExtractor'>.
[ 2020-05-06 17:08:39,000 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry RealDiv to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.DivExtractor'>.
[ 2020-05-06 17:08:39,001 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SquaredDifference to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.SquaredDifferenceExtractor'>.
[ 2020-05-06 17:08:39,001 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sqrt to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.SqrtExtractor'>.
[ 2020-05-06 17:08:39,001 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Rsqrt to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.RsqrtExtractor'>.
[ 2020-05-06 17:08:39,001 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Square to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.SquareExtractor'>.
[ 2020-05-06 17:08:39,002 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Neg to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.NegExtractor'>.
[ 2020-05-06 17:08:39,002 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ZerosLike to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.ZerosLike'>.
[ 2020-05-06 17:08:39,002 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Maximum to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.MaximumExtractor'>.
[ 2020-05-06 17:08:39,002 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Minimum to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.MinimumExtractor'>.
[ 2020-05-06 17:08:39,003 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Pow to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.PowExtractor'>.
[ 2020-05-06 17:08:39,004 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LogicalAnd to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.LogicalAndFrontExtractor'>.
[ 2020-05-06 17:08:39,005 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LogicalOr to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.LogicalOrFrontExtractor'>.
[ 2020-05-06 17:08:39,005 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Equal to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.EqualExtractor'>.
[ 2020-05-06 17:08:39,006 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LessEqual to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.LessEqualExtractor'>.
[ 2020-05-06 17:08:39,006 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Less to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.LessExtractor'>.
[ 2020-05-06 17:08:39,006 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Greater to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.GreaterExtractor'>.
[ 2020-05-06 17:08:39,007 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry GreaterEqual to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.GreaterEqualExtractor'>.
[ 2020-05-06 17:08:39,007 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry NotEqual to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.NotEqualExtractor'>.
[ 2020-05-06 17:08:39,007 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry FloorMod to extractors with custom extractor class <class 'extensions.front.tf.elementwise_ext.FloorModFrontExtractor'>.
[ 2020-05-06 17:08:39,008 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ExpandDims to extractors with custom extractor class <class 'extensions.front.tf.expand_dims_ext.ExpandDimsExtractor'>.
[ 2020-05-06 17:08:39,008 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ExtractImagePatches to extractors with custom extractor class <class 'extensions.front.tf.extract_image_patches_ext.ExtractImagePatchesExtractor'>.
[ 2020-05-06 17:08:39,008 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry FIFOQueueV2 to extractors with custom extractor class <class 'extensions.front.tf.fifo_queue_v2_ext.FIFOQueueV2Extractor'>.
[ 2020-05-06 17:08:39,009 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Fill to extractors with custom extractor class <class 'extensions.front.tf.fill_ext.FillExtractor'>.
[ 2020-05-06 17:08:39,009 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Gather to extractors with custom extractor class <class 'extensions.front.tf.gather_ext.GatherFrontExtractor'>.
[ 2020-05-06 17:08:39,009 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ResourceGather to extractors with custom extractor class <class 'extensions.front.tf.gather_ext.ResourceGatherFrontExtractor'>.
[ 2020-05-06 17:08:39,009 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry GatherV2 to extractors with custom extractor class <class 'extensions.front.tf.gather_ext.GatherV2FrontExtractor'>.
[ 2020-05-06 17:08:39,010 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Identity to extractors with custom extractor class <class 'extensions.front.tf.identity_ext.IdentityFrontExtractor'>.
[ 2020-05-06 17:08:39,010 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ReadVariableOp to extractors with custom extractor class <class 'extensions.front.tf.identity_ext.ReadVariableOpFrontExtractor'>.
[ 2020-05-06 17:08:39,010 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry StopGradient to extractors with custom extractor class <class 'extensions.front.tf.identity_ext.StopGradientExtractor'>.
[ 2020-05-06 17:08:39,010 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry LRN to extractors with custom extractor class <class 'extensions.front.tf.lrn_ext.LRNExtractor'>.
[ 2020-05-06 17:08:39,011 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry MatMul to extractors with custom extractor class <class 'extensions.front.tf.matmul_ext.MatMulExtractor'>.
[ 2020-05-06 17:08:39,011 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry NextIteration to extractors with custom extractor class <class 'extensions.front.tf.next_iteration_ext.NextIterationExtractor'>.
[ 2020-05-06 17:08:39,011 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry NonMaxSuppressionV3 to extractors with custom extractor class <class 'extensions.front.tf.non_max_suppression_ext.NonMaxSuppressionV3Extractor'>.
[ 2020-05-06 17:08:39,012 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry NonMaxSuppressionV4 to extractors with custom extractor class <class 'extensions.front.tf.non_max_suppression_ext.NonMaxSuppressionV4Extractor'>.
[ 2020-05-06 17:08:39,012 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry NonMaxSuppressionV5 to extractors with custom extractor class <class 'extensions.front.tf.non_max_suppression_ext.NonMaxSuppressionV5Extractor'>.
[ 2020-05-06 17:08:39,012 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry OneHot to extractors with custom extractor class <class 'extensions.front.tf.one_hot_ext.OneHotFrontExtractor'>.
[ 2020-05-06 17:08:39,013 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Pad to extractors with custom extractor class <class 'extensions.front.tf.pad_ext.PadFrontExtractor'>.
[ 2020-05-06 17:08:39,013 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry PadV2 to extractors with custom extractor class <class 'extensions.front.tf.pad_ext.PadV2FrontExtractor'>.
[ 2020-05-06 17:08:39,013 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry MirrorPad to extractors with custom extractor class <class 'extensions.front.tf.pad_ext.MirrorPadFrontExtractor'>.
[ 2020-05-06 17:08:39,013 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Placeholder to extractors with custom extractor class <class 'extensions.front.tf.placeholder_ext.PlaceholderFrontExtractor'>.
[ 2020-05-06 17:08:39,014 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry PlaceholderWithDefault to extractors with custom extractor class <class 'extensions.front.tf.placeholder_with_default_ext.PlaceholderWithDefaultExtractor'>.
[ 2020-05-06 17:08:39,015 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry AvgPool to extractors with custom extractor class <class 'extensions.front.tf.pooling_ext.AvgPoolFrontExtractor'>.
[ 2020-05-06 17:08:39,016 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry MaxPool to extractors with custom extractor class <class 'extensions.front.tf.pooling_ext.MaxPoolFrontExtractor'>.
[ 2020-05-06 17:08:39,016 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry MaxPool3D to extractors with custom extractor class <class 'extensions.front.tf.pooling_ext.MaxPool3DFrontExtractor'>.
[ 2020-05-06 17:08:39,017 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry AvgPool3D to extractors with custom extractor class <class 'extensions.front.tf.pooling_ext.AvgPool3DFrontExtractor'>.
[ 2020-05-06 17:08:39,017 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry All to extractors with custom extractor class <class 'extensions.front.tf.reduce_ext.AllFrontExtractor'>.
[ 2020-05-06 17:08:39,017 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Max to extractors with custom extractor class <class 'extensions.front.tf.reduce_ext.MaxFrontExtractor'>.
[ 2020-05-06 17:08:39,017 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Mean to extractors with custom extractor class <class 'extensions.front.tf.reduce_ext.MeanExtractor'>.
[ 2020-05-06 17:08:39,018 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Prod to extractors with custom extractor class <class 'extensions.front.tf.reduce_ext.ProdFrontExtractor'>.
[ 2020-05-06 17:08:39,018 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sum to extractors with custom extractor class <class 'extensions.front.tf.reduce_ext.SumFrontExtractor'>.
[ 2020-05-06 17:08:39,018 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Rank to extractors with custom extractor class <class 'extensions.front.tf.reshape_related_ext.RankFrontExtractor'>.
[ 2020-05-06 17:08:39,019 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Reshape to extractors with custom extractor class <class 'extensions.front.tf.reshape_related_ext.ReshapeExtractor'>.
[ 2020-05-06 17:08:39,019 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Shape to extractors with custom extractor class <class 'extensions.front.tf.reshape_related_ext.ShapeExtractor'>.
[ 2020-05-06 17:08:39,019 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Size to extractors with custom extractor class <class 'extensions.front.tf.reshape_related_ext.SizeFrontExtractor'>.
[ 2020-05-06 17:08:39,020 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Squeeze to extractors with custom extractor class <class 'extensions.front.tf.reshape_related_ext.SqueezeExtractor'>.
[ 2020-05-06 17:08:39,020 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ResizeBilinear to extractors with custom extractor class <class 'extensions.front.tf.resize_bilinear.ResizeBilinearFrontExtractor'>.
[ 2020-05-06 17:08:39,020 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ResizeNearestNeighbor to extractors with custom extractor class <class 'extensions.front.tf.resize_nearest_neighbor.ResizeNearestNeighborFrontExtractor'>.
[ 2020-05-06 17:08:39,020 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ReverseSequence to extractors with custom extractor class <class 'extensions.front.tf.reverse_sequence.ReverseSequenceFrontExtractor'>.
[ 2020-05-06 17:08:39,021 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry ReverseV2 to extractors with custom extractor class <class 'extensions.front.tf.reverse_v2.ReverseV2FrontExtractor'>.
[ 2020-05-06 17:08:39,021 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Select to extractors with custom extractor class <class 'extensions.front.tf.select_ext.SelectExtractor'>.
[ 2020-05-06 17:08:39,021 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Sign to extractors with custom extractor class <class 'extensions.front.tf.sign_ext.SignExtractor'>.
[ 2020-05-06 17:08:39,021 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Slice to extractors with custom extractor class <class 'extensions.front.tf.slice_ext.SliceExtractor'>.
[ 2020-05-06 17:08:39,022 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Softmax to extractors with custom extractor class <class 'extensions.front.tf.softmax_ext.SoftmaxFrontExtractor'>.
[ 2020-05-06 17:08:39,022 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SpaceToDepth to extractors with custom extractor class <class 'extensions.front.tf.space_to_depth_ext.SpaceToDepthFrontExtractor'>.
[ 2020-05-06 17:08:39,022 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SparseFillEmptyRows to extractors with custom extractor class <class 'extensions.front.tf.sparse_fill_empty_rows_ext.SparseFillEmptyRowsFrontExtractor'>.
[ 2020-05-06 17:08:39,023 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SparseSegmentMean to extractors with custom extractor class <class 'extensions.front.tf.sparse_segment_mean_ext.SparseSegmentMeanFrontExtractor'>.
[ 2020-05-06 17:08:39,023 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SparseSegmentSqrtN to extractors with custom extractor class <class 'extensions.front.tf.sparse_segment_sqrtn_ext.SparseSegmentSqrtNFrontExtractor'>.
[ 2020-05-06 17:08:39,023 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SparseSegmentSum to extractors with custom extractor class <class 'extensions.front.tf.sparse_segment_sum_ext.SparseSegmentSumFrontExtractor'>.
[ 2020-05-06 17:08:39,024 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SparseToDense to extractors with custom extractor class <class 'extensions.front.tf.sparse_to_dense_ext.SparseToDenseFrontExtractor'>.
[ 2020-05-06 17:08:39,025 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry SplitV to extractors with custom extractor class <class 'extensions.front.tf.split_ext.SplitVExtractor'>.
[ 2020-05-06 17:08:39,025 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Unpack to extractors with custom extractor class <class 'extensions.front.tf.split_ext.UnpackExtractor'>.
[ 2020-05-06 17:08:39,026 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Split to extractors with custom extractor class <class 'extensions.front.tf.split_ext.SplitExtractor'>.
[ 2020-05-06 17:08:39,026 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Tile to extractors with custom extractor class <class 'extensions.front.tf.tile_ext.TileExtractor'>.
[ 2020-05-06 17:08:39,026 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry TopK to extractors with custom extractor class <class 'extensions.front.tf.topk_ext.TopKExtractor'>.
[ 2020-05-06 17:08:39,027 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry TopKV2 to extractors with custom extractor class <class 'extensions.front.tf.topk_ext.TopKV2Extractor'>.
[ 2020-05-06 17:08:39,027 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Transpose to extractors with custom extractor class <class 'extensions.front.tf.transpose_ext.TransposeFrontExtractorTF'>.
[ 2020-05-06 17:08:39,027 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Unique to extractors with custom extractor class <class 'extensions.front.tf.unique_ext.UniqueFrontExtractor'>.
[ 2020-05-06 17:08:39,027 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry Variable to extractors with custom extractor class <class 'extensions.front.tf.variable_ext.VariableExtractor'>.
[ 2020-05-06 17:08:39,028 ] [ DEBUG ] [ register_custom_ops:74 ]  Added a new entry VariableV2 to extractors with custom extractor class <class 'extensions.front.tf.variable_ext.VariableV2Extractor'>.
[ 2020-05-06 17:08:39,028 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry AttributedGather to extractors with custom op class <class 'extensions.ops.gather.AttributedGather'>.
[ 2020-05-06 17:08:39,028 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Parameter to extractors with custom op class <class 'extensions.ops.parameter.Parameter'>.
[ 2020-05-06 17:08:39,028 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorIterator to extractors with custom op class <class 'extensions.ops.tensor_iterator.TensorIterator'>.
[ 2020-05-06 17:08:39,029 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Clamp to extractors with custom op class <class 'mo.ops.clamp.Clamp'>.
[ 2020-05-06 17:08:39,029 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Convolution to extractors with custom op class <class 'mo.ops.convolution.Convolution'>.
[ 2020-05-06 17:08:39,029 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Crop to extractors with custom op class <class 'mo.ops.crop.Crop'>.
[ 2020-05-06 17:08:39,029 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Activation to extractors with custom op class <class 'mo.ops.activation.Activation'>.
[ 2020-05-06 17:08:39,030 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Broadcast to extractors with custom op class <class 'mo.ops.broadcast.Broadcast'>.
[ 2020-05-06 17:08:39,030 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ConstantOfShape to extractors with custom op class <class 'mo.ops.constant_of_shape.ConstantOfShape'>.
[ 2020-05-06 17:08:39,030 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Deconvolution to extractors with custom op class <class 'mo.ops.deconvolution.Deconvolution'>.
[ 2020-05-06 17:08:39,030 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry DeformableConvolution to extractors with custom op class <class 'mo.ops.deformable_convolution.DeformableConvolution'>.
[ 2020-05-06 17:08:39,031 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Eltwise to extractors with custom op class <class 'mo.ops.eltwise.Eltwise'>.
[ 2020-05-06 17:08:39,031 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry EltwiseN to extractors with custom op class <class 'mo.ops.eltwise_n.EltwiseN'>.
[ 2020-05-06 17:08:39,031 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry EltwiseNin1 to extractors with custom op class <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'>.
[ 2020-05-06 17:08:39,031 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Flatten to extractors with custom op class <class 'mo.ops.flatten.Flatten'>.
[ 2020-05-06 17:08:39,032 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry FlattenONNX to extractors with custom op class <class 'mo.ops.flatten.FlattenONNX'>.
[ 2020-05-06 17:08:39,032 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry GroupNorm to extractors with custom op class <class 'mo.ops.group_norm.GroupNorm'>.
[ 2020-05-06 17:08:39,032 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry AttributedLRN to extractors with custom op class <class 'mo.ops.lrn.AttributedLRN'>.
[ 2020-05-06 17:08:39,032 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry LstmNonLinearity to extractors with custom op class <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'>.
[ 2020-05-06 17:08:39,033 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Memory to extractors with custom op class <class 'mo.ops.memory.Memory'>.
[ 2020-05-06 17:08:39,033 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry MemoryOffset to extractors with custom op class <class 'mo.ops.memoryoffset.MemoryOffset'>.
[ 2020-05-06 17:08:39,033 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Permute to extractors with custom op class <class 'mo.ops.permute.Permute'>.
[ 2020-05-06 17:08:39,033 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Pooling to extractors with custom op class <class 'mo.ops.pooling.Pooling'>.
[ 2020-05-06 17:08:39,034 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry AttributedPower to extractors with custom op class <class 'mo.ops.power.AttributedPower'>.
[ 2020-05-06 17:08:39,035 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Result to extractors with custom op class <class 'mo.ops.result.Result'>.
[ 2020-05-06 17:08:39,035 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ROIPooling to extractors with custom op class <class 'mo.ops.roipooling.ROIPooling'>.
[ 2020-05-06 17:08:39,036 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ScaleShift to extractors with custom op class <class 'mo.ops.scale_shift.ScaleShiftOp'>.
[ 2020-05-06 17:08:39,036 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ShapeOf to extractors with custom op class <class 'mo.ops.shape.Shape'>.
[ 2020-05-06 17:08:39,036 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry AttributedTile to extractors with custom op class <class 'mo.ops.tile.AttributedTile'>.
[ 2020-05-06 17:08:39,037 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Unsqueeze to extractors with custom op class <class 'mo.ops.unsqueeze.Unsqueeze'>.
[ 2020-05-06 17:08:39,037 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry DetectionOutput to extractors with custom op class <class 'extensions.ops.DetectionOutput.DetectionOutput'>.
[ 2020-05-06 17:08:39,038 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Enter to extractors with custom op class <class 'extensions.ops.Enter.Enter'>.
[ 2020-05-06 17:08:39,038 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Exit to extractors with custom op class <class 'extensions.ops.Exit.Exit'>.
[ 2020-05-06 17:08:39,038 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry RNN to extractors with custom op class <class 'extensions.ops.RNN.RNN'>.
[ 2020-05-06 17:08:39,038 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry GRU to extractors with custom op class <class 'extensions.ops.GRU.GRU'>.
[ 2020-05-06 17:08:39,039 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry GRUCell to extractors with custom op class <class 'extensions.ops.GRUCell.GRUCell'>.
[ 2020-05-06 17:08:39,039 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry GatherNd to extractors with custom op class <class 'extensions.ops.GatherNd.GatherNd'>.
[ 2020-05-06 17:08:39,039 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry LSTM to extractors with custom op class <class 'extensions.ops.LSTM.LSTM'>.
[ 2020-05-06 17:08:39,039 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Log to extractors with custom op class <class 'extensions.ops.Log.LogOp'>.
[ 2020-05-06 17:08:39,040 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Gemm to extractors with custom op class <class 'extensions.ops.MatMul.GemmONNX'>.
[ 2020-05-06 17:08:39,040 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry FullyConnected to extractors with custom op class <class 'extensions.ops.MatMul.FullyConnected'>.
[ 2020-05-06 17:08:39,040 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry RNNCell to extractors with custom op class <class 'extensions.ops.RNNCell.RNNCell'>.
[ 2020-05-06 17:08:39,041 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Reverse to extractors with custom op class <class 'extensions.ops.Reverse.Reverse'>.
[ 2020-05-06 17:08:39,041 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorArrayReadV3 to extractors with custom op class <class 'extensions.ops.TensorArrayRead.TensorArrayReader'>.
[ 2020-05-06 17:08:39,041 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorArrayScatterV3 to extractors with custom op class <class 'extensions.ops.TensorArrayScatter.TensorArrayScatter'>.
[ 2020-05-06 17:08:39,041 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorArraySizeV3 to extractors with custom op class <class 'extensions.ops.TensorArraySize.TensorArraySize'>.
[ 2020-05-06 17:08:39,042 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorArrayWriteV3 to extractors with custom op class <class 'extensions.ops.TensorArrayWrite.TensorArrayWriter'>.
[ 2020-05-06 17:08:39,042 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorIteratorInput to extractors with custom op class <class 'extensions.ops.TensorIterator_ops.TensorIteratorInput'>.
[ 2020-05-06 17:08:39,042 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorIteratorOutput to extractors with custom op class <class 'extensions.ops.TensorIterator_ops.TensorIteratorOutput'>.
[ 2020-05-06 17:08:39,042 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorIteratorCondition to extractors with custom op class <class 'extensions.ops.TensorIterator_ops.TensorIteratorCondition'>.
[ 2020-05-06 17:08:39,043 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry TensorIteratorBackEdge to extractors with custom op class <class 'extensions.ops.TensorIterator_ops.TensorIteratorBackEdge'>.
[ 2020-05-06 17:08:39,043 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Accum to extractors with custom op class <class 'extensions.ops.accum.AccumOp'>.
[ 2020-05-06 17:08:39,043 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry AdaptiveAvgPooling to extractors with custom op class <class 'extensions.ops.adaptive_avg_pooling.AdaptiveAvgPooling'>.
[ 2020-05-06 17:08:39,043 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Assert to extractors with custom op class <class 'extensions.ops.assert_op.Assert'>.
[ 2020-05-06 17:08:39,044 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Axpy to extractors with custom op class <class 'extensions.ops.axpy.AxpyOp'>.
[ 2020-05-06 17:08:39,045 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Binarization to extractors with custom op class <class 'extensions.ops.binarization.Binarization'>.
[ 2020-05-06 17:08:39,046 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry BN to extractors with custom op class <class 'extensions.ops.bn.BNOp'>.
[ 2020-05-06 17:08:39,046 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry _contrib_box_nms to extractors with custom op class <class 'extensions.ops.box_nms.BoxNms'>.
[ 2020-05-06 17:08:39,046 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ConstantFill to extractors with custom op class <class 'extensions.ops.constant_fill.ConstantFill'>.
[ 2020-05-06 17:08:39,046 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry copy to extractors with custom op class <class 'extensions.ops.copyop.CopyOp'>.
[ 2020-05-06 17:08:39,047 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Correlation to extractors with custom op class <class 'extensions.ops.correlation.CorrelationOp'>.
[ 2020-05-06 17:08:39,047 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry DataAugmentation to extractors with custom op class <class 'extensions.ops.data_augmentation.DataAugmentationOp'>.
[ 2020-05-06 17:08:39,047 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ExperimentalDetectronDetectionOutput to extractors with custom op class <class 'extensions.ops.detectionoutput_onnx.ExperimentalDetectronDetectionOutput'>.
[ 2020-05-06 17:08:39,047 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry FakeQuantize to extractors with custom op class <class 'extensions.ops.fakequantize.FakeQuantize'>.
[ 2020-05-06 17:08:39,048 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry GRN to extractors with custom op class <class 'extensions.ops.grn.GRNOp'>.
[ 2020-05-06 17:08:39,048 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry HardSigmoid to extractors with custom op class <class 'extensions.ops.hard_sigmoid.HardSigmoid'>.
[ 2020-05-06 17:08:39,048 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry InstanceNormalization to extractors with custom op class <class 'extensions.ops.instance_normalization.InstanceNormalization'>.
[ 2020-05-06 17:08:39,048 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Interp to extractors with custom op class <class 'extensions.ops.interp.InterpOp'>.
[ 2020-05-06 17:08:39,049 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Interpolate to extractors with custom op class <class 'extensions.ops.interpolate.Interpolate'>.
[ 2020-05-06 17:08:39,049 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry LSTMCell to extractors with custom op class <class 'extensions.ops.lstm_cell.LSTMCell'>.
[ 2020-05-06 17:08:39,049 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry LSTMSequence to extractors with custom op class <class 'extensions.ops.lstm_sequence.LSTMSequence'>.
[ 2020-05-06 17:08:39,050 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Merge to extractors with custom op class <class 'extensions.ops.merge.Merge'>.
[ 2020-05-06 17:08:39,050 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry MVN to extractors with custom op class <class 'extensions.ops.mvn.MVN'>.
[ 2020-05-06 17:08:39,050 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry MXRepeat to extractors with custom op class <class 'extensions.ops.mxrepeat.MXRepeat'>.
[ 2020-05-06 17:08:39,050 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry MXSlice to extractors with custom op class <class 'extensions.ops.mxslice.MXSlice'>.
[ 2020-05-06 17:08:39,051 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry NonMaxSuppression to extractors with custom op class <class 'extensions.ops.non_max_suppression.NonMaxSuppression'>.
[ 2020-05-06 17:08:39,051 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry NonZero to extractors with custom op class <class 'extensions.ops.non_zero.NonZero'>.
[ 2020-05-06 17:08:39,051 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Normalize to extractors with custom op class <class 'extensions.ops.normalize.NormalizeOp'>.
[ 2020-05-06 17:08:39,051 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry NormalizeL2 to extractors with custom op class <class 'extensions.ops.normalize_l2.NormalizeL2Op'>.
[ 2020-05-06 17:08:39,052 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry pnorm to extractors with custom op class <class 'extensions.ops.pnorm.PNormOp'>.
[ 2020-05-06 17:08:39,052 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry PowerFile to extractors with custom op class <class 'extensions.ops.power_file.PowerFileOp'>.
[ 2020-05-06 17:08:39,052 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry PredictionHeatmap to extractors with custom op class <class 'extensions.ops.prediction_heatmap.PredictionHeatmapOp'>.
[ 2020-05-06 17:08:39,052 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry PReLU to extractors with custom op class <class 'extensions.ops.prelu.PreluOp'>.
[ 2020-05-06 17:08:39,053 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry PriorBox to extractors with custom op class <class 'extensions.ops.priorbox.PriorBoxOp'>.
[ 2020-05-06 17:08:39,053 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry PriorBoxClustered to extractors with custom op class <class 'extensions.ops.priorbox_clustered.PriorBoxClusteredOp'>.
[ 2020-05-06 17:08:39,054 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ExperimentalDetectronPriorGridGenerator to extractors with custom op class <class 'extensions.ops.priorgridgenerator_onnx.ExperimentalDetectronPriorGridGenerator'>.
[ 2020-05-06 17:08:39,055 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Proposal to extractors with custom op class <class 'extensions.ops.proposal.ProposalOp'>.
[ 2020-05-06 17:08:39,056 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ExperimentalDetectronGenerateProposalsSingleImage to extractors with custom op class <class 'extensions.ops.proposal_onnx.ExperimentalDetectronGenerateProposalsSingleImage'>.
[ 2020-05-06 17:08:39,056 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry PSROIPooling to extractors with custom op class <class 'extensions.ops.psroipooling.PSROIPoolingOp'>.
[ 2020-05-06 17:08:39,056 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Range to extractors with custom op class <class 'extensions.ops.range.Range'>.
[ 2020-05-06 17:08:39,056 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry RegionYolo to extractors with custom op class <class 'extensions.ops.regionyolo.RegionYoloOp'>.
[ 2020-05-06 17:08:39,057 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ReorgYolo to extractors with custom op class <class 'extensions.ops.reorgyolo.ReorgYoloOp'>.
[ 2020-05-06 17:08:39,057 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Resample to extractors with custom op class <class 'extensions.ops.resample.ResampleOp'>.
[ 2020-05-06 17:08:39,057 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Resize to extractors with custom op class <class 'extensions.ops.resize.ResizeOp'>.
[ 2020-05-06 17:08:39,057 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ExperimentalDetectronROIFeatureExtractor to extractors with custom op class <class 'extensions.ops.roifeatureextractor_onnx.ExperimentalDetectronROIFeatureExtractor'>.
[ 2020-05-06 17:08:39,058 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ShuffleChannel to extractors with custom op class <class 'extensions.ops.shufflechannel.ShuffleChannelOp'>.
[ 2020-05-06 17:08:39,058 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry SimplerNMS to extractors with custom op class <class 'extensions.ops.simplernms.SimplerNMSOp'>.
[ 2020-05-06 17:08:39,058 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry SparseReshape to extractors with custom op class <class 'extensions.ops.sparse_reshape.SparseReshape'>.
[ 2020-05-06 17:08:39,058 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ExperimentalSparseWeightedSum to extractors with custom op class <class 'extensions.ops.sparse_weighted_sum.ExperimentalSparseWeightedSum'>.
[ 2020-05-06 17:08:39,059 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry SpatialTransformer to extractors with custom op class <class 'extensions.ops.spatial_transformer.SpatialTransformOp'>.
[ 2020-05-06 17:08:39,059 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Splice to extractors with custom op class <class 'extensions.ops.splice.Splice'>.
[ 2020-05-06 17:08:39,059 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry SwapAxis to extractors with custom op class <class 'extensions.ops.swapaxis.SwapAxis'>.
[ 2020-05-06 17:08:39,060 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Switch to extractors with custom op class <class 'extensions.ops.switch.Switch'>.
[ 2020-05-06 17:08:39,060 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry ExperimentalDetectronTopKROIs to extractors with custom op class <class 'extensions.ops.topkrois_onnx.ExperimentalDetectronTopKROIs'>.
[ 2020-05-06 17:08:39,060 ] [ DEBUG ] [ register_custom_ops:104 ]  Added a new entry Upsample to extractors with custom op class <class 'extensions.ops.upsample.UpsampleOp'>.
[ WARNING ]  Broadcast of scalar to shape: [1]
[ 2020-05-06 17:08:39,195 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,196 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,197 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,201 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,203 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,205 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,207 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,207 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,209 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,209 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,210 ] [ DEBUG ] [ utils:78 ]  value = [0.007843137718737125], shape = [], res = [0.00784314], res.shape = (1,)
[ 2020-05-06 17:08:39,211 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,408 ] [ DEBUG ] [ utils:78 ]  value = [224], shape = [], res = [224], res.shape = (1,)
[ 2020-05-06 17:08:39,409 ] [ DEBUG ] [ utils:78 ]  value = [224], shape = [], res = [224], res.shape = (1,)
[ 2020-05-06 17:08:39,410 ] [ DEBUG ] [ utils:78 ]  value = [14], shape = [], res = [14], res.shape = (1,)
[ 2020-05-06 17:08:39,411 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,412 ] [ DEBUG ] [ utils:78 ]  value = [14], shape = [], res = [14], res.shape = (1,)
[ 2020-05-06 17:08:39,413 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,413 ] [ DEBUG ] [ utils:78 ]  value = [7], shape = [], res = [7], res.shape = (1,)
[ 2020-05-06 17:08:39,414 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,415 ] [ DEBUG ] [ utils:78 ]  value = [7], shape = [], res = [7], res.shape = (1,)
[ 2020-05-06 17:08:39,415 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,416 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:39,416 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,418 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:39,418 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,419 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,420 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,420 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,421 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,422 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,423 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,424 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,425 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,426 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,427 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,427 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,428 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,429 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,430 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,431 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,432 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,433 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,434 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,435 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,442 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,443 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,447 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,448 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:39,450 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,451 ] [ DEBUG ] [ utils:78 ]  value = [14], shape = [], res = [14], res.shape = (1,)
[ 2020-05-06 17:08:39,452 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,462 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,463 ] [ DEBUG ] [ utils:78 ]  value = [14], shape = [], res = [14], res.shape = (1,)
[ 2020-05-06 17:08:39,466 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,468 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,469 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,482 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,487 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,494 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,496 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,497 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,503 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,505 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,515 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,516 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,519 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,525 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,525 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,526 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,527 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,532 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,534 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,535 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,536 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,544 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,545 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,546 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,547 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,547 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,550 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,555 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,558 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,560 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,560 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,565 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,565 ] [ DEBUG ] [ utils:78 ]  value = [7], shape = [], res = [7], res.shape = (1,)
[ 2020-05-06 17:08:39,566 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,568 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,569 ] [ DEBUG ] [ utils:78 ]  value = [7], shape = [], res = [7], res.shape = (1,)
[ 2020-05-06 17:08:39,574 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,576 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,576 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,577 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,580 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,584 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,585 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,585 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,590 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,594 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,595 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,596 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,598 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,604 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,605 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,606 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,606 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,609 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,613 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,615 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,616 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,620 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,625 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,626 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,626 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,627 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,630 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,634 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,637 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,638 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,640 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,643 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,644 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:39,644 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,645 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,646 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:39,646 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,649 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,650 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,655 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,656 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,658 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,660 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,663 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,664 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,666 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,667 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,674 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,675 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,678 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,679 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,680 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,680 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,680 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,682 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,689 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,691 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,692 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,695 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,699 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,700 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,700 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,701 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,702 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,706 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,712 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,713 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,714 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,716 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,716 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,720 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,722 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,722 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,723 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,726 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,726 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,729 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,731 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,733 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,734 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,736 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,740 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,743 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,744 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,747 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,749 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,750 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,752 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,753 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,754 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,756 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,759 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,762 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,763 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,765 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,766 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,767 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,773 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,774 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,775 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,776 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,777 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,782 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,783 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,785 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,788 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,791 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,793 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,794 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,795 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,797 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,802 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,802 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,803 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,808 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,812 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,813 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,814 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,815 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,818 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,824 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,825 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,828 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,833 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,833 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,834 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,835 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,839 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,843 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,844 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,845 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,846 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,849 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,853 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,855 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,855 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,856 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,859 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,863 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,865 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,866 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,867 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,871 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,872 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,874 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,875 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,876 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,878 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,879 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,882 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,884 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,885 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,886 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,888 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,893 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,895 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,897 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,899 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,900 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,904 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,906 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,907 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,908 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,910 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,910 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,915 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,916 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,918 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,920 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,924 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,927 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,929 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,930 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,933 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,934 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,936 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,938 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,942 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,943 ] [ DEBUG ] [ utils:78 ]  value = [0.5], shape = [], res = [0.5], res.shape = (1,)
[ 2020-05-06 17:08:39,944 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,946 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,965 ] [ DEBUG ] [ utils:78 ]  value = [801], shape = [], res = [801], res.shape = (1,)
[ WARNING ]  Broadcast of scalar to shape: [0]
[ 2020-05-06 17:08:39,966 ] [ DEBUG ] [ utils:78 ]  value = [b''], shape = [], res = [''], res.shape = (1,)
[ 2020-05-06 17:08:39,967 ] [ DEBUG ] [ utils:78 ]  value = [b'Condition x == y did not hold element-wise:'], shape = [], res = ['Condition x == y did not hold element-wise:'], res.shape = (1,)
[ 2020-05-06 17:08:39,967 ] [ DEBUG ] [ utils:78 ]  value = [b'x (MultipleGridAnchorGenerator/assert_equal/x:0) = '], shape = [], res = ['x (MultipleGridAnchorGenerator/assert_equal/x:0) = '], res.shape = (1,)
[ 2020-05-06 17:08:39,968 ] [ DEBUG ] [ utils:78 ]  value = [b'y (MultipleGridAnchorGenerator/add_23:0) = '], shape = [], res = ['y (MultipleGridAnchorGenerator/add_23:0) = '], res.shape = (1,)
[ 2020-05-06 17:08:39,970 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:39,977 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:39,977 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,978 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:39,981 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:39,982 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:39,989 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:39,990 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:39,990 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:39,997 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:39,998 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,001 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,002 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,006 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,011 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,011 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,020 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,021 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,022 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,030 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,030 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,034 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,035 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,036 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,044 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,045 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,051 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,051 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,051 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,060 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,060 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,061 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,062 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,071 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,071 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,072 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,075 ] [ DEBUG ] [ utils:78 ]  value = [2.0], shape = [], res = [2.], res.shape = (1,)
[ 2020-05-06 17:08:40,076 ] [ DEBUG ] [ utils:78 ]  value = [2.0], shape = [], res = [2.], res.shape = (1,)
[ 2020-05-06 17:08:40,077 ] [ DEBUG ] [ utils:78 ]  value = [10.0], shape = [], res = [10.], res.shape = (1,)
[ 2020-05-06 17:08:40,080 ] [ DEBUG ] [ utils:78 ]  value = [10.0], shape = [], res = [10.], res.shape = (1,)
[ 2020-05-06 17:08:40,081 ] [ DEBUG ] [ utils:78 ]  value = [5.0], shape = [], res = [5.], res.shape = (1,)
[ 2020-05-06 17:08:40,083 ] [ DEBUG ] [ utils:78 ]  value = [2.0], shape = [], res = [2.], res.shape = (1,)
[ 2020-05-06 17:08:40,084 ] [ DEBUG ] [ utils:78 ]  value = [2.0], shape = [], res = [2.], res.shape = (1,)
[ 2020-05-06 17:08:40,086 ] [ DEBUG ] [ utils:78 ]  value = [2.0], shape = [], res = [2.], res.shape = (1,)
[ 2020-05-06 17:08:40,088 ] [ DEBUG ] [ utils:78 ]  value = [2.0], shape = [], res = [2.], res.shape = (1,)
[ 2020-05-06 17:08:40,092 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,093 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,093 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:40,096 ] [ DEBUG ] [ utils:78 ]  value = [224], shape = [], res = [224], res.shape = (1,)
[ 2020-05-06 17:08:40,103 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,113 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,113 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,120 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,121 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,124 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,125 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,131 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,131 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,134 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,136 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,141 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,142 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,192 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,196 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,197 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,199 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,201 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,211 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,216 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,217 ] [ DEBUG ] [ utils:78 ]  value = [0.30000001192092896], shape = [], res = [0.3], res.shape = (1,)
[ 2020-05-06 17:08:40,221 ] [ DEBUG ] [ utils:78 ]  value = [9.99999993922529e-09], shape = [], res = [1.e-08], res.shape = (1,)
[ 2020-05-06 17:08:40,226 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,227 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,230 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,231 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,232 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,233 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:40,234 ] [ DEBUG ] [ utils:78 ]  value = [-1.0], shape = [], res = [-1.], res.shape = (1,)
[ 2020-05-06 17:08:40,237 ] [ DEBUG ] [ utils:78 ]  value = [0.0], shape = [], res = [0.], res.shape = (1,)
[ 2020-05-06 17:08:40,244 ] [ DEBUG ] [ utils:78 ]  value = [b'Incorrect field size: actual vs expected.'], shape = [], res = ['Incorrect field size: actual vs expected.'], res.shape = (1,)
[ 2020-05-06 17:08:40,246 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,247 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,250 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,251 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,254 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,256 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,257 ] [ DEBUG ] [ utils:78 ]  value = [0.0], shape = [], res = [0.], res.shape = (1,)
[ 2020-05-06 17:08:40,261 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,262 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,263 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,270 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,273 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:40,274 ] [ DEBUG ] [ utils:78 ]  value = [-1.0], shape = [], res = [-1.], res.shape = (1,)
[ 2020-05-06 17:08:40,276 ] [ DEBUG ] [ utils:78 ]  value = [0.0], shape = [], res = [0.], res.shape = (1,)
[ 2020-05-06 17:08:40,282 ] [ DEBUG ] [ utils:78 ]  value = [b'Incorrect field size: actual vs expected.'], shape = [], res = ['Incorrect field size: actual vs expected.'], res.shape = (1,)
[ 2020-05-06 17:08:40,282 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,283 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,284 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,286 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,314 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:40,315 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ 2020-05-06 17:08:40,317 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,322 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,325 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,326 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,327 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,331 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,332 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,333 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,334 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,335 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,337 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,341 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,342 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,345 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,347 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,348 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,350 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,352 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,354 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,354 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,355 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,360 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,363 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,365 ] [ DEBUG ] [ utils:78 ]  value = [4], shape = [], res = [4], res.shape = (1,)
[ 2020-05-06 17:08:40,372 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,375 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,376 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,378 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,379 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,382 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,385 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,389 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,395 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,395 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,396 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,396 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,403 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,404 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,405 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,405 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,406 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,413 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,415 ] [ DEBUG ] [ utils:78 ]  value = [2], shape = [], res = [2], res.shape = (1,)
[ 2020-05-06 17:08:40,416 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,425 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,425 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,426 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,426 ] [ DEBUG ] [ utils:78 ]  value = [-1], shape = [], res = [-1], res.shape = (1,)
[ 2020-05-06 17:08:40,428 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,433 ] [ DEBUG ] [ utils:78 ]  value = [100], shape = [], res = [100], res.shape = (1,)
[ 2020-05-06 17:08:40,434 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,437 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,441 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,442 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,444 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,444 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,445 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,446 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,447 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,448 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,449 ] [ DEBUG ] [ utils:78 ]  value = [0], shape = [], res = [0], res.shape = (1,)
[ 2020-05-06 17:08:40,452 ] [ DEBUG ] [ utils:78 ]  value = [1], shape = [], res = [1], res.shape = (1,)
[ 2020-05-06 17:08:40,454 ] [ DEBUG ] [ utils:78 ]  value = [1.0], shape = [], res = [1.], res.shape = (1,)
[ WARNING ]  Instructions/layers that do not have attribute extractors:
[ WARNING ]      Where (1)
[ WARNING ]          Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Where
[ 2020-05-06 17:08:40,482 ] [ DEBUG ] [ class_registration:257 ]  Replacers execution order:
|  id  | enabled | class
|    0 |  None   | <class 'extensions.analysis.boolean_input.TrainingPhaseAnalysis'>
|    1 |  None   | <class 'extensions.analysis.tf_yolo.TensorFlowYOLOV3Analysis'>
|    2 |  None   | <class 'extensions.analysis.tf_yolo.TensorFlowYOLOV1V2Analysis'>
|    3 |  None   | <class 'extensions.analysis.tf_retinanet.TensorFlowRetinaNet'>
|    4 |  None   | <class 'extensions.analysis.tf_od_api.TensorFlowObjectDetectionAPIAnalysis'>
|    5 |  False  | <class 'extensions.middle.MulFakeQuantizeFuse.MulFakeQuantizeFuse'>
|    6 |  None   | <class 'extensions.analysis.nodes.IntermediatesNodesAnalysis'>
|    7 |  None   | <class 'extensions.analysis.inputs.InputsAnalysis'>
|    8 |  None   | <class 'mo.utils.model_analysis.AnalysisCollectorAnchor'>
|    9 |  False  | <class 'extensions.analysis.json_print.AnalysisJSONPrint'>
|   10 |  True   | <class 'extensions.front.user_data_repack.UserDataRepack'>
|   11 |  True   | <class 'extensions.front.output_cut.OutputCut'>
|   12 |  True   | <class 'extensions.front.input_cut.InputCut'>
|   13 |  True   | <class 'extensions.front.tf.variables_values_freezing.VariablesToConstants'>
|   14 |  True   | <class 'extensions.front.restore_ports.RestorePorts'>
|   15 |  True   | <class 'extensions.front.MoveEmbeddedInputsToInputs.MoveEmbeddedInputsToInputs'>
|   16 |  True   | <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'>
|   17 |  True   | <class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'>
|   18 |  True   | <class 'extensions.front.tf.tensorflow_patterns.TensorflowSubgraphPatterns'>
|   19 |  True   | <class 'extensions.front.tf.tensorflow_patterns.TensorflowOperationPatterns'>
|   20 |  True   | <class 'extensions.front.transformations_config.TransformationsConfig'>
|   21 |  True   | <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'>
|   22 |  True   | <class 'extensions.front.pass_separator.FrontStart'>
|   23 |  None   | <class 'extensions.front.YOLO.YoloV3RegionAddon'>
|   24 |  True   | <class 'extensions.front.split_normalizer.VariadicSplitInputsSwap'>
|   25 |  True   | <class 'extensions.front.tf.UnpackPackReverseInputChannels.UnpackPackReverseInputChannels'>
|   26 |  True   | <class 'extensions.front.tf.transposed_mvn_unrolled.TransposedMVNUnrolled'>
|   27 |  True   | <class 'extensions.front.TopKNormalize.TopKNormalize'>
|   28 |  True   | <class 'extensions.front.tf.non_max_suppression_normalize.TFNonMaxSuppressionNormalize'>
|   29 |  True   | <class 'extensions.front.tf.SwitchMergeOptimization.SwitchMergeOptimization'>
|   30 |  True   | <class 'extensions.front.tf.swish.Swish'>
|   31 |  True   | <class 'extensions.front.tf.swap_deconv_inputs.SwapDeconvInputs'>
|   32 |  True   | <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'>
|   33 |  True   | <class 'extensions.front.split_normalizer.SplitInputsReconnect'>
|   34 |  True   | <class 'extensions.front.softsign_replacer.SoftSign'>
|   35 |  True   | <class 'extensions.front.tf.SizeReplacer.SizeFrontReplacer'>
|   36 |  None   | <class 'extensions.front.tf.SSDToolboxDetectionOutput.SSDToolboxDetectionOutputReplacement'>
|   37 |  None   | <class 'extensions.front.tf.RetinaNetFilteredDetectionsReplacement.RetinaNetFilteredDetectionsReplacement'>
|   38 |  True   | <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'>
|   39 |  True   | <class 'extensions.front.softmax.SoftmaxFromKeras'>
|   40 |  True   | <class 'extensions.front.reciprocal.ReciprocalReplacer'>
|   41 |  True   | <class 'extensions.front.tf.fifo_replacer.QueueDequeueManyV2'>
|   42 |  True   | <class 'extensions.front.tf.prelu.PReLUWithAbs'>
|   43 |  True   | <class 'extensions.front.tf.prelu.PReLU'>
|   44 |  True   | <class 'extensions.front.PowerToEltwises.PowerToEltwises'>
|   45 |  True   | <class 'extensions.front.tf.mvn_unrolled.MVNUnrolled'>
|   46 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIOutputReplacement'>
|   47 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIConstValueOverride'>
|   48 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessorReplacement'>
|   49 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIProposalReplacement'>
|   50 |  True   | <class 'extensions.front.no_op_eraser.NoOpEraser'>
|   51 |  True   | <class 'extensions.front.tf.nearest_neighbor_upsampling.NearestNeighborUpsampling'>
|   52 |  True   | <class 'extensions.front.tf.FlattenToReshape.FlattenToReshapeableReshape'>
|   53 |  True   | <class 'extensions.front.Pack.Pack'>
|   54 |  True   | <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'>
|   55 |  True   | <class 'extensions.front.tf.mvn.MVNReplacer'>
|   56 |  True   | <class 'extensions.front.squared_difference.SquaredDifference'>
|   57 |  True   | <class 'extensions.front.tf.LogSoftmax.LogSoftmaxFrontReplacer'>
|   58 |  True   | <class 'extensions.front.Log1p.Log1p'>
|   59 |  True   | <class 'extensions.front.LRNReplacer.LRNReplacer'>
|   60 |  True   | <class 'extensions.front.tf.InterpolateTransposes.InterpolateTranspose'>
|   61 |  True   | <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'>
|   62 |  True   | <class 'extensions.front.instance_normalization.InstanceNormalization'>
|   63 |  True   | <class 'extensions.front.image_scaler.ImageScaler'>
|   64 |  True   | <class 'extensions.front.global_pooling_to_reduce.GlobalPoolingToReduce'>
|   65 |  True   | <class 'extensions.front.MatMul_normalizer.GemmDecomposer'>
|   66 |  True   | <class 'extensions.front.tf.GNMT_DynamicSequenceLengths.GNMT_sequence_lengths'>
|   67 |  True   | <class 'extensions.front.MatMul_normalizer.FullyConnectedDecomposer'>
|   68 |  True   | <class 'extensions.front.flatten_to_reshape.FlattenToReshape'>
|   69 |  True   | <class 'extensions.front.rank_decomposer.RankDecomposer'>
|   70 |  True   | <class 'extensions.front.FillToBroadcast.FillToBroadcast'>
|   71 |  True   | <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'>
|   72 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>
|   73 |  True   | <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'>
|   74 |  None   | <class 'extensions.front.YOLO.YoloRegionAddon'>
|   75 |  True   | <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'>
|   76 |  True   | <class 'extensions.front.tf.fake_const_ext.FakeConstToConst'>
|   77 |  True   | <class 'extensions.front.tf.fifo_replacer.FIFOQueue'>
|   78 |  True   | <class 'extensions.front.override_batch.OverrideBatch'>
|   79 |  True   | <class 'extensions.front.tf.sparse_weighted_sum.ExperimentalSparseWeightedSumFrontReplacer2'>
|   80 |  True   | <class 'extensions.front.tf.sparse_weighted_sum.ExperimentalSparseWeightedSumFrontReplacer'>
|   81 |  True   | <class 'extensions.front.eltwise_n.EltwiseNReplacement'>
|   82 |  True   | <class 'extensions.front.div.Div'>
|   83 |  True   | <class 'extensions.front.tf.CropAndResizeReplacement.CropAndResizeReplacement'>
|   84 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>
|   85 |  True   | <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'>
|   86 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPSROIPoolingReplacement'>
|   87 |  True   | <class 'extensions.front.sub.Sub'>
|   88 |  True   | <class 'extensions.front.split_normalizer.SqueezeAxis'>
|   89 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement'>
|   90 |  None   | <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNSigmoidReplacement'>
|   91 |  True   | <class 'extensions.front.tf.concat.Concat'>
|   92 |  True   | <class 'extensions.front.ChangePlaceholderTypes.ChangePlaceholderTypes'>
|   93 |  True   | <class 'extensions.front.ChangeCastOutputType.ChangeCastOutputType'>
|   94 |  True   | <class 'extensions.front.tf.CTCGreedyDecoder.CTCGreedyDecoderReplacement'>
|   95 |  True   | <class 'extensions.front.tf.bucketize.BucketizeFrontReplacer'>
|   96 |  True   | <class 'extensions.front.tf.BlockLSTM.BlockLSTM'>
|   97 |  True   | <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'>
|   98 |  True   | <class 'extensions.front.tf.BatchToSpaceNDToUpsample.BatchToSpaceNDToUpsample'>
|   99 |  True   | <class 'extensions.front.split_normalizer.AttributedVariadicSplitToVariadicSplit'>
|  100 |  True   | <class 'extensions.front.split_normalizer.AttributedSplitToSplit'>
|  101 |  True   | <class 'extensions.front.tf.basic_lstm_cell.BasicLSTMCell'>
|  102 |  True   | <class 'extensions.front.AttributedGatherNormalizer.AttributedGatherNormalizer'>
|  103 |  True   | <class 'extensions.front.tf.assign_elimination.AssignSubElimination'>
|  104 |  True   | <class 'extensions.front.tf.assign_elimination.AssignElimination'>
|  105 |  True   | <class 'extensions.front.tf.assign_elimination.AssignAddElimination'>
|  106 |  True   | <class 'extensions.front.tf.assign_elimination.AssertElimination'>
|  107 |  True   | <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'>
|  108 |  True   | <class 'extensions.front.pass_separator.FrontFinish'>
|  109 |  True   | <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'>
|  110 |  True   | <class 'extensions.middle.PartialInfer.PartialInfer'>
|  111 |  True   | <class 'extensions.middle.ReverseV2ToReverseSequence.ReverseToReverseSequence'>
|  112 |  True   | <class 'extensions.middle.DeleteControlFlowEdges.DeleteControlFlowEdges'>
|  113 |  True   | <class 'extensions.middle.quantize_fuses.MarkNodesToFuseUpToFakeQuantize'>
|  114 |  True   | <class 'extensions.middle.quantize_fuses.FakeQuantizeFuse'>
|  115 |  True   | <class 'extensions.middle.BinarizeWeightsM1P1.BinarizeWeightsM1P1'>
|  116 |  True   | <class 'extensions.middle.ReluQuantizeFuse.ReluFakeQuantizeMark'>
|  117 |  True   | <class 'extensions.middle.ReluQuantizeFuse.ReluQuantizeFuse'>
|  118 |  True   | <class 'extensions.middle.ReluQuantizeFuse.ClampQuantizeMark'>
|  119 |  True   | <class 'extensions.middle.AddIsCyclicAttribute.AddIsCyclicAttribute'>
|  120 |  True   | <class 'extensions.middle.TensorIteratorInput.SmartInputMatcher'>
|  121 |  True   | <class 'extensions.middle.TensorIteratorOutput.SmartOutputMatcher'>
|  122 |  True   | <class 'extensions.middle.TensorIteratorOutput.SimpleOutputMatcher'>
|  123 |  True   | <class 'extensions.middle.TensorIteratorCondition.LoopConditionMatcher'>
|  124 |  True   | <class 'extensions.middle.TensorIteratorCondition.SimpleConditionMatcher'>
|  125 |  True   | <class 'extensions.middle.TensorIteratorCondition.DynamicDecoderConditionMatcher'>
|  126 |  True   | <class 'extensions.middle.TensorIteratorBackEdge.BackEdgesMatching'>
|  127 |  True   | <class 'extensions.middle.TensorIteratorConditionChecker.ConditionChecks'>
|  128 |  True   | <class 'extensions.middle.DeleteNotExecutable.DeleteNotExecutable'>
|  129 |  True   | <class 'extensions.middle.TensorIteratorInput.SimpleInputMatcher'>
|  130 |  True   | <class 'extensions.middle.TensorIteratorInput.BackEdgeSimpleInputMatcher'>
|  131 |  True   | <class 'extensions.middle.TensorIteratorMerge.TensorIteratorMerge'>
|  132 |  True   | <class 'extensions.middle.CheckForCycle.CheckForCycle'>
|  133 |  True   | <class 'extensions.middle.SharedWeightsDuplication.SharedWeightsDuplication'>
|  134 |  True   | <class 'extensions.middle.pass_separator.PreMiddleStart'>
|  135 |  True   | <class 'extensions.middle.UselessSplitEraser.UselessSplitEraser'>
|  136 |  True   | <class 'extensions.middle.InputCut.MiddleInputCut'>
|  137 |  True   | <class 'extensions.middle.ScaleInput.ScaleInput'>
|  138 |  True   | <class 'extensions.middle.AddMeanScaleValues.AddMeanScaleValues'>
|  139 |  True   | <class 'extensions.middle.RemoveIdentity.RemoveNodesWithZeroPhase'>
|  140 |  True   | <class 'extensions.middle.RemoveIdentity.RemoveIdentity'>
|  141 |  True   | <class 'extensions.middle.RemoveIdentity.RemoveDropout'>
|  142 |  True   | <class 'extensions.middle.L2NormToNorm.L2NormToNorm'>
|  143 |  True   | <class 'extensions.middle.DilatedConvolution.DilatedConvolutionConverter'>
|  144 |  True   | <class 'extensions.middle.CustomSubgraphCall.CustomSubgraphCall'>
|  145 |  True   | <class 'extensions.middle.ConvertMultiInputConv.ConvertMultiInputConv'>
|  146 |  True   | <class 'extensions.middle.pass_separator.MiddleStart'>
|  147 |  True   | <class 'extensions.middle.wights_permute_normalizer.WeightsPermuteNormalizer'>
|  148 |  True   | <class 'extensions.middle.UpsampleToResample.UpsampleToResample'>
|  149 |  True   | <class 'extensions.middle.TF_lstm_cell_to_generic.TensorFlowLSTMtoGeneric'>
|  150 |  True   | <class 'extensions.middle.SwapAxesMiddleReplacer.SwapAxisMiddleReplacer'>
|  151 |  True   | <class 'extensions.middle.sparse_reshape.SparseReshapeMiddleReplacer'>
|  152 |  True   | <class 'extensions.middle.space_to_depth.SpaceToDepth'>
|  153 |  True   | <class 'extensions.middle.ShuffleChannel.ShuffleChannel'>
|  154 |  True   | <class 'extensions.middle.ReverseTransposeNormalization.ReverseTransposeNormalization'>
|  155 |  True   | <class 'extensions.middle.ReplacePNorm.ReplacePNormNodePattern'>
|  156 |  True   | <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetWithMemoryNodePattern'>
|  157 |  True   | <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetNodePattern'>
|  158 |  True   | <class 'extensions.middle.RemoveDuplicationMemory.RemoveMemoryDuplicationPattern'>
|  159 |  True   | <class 'extensions.middle.RemoveDuplicationMemory.MergeNeighborSplicePattern'>
|  160 |  True   | <class 'extensions.middle.RemoveUselessCrops.RemoveUselessCropsPattern'>
|  161 |  True   | <class 'extensions.middle.InsertSelect.AddSelectBeforeMemoryNodePattern'>
|  162 |  True   | <class 'extensions.middle.ReplaceSpliceNodePattern.ReplaceSpliceNodePattern'>
|  163 |  True   | <class 'extensions.middle.RemoveUselessConcatSplit.RemoveUselessConcatSplitPattern'>
|  164 |  True   | <class 'extensions.middle.ONNXRNNSequenceNormalize.ONNXRNNSequenceNormalize'>
|  165 |  False  | <class 'extensions.middle.TensorIteratorLSTMToLSTMSequence.TensorIteratorLSTM'>
|  166 |  True   | <class 'extensions.middle.NormalizePad.NormalizePad'>
|  167 |  True   | <class 'extensions.middle.MinimumMiddleReplacer.MinimumMiddleReplacer'>
|  168 |  True   | <class 'extensions.middle.MXTileReplacer.MXTileReplacer'>
|  169 |  True   | <class 'extensions.middle.MXRepeatReplacer.MXRepeatReplacer'>
|  170 |  True   | <class 'extensions.middle.MXNetSplitMultiLayers.MXNetSplitLayersToRNNSequence'>
|  171 |  True   | <class 'extensions.middle.MXNetRNNSequenceNormalize.MXNetRNNSequenceNormalize'>
|  172 |  True   | <class 'extensions.middle.DecomposeBidirectionalRNNSequence.DecomposeBidirectionalRNNSequence'>
|  173 |  None   | <class 'extensions.middle.RNNSequenceNormalizeToIE.RNNSequenceNormalize'>
|  174 |  True   | <class 'extensions.middle.GRURNNSequenceToTensorIterator.GRUAndRNNToTensorIterator'>
|  175 |  True   | <class 'extensions.middle.GatherNdNormalizer.GatherNdNormalize'>
|  176 |  True   | <class 'extensions.middle.FusedBatchNormTraining.FusedBatchNormTraining'>
|  177 |  True   | <class 'extensions.middle.FusedBatchNormNonConstant.FusedBatchNormNonConstant'>
|  178 |  True   | <class 'extensions.middle.EltwiseInputReshape.EltwiseInputReshape'>
|  179 |  False  | <class 'extensions.middle.EltwiseInputReshape.Eltwise1DInputReshape'>
|  180 |  False  | <class 'extensions.middle.EltwiseInputNormalization.EltwiseInputNormalize'>
|  181 |  True   | <class 'extensions.middle.DepthToSpace.DepthToSpace'>
|  182 |  True   | <class 'extensions.middle.Deconvolution3rdInputNormalization.Deconvolution3rdInputNormalization'>
|  183 |  True   | <class 'extensions.middle.DecomposeBias.DecomposeBias'>
|  184 |  True   | <class 'extensions.middle.SliceConverter.ConvertSlice'>
|  185 |  True   | <class 'extensions.middle.UselessStridedSlice.UselessStridedSliceEraser'>
|  186 |  True   | <class 'extensions.middle.ConvertGroupedStridedSlice.ConvertGroupedStridedSlice'>
|  187 |  True   | <class 'extensions.middle.ConvertLayoutDependentOperations.ConvertLayoutDependentOperations'>
|  188 |  True   | <class 'extensions.middle.ConvToBinaryConv.ConvToBinaryConv'>
|  189 |  True   | <class 'extensions.middle.ConstSwitchResolver.ConstSwitchEraser'>
|  190 |  True   | <class 'extensions.middle.UselessMerge.UselessMergeEraser'>
|  191 |  True   | <class 'extensions.middle.BlockLSTMtoLSTMSequence.BlockLSTMtoLSTMSequence'>
|  192 |  True   | <class 'extensions.middle.LSTMRNNSequenceToTensorIterator.LSTMToTensorIterator'>
|  193 |  True   | <class 'extensions.middle.permute_tensor_iterator.TransposeTensorIteratorLSTM'>
|  194 |  True   | <class 'extensions.middle.reverse_tensor_iterator.ReverseTensorIteratorLSTM'>
|  195 |  True   | <class 'extensions.middle.BiasAddBroadcasting.BiasAddInputBroadcasting'>
|  196 |  True   | <class 'extensions.middle.EltwiseChecker.EltwiseChecker'>
|  197 |  True   | <class 'extensions.middle.GroupNorm.GroupNormToMVN'>
|  198 |  True   | <class 'extensions.middle.AttributedTileNormalizer.AttributedTileNormalizer'>
|  199 |  True   | <class 'extensions.middle.ArgMaxToTopK.ArgMaxToTopK'>
|  200 |  True   | <class 'extensions.middle.AnchorToPriorBox.AnchorToPriorBoxes'>
|  201 |  True   | <class 'extensions.middle.ssd_anchors_to_const.SsdAnchorsMiddleReplacer'>
|  202 |  True   | <class 'extensions.middle.FakeSplitOutputs.AddFakeOutputsToVariadicSplit'>
|  203 |  True   | <class 'extensions.middle.FakeSplitOutputs.AddFakeOutputsToSplit'>
|  204 |  True   | <class 'extensions.middle.pass_separator.MiddleFinish'>
|  205 |  True   | <class 'extensions.middle.RemoveRedundantReshapeAfterCropAndResize.RemoveRedundantReshapeAfterCropAndResize'>
|  206 |  True   | <class 'extensions.middle.NasNet.NasNet'>
|  207 |  True   | <class 'extensions.middle.fusings.Fusing'>
|  208 |  True   | <class 'extensions.middle.LeakyReluPattern.LeakyReLU'>
|  209 |  True   | <class 'extensions.middle.MulAddToSS.MulAddToSS'>
|  210 |  True   | <class 'extensions.middle.preprocessing.Preprocessing'>
|  211 |  True   | <class 'extensions.middle.preprocessing.CaffeMeanFileProcessing'>
|  212 |  True   | <class 'extensions.middle.ConcatOptimization.ConcatOptimization'>
|  213 |  True   | <class 'extensions.middle.FuseReshapesSequence.FuseReshapesSequence'>
|  214 |  True   | <class 'extensions.middle.RemoveRedundantReshapes.RemoveRedundantReshapes'>
|  215 |  True   | <class 'extensions.middle.pass_separator.PostMiddleStart'>
|  216 |  True   | <class 'extensions.middle.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'>
|  217 |  True   | <class 'extensions.middle.LayoutChangeForConstantShapePaths.LayoutChangeForConstantShapePaths'>
|  218 |  True   | <class 'extensions.middle.ApplyNHWCtoNCHWpermutation.ApplyNHWCtoNCHWpermutation'>
|  219 |  True   | <class 'extensions.middle.ApplyPermutations.ApplyPermutation'>
|  220 |  True   | <class 'extensions.back.pass_separator.BackStart'>
|  221 |  True   | <class 'extensions.back.split_normalizer.VariadicSplitNormalizer'>
|  222 |  True   | <class 'extensions.back.split_normalizer.PassVariadicSplitAsIs'>
|  223 |  True   | <class 'extensions.back.UselessConcatRemoval.UselessConcatRemoval'>
|  224 |  True   | <class 'extensions.back.TileNormalizer.TileInputAlignment'>
|  225 |  True   | <class 'extensions.back.TileNormalizer.TileMultipleAxisReplacer'>
|  226 |  True   | <class 'extensions.back.TileNormalizer.Tile3DReshaper'>
|  227 |  True   | <class 'extensions.back.TileNormalizer.TileVersionDowngrader'>
|  228 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.SubtractToEltwises'>
|  229 |  False  | <class 'extensions.back.ShufflenetReLUReorder.ShufflenetReLUReorder'>
|  230 |  True   | <class 'extensions.back.SelectBroadcast.SelectBroadcast'>
|  231 |  False  | <class 'extensions.back.ReverseInputChannels.ReverseChannelsPropagationUp'>
|  232 |  False  | <class 'extensions.back.ReverseInputChannels.ReverseChannelsPropagationDown'>
|  233 |  True   | <class 'extensions.back.ResultNormalizer.ResultNormalizer'>
|  234 |  False  | <class 'extensions.back.RemoveUselessConvert.RemoveUselessConvert'>
|  235 |  True   | <class 'extensions.back.remove_last_softmax_pattern.RemoveLastSoftMaxPattern'>
|  236 |  True   | <class 'extensions.back.remove_last_softmax_pattern.RemoveLastLogSoftMaxPattern'>
|  237 |  True   | <class 'extensions.back.ReduceToPooling.ReduceReplacer'>
|  238 |  True   | <class 'extensions.back.ReduceToPooling.ReduceLogicalReplacer'>
|  239 |  True   | <class 'extensions.back.RNNSequenceTypeRename.RNNSequence'>
|  240 |  True   | <class 'extensions.back.ProposalMutation.ProposalMutation'>
|  241 |  True   | <class 'extensions.back.priorbox_mutation.PriorboxMutation'>
|  242 |  True   | <class 'extensions.back.PadNormalizer.PadNormalize'>
|  243 |  True   | <class 'extensions.back.PackBinaryWeights.PackBinaryWeights'>
|  244 |  False  | <class 'extensions.back.op_versioning.OpVersioning'>
|  245 |  True   | <class 'extensions.back.OneHotNormalizer.OneHotNormalizer'>
|  246 |  False  | <class 'extensions.back.SpecialNodesFinalization.NormalizeTI'>
|  247 |  True   | <class 'extensions.back.NonMaximumSuppressionNormalize.NonMaximumSuppressionNormalizer'>
|  248 |  False  | <class 'extensions.back.ScalarConstNormalize.ScalarNormalize'>
|  249 |  True   | <class 'extensions.back.TopKNormalizer.TopKNormalizer'>
|  250 |  True   | <class 'extensions.back.Reshape0DToSqueeze.Reshape0DToSqueeze'>
|  251 |  True   | <class 'extensions.back.fuse_sub_div_min.Negate'>
|  252 |  True   | <class 'extensions.back.fuse_sub_div_min.EltwisesToSubtract'>
|  253 |  True   | <class 'extensions.back.MaxPool.MaxPool'>
|  254 |  True   | <class 'extensions.back.MatMulNormalizer.MatMulConstTransposesExtraction'>
|  255 |  True   | <class 'extensions.back.MatMulNormalizer.MatMulToFullyConnected'>
|  256 |  True   | <class 'extensions.back.MatMulNormalizer.SSBiasAddonForFC'>
|  257 |  True   | <class 'extensions.back.MatMulNormalizer.PullTransposeThroughFQUp'>
|  258 |  True   | <class 'extensions.back.MatMulNormalizer.BiasAddonForFC'>
|  259 |  True   | <class 'extensions.back.MatMulNormalizer.FullyConnectedFinalization'>
|  260 |  True   | <class 'extensions.back.LeakyReluToReluWithNegativeSlope.LeakyReluToReluWithNegativeSlope'>
|  261 |  True   | <class 'extensions.back.LeakyReLUMutation.LeakyReLUMutation'>
|  262 |  True   | <class 'extensions.back.LSTMCellNormalizer.LSTMCellNormalizer'>
|  263 |  True   | <class 'extensions.back.LRNToNorm.LRN_normalization'>
|  264 |  True   | <class 'extensions.back.InterpolateToInterpOrResample.InterpolateToInterpOrResample'>
|  265 |  True   | <class 'extensions.back.ShapeOfToShape.ShapeOfToShape'>
|  266 |  False  | <class 'extensions.back.ReverseInputChannels.InsertReverseChannels'>
|  267 |  True   | <class 'extensions.back.GatherNormalizer.GatherTreeNormalizer'>
|  268 |  True   | <class 'extensions.back.GatherNormalizer.GatherNormalizer'>
|  269 |  True   | <class 'extensions.back.GatherNormalizer.Gather0D'>
|  270 |  True   | <class 'extensions.back.FuseTransposesSequence.FuseTransposesSequence'>
|  271 |  True   | <class 'extensions.back.ShuffleChannelPatternOptimization.ShuffleChannelPatternOptimization'>
|  272 |  False  | <class 'extensions.back.OptimizeTransposeReshapeSequence.OptimizeTransposeReshapeSequence'>
|  273 |  False  | <class 'extensions.back.ReduceTransposeDimensions.ReduceTransposeDimensions'>
|  274 |  True   | <class 'extensions.back.TransposeToPermute.TransposeToPermute'>
|  275 |  True   | <class 'extensions.back.EnableConstantStridedSlice.EnableConstantStridedSlice'>
|  276 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.EltwisesWithScalarInputToPower'>
|  277 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowerMerge'>
|  278 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulPowPowerMerge'>
|  279 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.AddPowPowerMerge'>
|  280 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowPowerMerge'>
|  281 |  True   | <class 'extensions.back.fuse_sub_div_min.EltwisesToDiv'>
|  282 |  True   | <class 'extensions.back.DumpFakeQuantStat.DumpFakeQuantStat'>
|  283 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.DivideToEltwises'>
|  284 |  False  | <class 'extensions.back.disable_unsupported_ND_operations.DisableUnsupportedNDOperations'>
|  285 |  False  | <class 'extensions.back.ReverseInputChannels.DecomposeReverseChannels'>
|  286 |  True   | <class 'extensions.back.CutMemory.CutMemory'>
|  287 |  True   | <class 'extensions.back.CropToStridedSlice.CropToStridedSlice'>
|  288 |  True   | <class 'extensions.back.StridedSliceMasksNormalizer.StridedSliceMasksNormalizer'>
|  289 |  True   | <class 'extensions.back.ConvolutionNormalizer.ConvolutionReshaper'>
|  290 |  True   | <class 'extensions.back.ConvolutionNormalizer.ConvolutionNormalizer'>
|  291 |  True   | <class 'extensions.back.insert_compatibility_l2normalization.CompatibilityL2NormalizationPattern'>
|  292 |  True   | <class 'extensions.back.NormalizeToNormalizeL2.NormalizeToNormalizeL2'>
|  293 |  True   | <class 'extensions.back.ElementwiseOpsToEltwiseOps.SimpleEltwiseToEltwiseOp'>
|  294 |  True   | <class 'extensions.back.ScalarConstNormalize.ScalarNormalizeForSpecificOps'>
|  295 |  True   | <class 'extensions.back.ScalarConstNormalize.RangeInputNormalize'>
|  296 |  True   | <class 'extensions.back.AvgPool.AvgPool'>
|  297 |  True   | <class 'extensions.back.ReverseInputChannels.ApplyReverseChannels'>
|  298 |  True   | <class 'extensions.back.split_normalizer.SplitNormalizer'>
|  299 |  True   | <class 'extensions.back.ParameterToPlaceholder.ParameterToInput'>
|  300 |  True   | <class 'extensions.back.GroupedConvWeightsNormalize.GroupedConvWeightsNormalize'>
|  301 |  True   | <class 'extensions.back.ConvolutionNormalizer.DeconvolutionNormalizer'>
|  302 |  True   | <class 'extensions.back.ConvolutionNormalizer.ConvolutionWithGroupsResolver'>
|  303 |  True   | <class 'extensions.back.ReshapeMutation.ReshapeMutation'>
|  304 |  True   | <class 'extensions.back.ForceStrictPrecision.ForceStrictPrecision'>
|  305 |  True   | <class 'extensions.back.I64ToI32.I64ToI32'>
|  306 |  True   | <class 'extensions.back.ReshapeMutation.DisableReshapeMutationInTensorIterator'>
|  307 |  True   | <class 'extensions.back.ConvolutionNormalizer.PullReshapeThroughFQ'>
|  308 |  True   | <class 'extensions.back.ActivationsNormalizer.ActivationsNormalizer'>
|  309 |  True   | <class 'extensions.back.pass_separator.BackFinish'>
|  310 |  False  | <class 'extensions.back.SpecialNodesFinalization.RemoveConstOps'>
|  311 |  False  | <class 'extensions.back.SpecialNodesFinalization.CreateConstNodesReplacement'>
|  312 |  True   | <class 'extensions.back.kaldi_remove_memory_output.KaldiRemoveMemoryOutputBackReplacementPattern'>
|  313 |  False  | <class 'extensions.back.SpecialNodesFinalization.RemoveOutputOps'>
|  314 |  True   | <class 'extensions.back.blob_normalizer.BlobNormalizer'>
|  315 |  False  | <class 'extensions.middle.AddFakeQuantizeFuse.AddFakeQuantizeFuse'>
[ 2020-05-06 17:08:40,492 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.boolean_input.TrainingPhaseAnalysis'>
[ 2020-05-06 17:08:40,510 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.tf_yolo.TensorFlowYOLOV3Analysis'>
[ 2020-05-06 17:08:40,545 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.tf_yolo.TensorFlowYOLOV1V2Analysis'>
[ 2020-05-06 17:08:40,620 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.tf_retinanet.TensorFlowRetinaNet'>
[ 2020-05-06 17:08:40,697 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.tf_od_api.TensorFlowObjectDetectionAPIAnalysis'>
[ INFO ]  Skip replacer <class 'extensions.middle.MulFakeQuantizeFuse.MulFakeQuantizeFuse'> (enabled = False)
[ 2020-05-06 17:08:40,877 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.nodes.IntermediatesNodesAnalysis'>
[ 2020-05-06 17:08:40,904 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.analysis.inputs.InputsAnalysis'>
[ 2020-05-06 17:08:40,930 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'mo.utils.model_analysis.AnalysisCollectorAnchor'>
[ INFO ]  Skip replacer <class 'extensions.analysis.json_print.AnalysisJSONPrint'> (enabled = False)
[ 2020-05-06 17:08:40,946 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.user_data_repack.UserDataRepack'>
[ 2020-05-06 17:08:40,965 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.output_cut.OutputCut'>
[ 2020-05-06 17:08:41,008 ] [ DEBUG ] [ graph:1034 ]  Sink: detection_boxes/sink_port_0 for node detection_boxes
[ 2020-05-06 17:08:41,008 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C05C18>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'detection_boxes/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x0000027886099DC8>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,010 ] [ DEBUG ] [ graph:1036 ]  Add edge from detection_boxes to detection_boxes/sink_port_0
[ 2020-05-06 17:08:41,014 ] [ DEBUG ] [ graph:1034 ]  Sink: detection_scores/sink_port_0 for node detection_scores
[ 2020-05-06 17:08:41,015 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C054C8>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'detection_scores/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x0000027886099D38>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,016 ] [ DEBUG ] [ graph:1036 ]  Add edge from detection_scores to detection_scores/sink_port_0
[ 2020-05-06 17:08:41,017 ] [ DEBUG ] [ graph:1034 ]  Sink: detection_multiclass_scores/sink_port_0 for node detection_multiclass_scores
[ 2020-05-06 17:08:41,017 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C05048>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'detection_multiclass_scores/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x0000027886099168>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,018 ] [ DEBUG ] [ graph:1036 ]  Add edge from detection_multiclass_scores to detection_multiclass_scores/sink_port_0
[ 2020-05-06 17:08:41,024 ] [ DEBUG ] [ graph:1034 ]  Sink: detection_classes/sink_port_0 for node detection_classes
[ 2020-05-06 17:08:41,025 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C05288>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'detection_classes/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x0000027886099288>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,026 ] [ DEBUG ] [ graph:1036 ]  Add edge from detection_classes to detection_classes/sink_port_0
[ 2020-05-06 17:08:41,026 ] [ DEBUG ] [ graph:1034 ]  Sink: num_detections/sink_port_0 for node num_detections
[ 2020-05-06 17:08:41,027 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C05798>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'num_detections/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x00000278860993A8>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,027 ] [ DEBUG ] [ graph:1036 ]  Add edge from num_detections to num_detections/sink_port_0
[ 2020-05-06 17:08:41,027 ] [ DEBUG ] [ graph:1034 ]  Sink: raw_detection_boxes/sink_port_0 for node raw_detection_boxes
[ 2020-05-06 17:08:41,028 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C0FEE8>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'raw_detection_boxes/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x00000278860994C8>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,028 ] [ DEBUG ] [ graph:1036 ]  Add edge from raw_detection_boxes to raw_detection_boxes/sink_port_0
[ 2020-05-06 17:08:41,029 ] [ DEBUG ] [ graph:1034 ]  Sink: raw_detection_scores/sink_port_0 for node raw_detection_scores
[ 2020-05-06 17:08:41,029 ] [ DEBUG ] [ graph:1035 ]  {'kind': 'op', 'op': 'Result', 'type': 'Result', 'infer': <function Result.__init__.<locals>.<lambda> at 0x0000027887C0FF78>, 'value': None, 'data_type': None, 'in_ports_count': 1, 'name': 'raw_detection_scores/sink_port_0', 'dim_attrs': ['batch_dims', 'channel_dims', 'axis', 'spatial_dims'], 'shape_attrs': ['shape', 'window', 'output_shape', 'pad', 'stride'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x00000278860995E8>), 'name', 'type', 'version'], [('data', [], []), '@ports', '@consts'])], '_in_ports': {0: {}}, '_out_ports': {}}
[ 2020-05-06 17:08:41,029 ] [ DEBUG ] [ graph:1036 ]  Add edge from raw_detection_scores to raw_detection_scores/sink_port_0
[ 2020-05-06 17:08:41,033 ] [ DEBUG ] [ eliminate:66 ]  The following nodes are seeded as output reachable:
[ 2020-05-06 17:08:41,181 ] [ DEBUG ] [ eliminate:136 ]  Removing the following dead nodes:
[ 2020-05-06 17:08:41,207 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.input_cut.InputCut'>
[ 2020-05-06 17:08:41,232 ] [ DEBUG ] [ eliminate:66 ]  The following nodes are seeded as output reachable:
[ 2020-05-06 17:08:41,377 ] [ DEBUG ] [ eliminate:136 ]  Removing the following dead nodes:
[ INFO ]  Skip replacer <class 'extensions.front.tf.variables_values_freezing.VariablesToConstants'> (graph_condition not satisfied)
[ 2020-05-06 17:08:41,406 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.restore_ports.RestorePorts'>
[ 2020-05-06 17:08:41,436 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.MoveEmbeddedInputsToInputs.MoveEmbeddedInputsToInputs'>
[ 2020-05-06 17:08:41,515 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'>
[ INFO ]  Skip replacer <class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'> (graph_condition not satisfied)
[ INFO ]  Skip replacer <class 'extensions.front.tf.tensorflow_patterns.TensorflowSubgraphPatterns'> (graph_condition not satisfied)
[ INFO ]  Skip replacer <class 'extensions.front.tf.tensorflow_patterns.TensorflowOperationPatterns'> (graph_condition not satisfied)
[ 2020-05-06 17:08:41,596 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.transformations_config.TransformationsConfig'>
[ INFO ]  Registered custom replacement with id 'ObjectDetectionAPIPreprocessorReplacement'
[ INFO ]  Registered custom replacement with id 'ObjectDetectionAPISSDPostprocessorReplacement'
[ 2020-05-06 17:08:41,620 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'>
[ 2020-05-06 17:08:41,751 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.pass_separator.FrontStart'>
[ 2020-05-06 17:08:41,773 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.YOLO.YoloV3RegionAddon'>
[ WARNING ]  Configuration file for custom replacement with id 'TFYOLOV3' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'TFYOLOV3'
[ 2020-05-06 17:08:41,810 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.split_normalizer.VariadicSplitInputsSwap'>
[ 2020-05-06 17:08:41,833 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.UnpackPackReverseInputChannels.UnpackPackReverseInputChannels'>
[ 2020-05-06 17:08:41,914 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.transposed_mvn_unrolled.TransposedMVNUnrolled'>
[ 2020-05-06 17:08:41,915 ] [ DEBUG ] [ transposed_mvn_unrolled:111 ]  Enabled Transposed MVN replacement
[ 2020-05-06 17:08:41,998 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.TopKNormalize.TopKNormalize'>
[ 2020-05-06 17:08:42,001 ] [ DEBUG ] [ TopKNormalize:43 ]  The TopK node input "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/TopKV2" is already normalized
[ 2020-05-06 17:08:42,001 ] [ DEBUG ] [ TopKNormalize:43 ]  The TopK node input "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/TopKV2" is already normalized
[ 2020-05-06 17:08:42,024 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.non_max_suppression_normalize.TFNonMaxSuppressionNormalize'>
[ 2020-05-06 17:08:42,106 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.SwitchMergeOptimization.SwitchMergeOptimization'>
[ 2020-05-06 17:08:42,130 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.swish.Swish'>
[ 2020-05-06 17:08:42,208 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.swap_deconv_inputs.SwapDeconvInputs'>
[ 2020-05-06 17:08:42,232 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'>
[ 2020-05-06 17:08:42,236 ] [ DEBUG ] [ SqueezeNormalize:41 ]  The Squeeze node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/non_max_suppression/NonMaxSuppressionV3/Crop/Squeeze" is already normalized
[ 2020-05-06 17:08:42,257 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.split_normalizer.SplitInputsReconnect'>
[ 2020-05-06 17:08:42,281 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.softsign_replacer.SoftSign'>
[ 2020-05-06 17:08:42,360 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.SizeReplacer.SizeFrontReplacer'>
[ 2020-05-06 17:08:42,422 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size/Shape/ReduceProd/ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Equal with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:42,422 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size/Shape/ReduceProd/ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Assert/Assert with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:42,424 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size']
[ 2020-05-06 17:08:42,426 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size/Shape/ReduceProd/ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Equal with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:42,428 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size/Shape/ReduceProd/ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Assert/Assert with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:42,428 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size']
[ 2020-05-06 17:08:42,449 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.SSDToolboxDetectionOutput.SSDToolboxDetectionOutputReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'SSDToolboxDetectionOutput' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'SSDToolboxDetectionOutput'
[ 2020-05-06 17:08:42,471 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.RetinaNetFilteredDetectionsReplacement.RetinaNetFilteredDetectionsReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'RetinaNetFilteredDetectionsReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'RetinaNetFilteredDetectionsReplacement'
[ 2020-05-06 17:08:42,497 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'>
[ 2020-05-06 17:08:42,665 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.softmax.SoftmaxFromKeras'>
[ 2020-05-06 17:08:42,758 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.reciprocal.ReciprocalReplacer'>
[ 2020-05-06 17:08:42,834 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.fifo_replacer.QueueDequeueManyV2'>
[ 2020-05-06 17:08:42,911 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.prelu.PReLUWithAbs'>
[ 2020-05-06 17:08:42,994 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.prelu.PReLU'>
[ 2020-05-06 17:08:43,096 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.PowerToEltwises.PowerToEltwises'>
[ 2020-05-06 17:08:43,175 ] [ DEBUG ] [ eliminate:66 ]  The following nodes are seeded as output reachable:
[ 2020-05-06 17:08:43,331 ] [ DEBUG ] [ eliminate:136 ]  Removing the following dead nodes: MultipleGridAnchorGenerator/Sqrt
MultipleGridAnchorGenerator/Sqrt_1
MultipleGridAnchorGenerator/Sqrt_2
MultipleGridAnchorGenerator/Sqrt_3
MultipleGridAnchorGenerator/Sqrt_4
MultipleGridAnchorGenerator/Sqrt_5
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/zeros_like
Postprocessor/zeros_like
Postprocessor/zeros_like_1
[ 2020-05-06 17:08:43,359 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.mvn_unrolled.MVNUnrolled'>
[ 2020-05-06 17:08:43,359 ] [ DEBUG ] [ mvn_unrolled:38 ]  Enabled MVN replacement
[ 2020-05-06 17:08:43,435 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIOutputReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIOutputReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIOutputReplacement'
[ 2020-05-06 17:08:43,461 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIConstValueOverride'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIConstValueOverride' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIConstValueOverride'
[ 2020-05-06 17:08:43,488 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessorReplacement'>
[ 2020-05-06 17:08:43,504 ] [ DEBUG ] [ replacement:139 ]  replace_sub_graph: "ObjectDetectionAPIPreprocessorReplacement" matched nodes: Preprocessor/map/Const
Preprocessor/map/Shape
Preprocessor/map/TensorArray
Preprocessor/map/TensorArrayStack/TensorArrayGatherV3
Preprocessor/map/TensorArrayStack/TensorArraySizeV3
Preprocessor/map/TensorArrayStack/range
Preprocessor/map/TensorArrayStack/range/delta
Preprocessor/map/TensorArrayStack/range/start
Preprocessor/map/TensorArrayStack_1/TensorArrayGatherV3
Preprocessor/map/TensorArrayStack_1/TensorArraySizeV3
Preprocessor/map/TensorArrayStack_1/range
Preprocessor/map/TensorArrayStack_1/range/delta
Preprocessor/map/TensorArrayStack_1/range/start
Preprocessor/map/TensorArrayUnstack/Shape
Preprocessor/map/TensorArrayUnstack/TensorArrayScatter/TensorArrayScatterV3
Preprocessor/map/TensorArrayUnstack/range
Preprocessor/map/TensorArrayUnstack/range/delta
Preprocessor/map/TensorArrayUnstack/range/start
Preprocessor/map/TensorArrayUnstack/strided_slice
Preprocessor/map/TensorArrayUnstack/strided_slice/stack
Preprocessor/map/TensorArrayUnstack/strided_slice/stack_1
Preprocessor/map/TensorArrayUnstack/strided_slice/stack_2
Preprocessor/map/TensorArray_1
Preprocessor/map/TensorArray_2
Preprocessor/map/strided_slice
Preprocessor/map/strided_slice/stack
Preprocessor/map/strided_slice/stack_1
Preprocessor/map/strided_slice/stack_2
Preprocessor/map/while/Enter
Preprocessor/map/while/Enter_1
Preprocessor/map/while/Enter_2
Preprocessor/map/while/Enter_3
Preprocessor/map/while/Exit_2
Preprocessor/map/while/Exit_3
Preprocessor/map/while/Identity
Preprocessor/map/while/Identity_1
Preprocessor/map/while/Identity_2
Preprocessor/map/while/Identity_3
Preprocessor/map/while/Less
Preprocessor/map/while/Less/Enter
Preprocessor/map/while/Less_1
Preprocessor/map/while/LogicalAnd
Preprocessor/map/while/LoopCond
Preprocessor/map/while/Merge
Preprocessor/map/while/Merge_1
Preprocessor/map/while/Merge_2
Preprocessor/map/while/Merge_3
Preprocessor/map/while/NextIteration
Preprocessor/map/while/NextIteration_1
Preprocessor/map/while/NextIteration_2
Preprocessor/map/while/NextIteration_3
Preprocessor/map/while/ResizeImage/resize/ExpandDims
Preprocessor/map/while/ResizeImage/resize/ExpandDims/dim
Preprocessor/map/while/ResizeImage/resize/ResizeBilinear
Preprocessor/map/while/ResizeImage/resize/Squeeze
Preprocessor/map/while/ResizeImage/resize/Squeeze/Dims
Preprocessor/map/while/ResizeImage/stack
Preprocessor/map/while/ResizeImage/stack_1
Preprocessor/map/while/Switch
Preprocessor/map/while/Switch_1
Preprocessor/map/while/Switch_2
Preprocessor/map/while/Switch_3
Preprocessor/map/while/TensorArrayReadV3
Preprocessor/map/while/TensorArrayReadV3/Enter
Preprocessor/map/while/TensorArrayReadV3/Enter_1
Preprocessor/map/while/TensorArrayWrite/TensorArrayWriteV3
Preprocessor/map/while/TensorArrayWrite/TensorArrayWriteV3/Enter
Preprocessor/map/while/TensorArrayWrite_1/TensorArrayWriteV3
Preprocessor/map/while/TensorArrayWrite_1/TensorArrayWriteV3/Enter
Preprocessor/map/while/add
Preprocessor/map/while/add/y
Preprocessor/map/while/add_1
Preprocessor/map/while/add_1/y
Preprocessor/map/while/iteration_counter
Preprocessor/mul
Preprocessor/mul/x
Preprocessor/sub
Preprocessor/sub/y
[ 2020-05-06 17:08:43,508 ] [ DEBUG ] [ pipeline_config:118 ]  Found value "1" for path "num_classes"
[ 2020-05-06 17:08:43,508 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "224" for path "image_resizer/fixed_shape_resizer/height"
[ 2020-05-06 17:08:43,508 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "224" for path "image_resizer/fixed_shape_resizer/width"
[ 2020-05-06 17:08:43,509 ] [ DEBUG ] [ pipeline_config:129 ]  There is no value path "None". Set default value "256"
[ 2020-05-06 17:08:43,514 ] [ DEBUG ] [ pipeline_config:129 ]  There is no value path "None". Set default value "256"
[ 2020-05-06 17:08:43,516 ] [ DEBUG ] [ pipeline_config:129 ]  There is no value path "None". Set default value "16"
[ 2020-05-06 17:08:43,517 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "0.15" for path "anchor_generator/ssd_anchor_generator/min_scale"
[ 2020-05-06 17:08:43,518 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "0.95" for path "anchor_generator/ssd_anchor_generator/max_scale"
[ 2020-05-06 17:08:43,519 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "6" for path "anchor_generator/ssd_anchor_generator/num_layers"
[ 2020-05-06 17:08:43,520 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "[0.7, 1.0]" for path "anchor_generator/ssd_anchor_generator/aspect_ratios"
[ 2020-05-06 17:08:43,521 ] [ DEBUG ] [ pipeline_config:129 ]  There is no value path "None". Set default value "1.0"
[ 2020-05-06 17:08:43,522 ] [ DEBUG ] [ pipeline_config:129 ]  There is no value path "None". Set default value "1.0"
[ 2020-05-06 17:08:43,523 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "SIGMOID" for path ".*/score_converter"
[ 2020-05-06 17:08:43,524 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "1e-08" for path ".*/batch_non_max_suppression/score_threshold"
[ 2020-05-06 17:08:43,528 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "0.3" for path ".*/batch_non_max_suppression/iou_threshold"
[ 2020-05-06 17:08:43,528 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "100" for path ".*/batch_non_max_suppression/max_detections_per_class"
[ 2020-05-06 17:08:43,529 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "100" for path ".*/batch_non_max_suppression/max_total_detections"
[ 2020-05-06 17:08:43,529 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "10.0" for path "box_coder/faster_rcnn_box_coder/x_scale"
[ 2020-05-06 17:08:43,529 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "10.0" for path "box_coder/faster_rcnn_box_coder/y_scale"
[ 2020-05-06 17:08:43,530 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "5.0" for path "box_coder/faster_rcnn_box_coder/width_scale"
[ 2020-05-06 17:08:43,530 ] [ DEBUG ] [ pipeline_config:125 ]  Found value "5.0" for path "box_coder/faster_rcnn_box_coder/height_scale"
[ INFO ]  There is image scaling node in the Preprocessor block.
[ 2020-05-06 17:08:43,532 ] [ DEBUG ] [ ObjectDetectionAPI:415 ]  The model resizes image to a fixed shape: (224, 224)
The Preprocessor block has been removed. Only nodes performing mean value subtraction and scaling (if applicable) are kept.
[ 2020-05-06 17:08:43,532 ] [ DEBUG ] [ replacement:146 ]  replace_sub_graph: "ObjectDetectionAPIPreprocessorReplacement" removing nodes: Preprocessor/map/Const
[ 2020-05-06 17:08:43,554 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIProposalReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIProposalReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIProposalReplacement'
[ 2020-05-06 17:08:43,578 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.no_op_eraser.NoOpEraser'>
[ 2020-05-06 17:08:43,660 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.nearest_neighbor_upsampling.NearestNeighborUpsampling'>
[ 2020-05-06 17:08:43,765 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.FlattenToReshape.FlattenToReshapeableReshape'>
[ 2020-05-06 17:08:43,835 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,838 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,842 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,843 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,844 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,845 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,848 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,849 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,853 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,855 ] [ DEBUG ] [ FlattenToReshape:78 ]  The pattern does not correspond to flatten. The "Pack" operation produces tensor with 3 items but should produce just 2.
[ 2020-05-06 17:08:43,876 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.Pack.Pack'>
[ 2020-05-06 17:08:43,939 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Pad_5 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,939 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5']
[ 2020-05-06 17:08:43,943 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_3/Reshape/shape/Concat_ to BoxPredictor_3/Reshape with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_3/Reshape/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,943 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_3/Reshape/shape']
[ 2020-05-06 17:08:43,945 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/values_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/ExpandDims_2817 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:43,945 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/values_1']
[ 2020-05-06 17:08:43,947 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Tile/multiples/Concat_ to Postprocessor/Tile with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Tile/multiples', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,948 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Tile/multiples']
[ 2020-05-06 17:08:43,949 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/values_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/values_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,951 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/values_1']
[ 2020-05-06 17:08:43,957 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4 with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,958 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size']
[ 2020-05-06 17:08:43,960 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_0/Reshape_1/shape/Concat_ to BoxPredictor_0/Reshape_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_0/Reshape_1/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,961 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_0/Reshape_1/shape']
[ 2020-05-06 17:08:43,963 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_1/Concat_ to MultipleGridAnchorGenerator/Reshape_1 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,965 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_1']
[ 2020-05-06 17:08:43,967 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_0/Reshape/shape/Concat_ to BoxPredictor_0/Reshape with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_0/Reshape/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,968 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_0/Reshape/shape']
[ 2020-05-06 17:08:43,971 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_5/Reshape/shape/Concat_ to BoxPredictor_5/Reshape with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_5/Reshape/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,972 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_5/Reshape/shape']
[ 2020-05-06 17:08:43,973 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_1/size/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_1 with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_1/size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,976 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_1/size']
[ 2020-05-06 17:08:43,978 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Pad_4 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,978 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4']
[ 2020-05-06 17:08:43,980 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_3/Reshape_1/shape/Concat_ to BoxPredictor_3/Reshape_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_3/Reshape_1/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,981 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_3/Reshape_1/shape']
[ 2020-05-06 17:08:43,984 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:43,988 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1']
[ 2020-05-06 17:08:44,007 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/stack/Concat_ to Postprocessor/Reshape_2 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/stack', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,008 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/stack']
[ 2020-05-06 17:08:44,013 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,014 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack']
[ 2020-05-06 17:08:44,015 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_10/Concat_ to MultipleGridAnchorGenerator/Reshape_10 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_10', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,016 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_10']
[ 2020-05-06 17:08:44,019 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Pad with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,020 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack']
[ 2020-05-06 17:08:44,025 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,026 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack']
[ 2020-05-06 17:08:44,030 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/stack/Concat_ to Postprocessor/Decode/transpose_1 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/stack', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,030 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/stack']
[ 2020-05-06 17:08:44,032 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Pad_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,033 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1']
[ 2020-05-06 17:08:44,035 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_4/Reshape/shape/Concat_ to BoxPredictor_4/Reshape with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_4/Reshape/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,035 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_4/Reshape/shape']
[ 2020-05-06 17:08:44,037 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_8/Concat_ to MultipleGridAnchorGenerator/Reshape_8 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_8', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,043 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_8']
[ 2020-05-06 17:08:44,044 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_5/size/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_5 with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_5/size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,044 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_5/size']
[ 2020-05-06 17:08:44,046 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_1/Reshape/shape/Concat_ to BoxPredictor_1/Reshape with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_1/Reshape/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,048 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_1/Reshape/shape']
[ 2020-05-06 17:08:44,050 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_2/Reshape_1/shape/Concat_ to BoxPredictor_2/Reshape_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_2/Reshape_1/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,053 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_2/Reshape_1/shape']
[ 2020-05-06 17:08:44,056 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/stack_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/Shape with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/stack_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,056 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/stack_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/TensorArrayScatter/TensorArrayScatterV3 with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/stack_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,057 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/stack_1']
[ 2020-05-06 17:08:44,060 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack/Concat_ to MultipleGridAnchorGenerator/Reshape with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,062 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack']
[ 2020-05-06 17:08:44,064 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_3/Concat_ to MultipleGridAnchorGenerator/Reshape_3 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_3', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,064 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_3']
[ 2020-05-06 17:08:44,066 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_2/Reshape/shape/Concat_ to BoxPredictor_2/Reshape with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_2/Reshape/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,068 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_2/Reshape/shape']
[ 2020-05-06 17:08:44,075 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_5/Reshape_1/shape/Concat_ to BoxPredictor_5/Reshape_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_5/Reshape_1/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,076 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_5/Reshape_1/shape']
[ 2020-05-06 17:08:44,079 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_4/Reshape_1/shape/Concat_ to BoxPredictor_4/Reshape_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_4/Reshape_1/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,080 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_4/Reshape_1/shape']
[ 2020-05-06 17:08:44,082 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/ones/packed/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/ones with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/ones/packed', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,085 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/ones/packed']
[ 2020-05-06 17:08:44,087 ] [ DEBUG ] [ replacement:114 ]  Created edge from BoxPredictor_1/Reshape_1/shape/Concat_ to BoxPredictor_1/Reshape_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('BoxPredictor_1/Reshape_1/shape', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,088 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['BoxPredictor_1/Reshape_1/shape']
[ 2020-05-06 17:08:44,091 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_9/Concat_ to MultipleGridAnchorGenerator/Reshape_9 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_9', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,092 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_9']
[ 2020-05-06 17:08:44,095 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_11/Concat_ to MultipleGridAnchorGenerator/Reshape_11 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_11', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,096 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_11']
[ 2020-05-06 17:08:44,097 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_4 with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,097 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4']
[ 2020-05-06 17:08:44,099 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_5/Concat_ to MultipleGridAnchorGenerator/Reshape_5 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_5', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,101 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_5']
[ 2020-05-06 17:08:44,107 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_7/Concat_ to MultipleGridAnchorGenerator/Reshape_7 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_7', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,108 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_7']
[ 2020-05-06 17:08:44,110 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,111 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y']
[ 2020-05-06 17:08:44,112 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,115 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size']
[ 2020-05-06 17:08:44,116 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/values_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/ExpandDims_2855 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:44,117 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/values_1']
[ 2020-05-06 17:08:44,118 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_4/Concat_ to MultipleGridAnchorGenerator/Reshape_4 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,119 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_4']
[ 2020-05-06 17:08:44,123 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1/Concat_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1 with attrs: {'in': 2, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,125 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1']
[ 2020-05-06 17:08:44,127 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_6/Concat_ to MultipleGridAnchorGenerator/Reshape_6 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_6', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,127 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_6']
[ 2020-05-06 17:08:44,129 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/stack_2/Concat_ to MultipleGridAnchorGenerator/Reshape_2 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/stack_2', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:44,129 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/stack_2']
[ 2020-05-06 17:08:44,150 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'>
[ 2020-05-06 17:08:44,255 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.mvn.MVNReplacer'>
[ 2020-05-06 17:08:44,256 ] [ DEBUG ] [ mvn:33 ]  Enabled MVN replacement
[ INFO ]  Skip replacer <class 'extensions.front.squared_difference.SquaredDifference'> (graph_condition not satisfied)
[ 2020-05-06 17:08:44,339 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.LogSoftmax.LogSoftmaxFrontReplacer'>
[ 2020-05-06 17:08:44,428 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.Log1p.Log1p'>
[ INFO ]  Skip replacer <class 'extensions.front.LRNReplacer.LRNReplacer'> (graph_condition not satisfied)
[ 2020-05-06 17:08:44,521 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.InterpolateTransposes.InterpolateTranspose'>
[ WARNING ]  Configuration file for custom replacement with id 'InterpolateTranspose' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'InterpolateTranspose'
[ 2020-05-06 17:08:44,549 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'>
[ 2020-05-06 17:08:44,639 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.instance_normalization.InstanceNormalization'>
[ 2020-05-06 17:08:44,729 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.image_scaler.ImageScaler'>
[ 2020-05-06 17:08:44,822 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.global_pooling_to_reduce.GlobalPoolingToReduce'>
[ 2020-05-06 17:08:44,846 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.MatMul_normalizer.GemmDecomposer'>
[ 2020-05-06 17:08:44,937 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.GNMT_DynamicSequenceLengths.GNMT_sequence_lengths'>
[ 2020-05-06 17:08:44,937 ] [ DEBUG ] [ GNMT_DynamicSequenceLengths:42 ]  +++++++++++++++ GNMT Sequence Lengths ConditionMatching ++++++++++++++++
[ 2020-05-06 17:08:45,072 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.MatMul_normalizer.FullyConnectedDecomposer'>
[ 2020-05-06 17:08:45,166 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.flatten_to_reshape.FlattenToReshape'>
[ 2020-05-06 17:08:45,258 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.rank_decomposer.RankDecomposer'>
[ 2020-05-06 17:08:45,351 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.FillToBroadcast.FillToBroadcast'>
[ 2020-05-06 17:08:45,421 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'>
[ 2020-05-06 17:08:45,523 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>
[ INFO ]  Node "Postprocessor/ToFloat" does not exist in the graph. Failed to match sub-graph by points "ObjectDetectionAPISSDPostprocessorReplacement".
[ ERROR ]  Failed to match nodes from custom replacement description with id 'ObjectDetectionAPISSDPostprocessorReplacement':
It means model and custom replacement description are incompatible.
Try to correct custom replacement description according to documentation with respect to model node names
[ 2020-05-06 17:08:45,549 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'>
[ 2020-05-06 17:08:45,725 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.YOLO.YoloRegionAddon'>
[ WARNING ]  Configuration file for custom replacement with id 'TFYOLO' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'TFYOLO'
[ 2020-05-06 17:08:45,749 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'>
[ 2020-05-06 17:08:45,836 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.fake_const_ext.FakeConstToConst'>
[ 2020-05-06 17:08:45,924 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.fifo_replacer.FIFOQueue'>
[ 2020-05-06 17:08:46,011 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.override_batch.OverrideBatch'>
[ 2020-05-06 17:08:46,033 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.sparse_weighted_sum.ExperimentalSparseWeightedSumFrontReplacer2'>
[ 2020-05-06 17:08:46,033 ] [ DEBUG ] [ sparse_weighted_sum:113 ]  Enabled ExperimentalSparseWeightedSum2 replacement
[ 2020-05-06 17:08:46,154 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.sparse_weighted_sum.ExperimentalSparseWeightedSumFrontReplacer'>
[ 2020-05-06 17:08:46,154 ] [ DEBUG ] [ sparse_weighted_sum:35 ]  Enabled ExperimentalSparseWeightedSum replacement
[ 2020-05-06 17:08:46,267 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.eltwise_n.EltwiseNReplacement'>
[ 2020-05-06 17:08:46,359 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.div.Div'>
[ 2020-05-06 17:08:46,433 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_7/mul_ to MultipleGridAnchorGenerator/mul_7 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_7', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,433 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_7/mul_ to MultipleGridAnchorGenerator/mul_42 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_7', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,439 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_7']
[ 2020-05-06 17:08:46,442 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv_1/mul_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/Scale/mul_2 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,442 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv_1/mul_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/Scale/mul_3 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,443 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv_1']
[ 2020-05-06 17:08:46,445 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_4/mul_ to MultipleGridAnchorGenerator/mul_4 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,446 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_4/mul_ to MultipleGridAnchorGenerator/mul_33 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,448 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_4']
[ 2020-05-06 17:08:46,450 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv/mul_ to Postprocessor/Decode/mul_2 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,450 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv']
[ 2020-05-06 17:08:46,451 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv/mul_ to MultipleGridAnchorGenerator/mul with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,452 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv/mul_ to MultipleGridAnchorGenerator/mul_17 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,453 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv']
[ 2020-05-06 17:08:46,471 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_1/mul_ to Postprocessor/Decode/mul_3 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,472 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_1']
[ 2020-05-06 17:08:46,474 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_5/mul_ to MultipleGridAnchorGenerator/mul_5 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_5', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,474 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_5/mul_ to MultipleGridAnchorGenerator/mul_34 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_5', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,475 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_5']
[ 2020-05-06 17:08:46,476 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_1/mul_ to MultipleGridAnchorGenerator/mul_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,477 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_1/mul_ to MultipleGridAnchorGenerator/mul_18 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,477 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_1']
[ 2020-05-06 17:08:46,479 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_17/mul_ to MultipleGridAnchorGenerator/mul_38 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_17', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,480 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_17']
[ 2020-05-06 17:08:46,485 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_4/mul_ to Postprocessor/Decode/sub with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,486 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_4']
[ 2020-05-06 17:08:46,487 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/truediv_1/mul_ to Postprocessor/Decode/get_center_coordinates_and_sizes/add_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/get_center_coordinates_and_sizes/truediv_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,487 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/get_center_coordinates_and_sizes/truediv_1']
[ 2020-05-06 17:08:46,489 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_7/mul_ to Postprocessor/Decode/add_3 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_7', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,491 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_7']
[ 2020-05-06 17:08:46,495 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/truediv/mul_ to Postprocessor/Decode/get_center_coordinates_and_sizes/add with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/get_center_coordinates_and_sizes/truediv', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,495 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/get_center_coordinates_and_sizes/truediv']
[ 2020-05-06 17:08:46,497 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_3/mul_ to Postprocessor/Decode/Exp with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_3', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,497 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_3']
[ 2020-05-06 17:08:46,498 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_3/mul_ to MultipleGridAnchorGenerator/mul_3 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_3', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,499 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_3/mul_ to MultipleGridAnchorGenerator/mul_26 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_3', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,505 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_3']
[ 2020-05-06 17:08:46,507 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_12/mul_ to MultipleGridAnchorGenerator/mul_12 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_12', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,508 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_12']
[ 2020-05-06 17:08:46,509 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_2/mul_ to MultipleGridAnchorGenerator/mul_2 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_2', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,509 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_2/mul_ to MultipleGridAnchorGenerator/mul_25 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_2', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,510 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_2']
[ 2020-05-06 17:08:46,511 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_8/mul_ to MultipleGridAnchorGenerator/mul_8 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_8', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,511 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_8/mul_ to MultipleGridAnchorGenerator/mul_49 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_8', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,512 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_8']
[ 2020-05-06 17:08:46,513 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_9/mul_ to MultipleGridAnchorGenerator/mul_9 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_9', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,513 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_9/mul_ to MultipleGridAnchorGenerator/mul_50 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_9', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,517 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_9']
[ 2020-05-06 17:08:46,522 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_14/mul_ to MultipleGridAnchorGenerator/mul_14 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_14', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,522 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_14']
[ 2020-05-06 17:08:46,523 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv/mul_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/Scale/mul with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,524 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv/mul_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/Scale/mul_1 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,524 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv']
[ 2020-05-06 17:08:46,526 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_6/mul_ to MultipleGridAnchorGenerator/mul_6 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_6', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,527 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_6/mul_ to MultipleGridAnchorGenerator/mul_41 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_6', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,531 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_6']
[ 2020-05-06 17:08:46,532 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_11/mul_ to MultipleGridAnchorGenerator/mul_11 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_11', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,532 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_11/mul_ to MultipleGridAnchorGenerator/mul_58 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_11', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,533 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_11']
[ 2020-05-06 17:08:46,534 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_6/mul_ to Postprocessor/Decode/add_2 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_6', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,535 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_6']
[ 2020-05-06 17:08:46,537 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_2/mul_ to Postprocessor/Decode/Exp_1 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_2', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,542 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_2']
[ 2020-05-06 17:08:46,545 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_15/mul_ to MultipleGridAnchorGenerator/mul_22 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_15', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,545 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_15']
[ 2020-05-06 17:08:46,548 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_13/mul_ to MultipleGridAnchorGenerator/mul_13 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_13', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,549 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_13']
[ 2020-05-06 17:08:46,553 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_19/mul_ to MultipleGridAnchorGenerator/mul_54 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_19', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,556 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_19']
[ 2020-05-06 17:08:46,558 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/truediv_1/mul_ to Postprocessor/stack_1/ExpandDims_29113113 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,559 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/truediv_1']
[ 2020-05-06 17:08:46,560 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/scale_logits/mul_ to Postprocessor/convert_scores with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/scale_logits', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,563 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/scale_logits']
[ 2020-05-06 17:08:46,565 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/truediv_5/mul_ to Postprocessor/Decode/sub_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/truediv_5', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,565 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/truediv_5']
[ 2020-05-06 17:08:46,566 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_10/mul_ to MultipleGridAnchorGenerator/mul_10 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_10', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,566 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_10/mul_ to MultipleGridAnchorGenerator/mul_57 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_10', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,567 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_10']
[ 2020-05-06 17:08:46,573 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_18/mul_ to MultipleGridAnchorGenerator/mul_46 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_18', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,574 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_18']
[ 2020-05-06 17:08:46,575 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/truediv/mul_ to Postprocessor/stack_1/ExpandDims_29103111 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,575 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/truediv']
[ 2020-05-06 17:08:46,577 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/truediv_16/mul_ to MultipleGridAnchorGenerator/mul_30 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/truediv_16', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,577 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/truediv_16']
[ 2020-05-06 17:08:46,603 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.CropAndResizeReplacement.CropAndResizeReplacement'>
[ 2020-05-06 17:08:46,693 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIDetectionOutputReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIDetectionOutputReplacement'
[ 2020-05-06 17:08:46,722 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'>
[ 2020-05-06 17:08:46,814 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPSROIPoolingReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIPSROIPoolingReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIPSROIPoolingReplacement'
[ 2020-05-06 17:08:46,846 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.sub.Sub'>
[ 2020-05-06 17:08:46,920 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/sub/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/mul with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,920 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/sub']
[ 2020-05-06 17:08:46,923 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/sub/add_ to Postprocessor/Decode/stack/ExpandDims_3067 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,924 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/sub']
[ 2020-05-06 17:08:46,927 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,927 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub']
[ 2020-05-06 17:08:46,929 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_1/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv_1/reciprocal_ with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,929 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_1']
[ 2020-05-06 17:08:46,931 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_15/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater_8 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_15', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,936 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_15']
[ 2020-05-06 17:08:46,938 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/Scale/split with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,939 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2']
[ 2020-05-06 17:08:46,940 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/sub_1/add_ to MultipleGridAnchorGenerator/concat_1 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/sub_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,941 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/sub_1']
[ 2020-05-06 17:08:46,943 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/sub_1/add_ to Postprocessor/Decode/stack/ExpandDims_28823069 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,946 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/sub_1']
[ 2020-05-06 17:08:46,947 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/sub_3/add_ to MultipleGridAnchorGenerator/concat_3 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/sub_3', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,947 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/sub_3']
[ 2020-05-06 17:08:46,949 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/sub_4/add_ to MultipleGridAnchorGenerator/concat_4 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/sub_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,949 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/sub_4']
[ 2020-05-06 17:08:46,950 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_18/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater_9 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_18', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,955 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_18']
[ 2020-05-06 17:08:46,956 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/sub_1/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/mul with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/sub_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,957 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/sub_1']
[ 2020-05-06 17:08:46,958 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/sub/add_ to Postprocessor/Decode/mul with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/get_center_coordinates_and_sizes/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,959 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/sub/add_ to Postprocessor/Decode/mul_3 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/get_center_coordinates_and_sizes/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,959 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/sub/add_ to Postprocessor/Decode/get_center_coordinates_and_sizes/truediv_1/mul_ with attrs: {'in': 1, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,960 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/get_center_coordinates_and_sizes/sub']
[ 2020-05-06 17:08:46,961 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_16/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/values_1/ExpandDims_3183 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,962 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_16']
[ 2020-05-06 17:08:46,963 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_4/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater_2 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_4', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,966 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_4']
[ 2020-05-06 17:08:46,970 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/sub/add_ to MultipleGridAnchorGenerator/concat with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,970 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/sub']
[ 2020-05-06 17:08:46,971 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_5/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/values_1/ExpandDims_2995 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,972 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_5']
[ 2020-05-06 17:08:46,973 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv/reciprocal_ with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,974 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub']
[ 2020-05-06 17:08:46,978 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_14/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater_7 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_14', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,980 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_14']
[ 2020-05-06 17:08:46,981 ] [ DEBUG ] [ replacement:114 ]  Created edge from Preprocessor/sub/add_ to FeatureExtractor/MobilenetV2/MobilenetV2/input with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Preprocessor/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,981 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Preprocessor/sub']
[ 2020-05-06 17:08:46,983 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_2/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1/ExpandDims_3039 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,983 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_2']
[ 2020-05-06 17:08:46,984 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/sub_5/add_ to MultipleGridAnchorGenerator/concat_5 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/sub_5', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,988 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/sub_5']
[ 2020-05-06 17:08:46,990 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1/add_ to Postprocessor/Decode/mul_1 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,990 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1/add_ to Postprocessor/Decode/mul_2 with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,991 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1/add_ to Postprocessor/Decode/get_center_coordinates_and_sizes/truediv/mul_ with attrs: {'in': 1, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:46,991 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1']
[ 2020-05-06 17:08:46,992 ] [ DEBUG ] [ replacement:114 ]  Created edge from MultipleGridAnchorGenerator/sub_2/add_ to MultipleGridAnchorGenerator/concat_2 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('MultipleGridAnchorGenerator/sub_2', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,993 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['MultipleGridAnchorGenerator/sub_2']
[ 2020-05-06 17:08:46,994 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/sub_1/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/mul with attrs: {'in': 1, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/sub_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,995 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/sub_1']
[ 2020-05-06 17:08:46,996 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/sub/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/zeros/Reshape with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:46,996 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/sub']
[ 2020-05-06 17:08:46,997 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_3/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1/ExpandDims_28623041 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:47,000 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_3']
[ 2020-05-06 17:08:47,004 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_17/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/values_1/ExpandDims_29623185 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:47,004 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_17']
[ 2020-05-06 17:08:47,005 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_19/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/values_1/ExpandDims_2987 with attrs: {'in': 0, 'out': 0, 'in_attrs': ['in', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info']}
[ 2020-05-06 17:08:47,006 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_19']
[ 2020-05-06 17:08:47,007 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_1/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater_1 with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_1', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:47,007 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/sub_1']
[ 2020-05-06 17:08:47,011 ] [ DEBUG ] [ replacement:114 ]  Created edge from Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/sub/add_ to Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/mul with attrs: {'in': 0, 'out': 0, 'fw_tensor_debug_info': [('Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/sub', 0)], 'in_attrs': ['in', 'control_flow_edge', 'permutation'], 'out_attrs': ['out', 'permutation'], 'data_attrs': ['fw_tensor_debug_info'], 'control_flow_edge': False}
[ 2020-05-06 17:08:47,013 ] [ DEBUG ] [ replacement:230 ]  Removing nodes: ['Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/sub']
[ 2020-05-06 17:08:47,036 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.split_normalizer.SqueezeAxis'>
[ 2020-05-06 17:08:47,073 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement'
[ 2020-05-06 17:08:47,102 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNSigmoidReplacement'>
[ WARNING ]  Configuration file for custom replacement with id 'ObjectDetectionAPIMaskRCNNSigmoidReplacement' doesn't exist
[ INFO ]  Failed to find custom replacement description with id 'ObjectDetectionAPIMaskRCNNSigmoidReplacement'
[ 2020-05-06 17:08:47,134 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.concat.Concat'>
[ 2020-05-06 17:08:47,227 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.ChangePlaceholderTypes.ChangePlaceholderTypes'>
[ 2020-05-06 17:08:47,230 ] [ DEBUG ] [ ChangePlaceholderTypes:37 ]  Convert data type of Parameter "image_tensor" to float32
[ 2020-05-06 17:08:47,230 ] [ DEBUG ] [ ChangePlaceholderTypes:41 ]  Removing "Convert" node "Cast"
[ 2020-05-06 17:08:47,257 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.ChangeCastOutputType.ChangeCastOutputType'>
[ 2020-05-06 17:08:47,351 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.CTCGreedyDecoder.CTCGreedyDecoderReplacement'>
[ 2020-05-06 17:08:47,435 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.bucketize.BucketizeFrontReplacer'>
[ 2020-05-06 17:08:47,461 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.BlockLSTM.BlockLSTM'>
[ 2020-05-06 17:08:47,551 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'>
[ 2020-05-06 17:08:47,793 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.BatchToSpaceNDToUpsample.BatchToSpaceNDToUpsample'>
[ 2020-05-06 17:08:47,884 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.split_normalizer.AttributedVariadicSplitToVariadicSplit'>
[ 2020-05-06 17:08:47,909 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.split_normalizer.AttributedSplitToSplit'>
[ 2020-05-06 17:08:47,941 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.basic_lstm_cell.BasicLSTMCell'>
[ 2020-05-06 17:08:48,194 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.AttributedGatherNormalizer.AttributedGatherNormalizer'>
[ 2020-05-06 17:08:48,284 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.assign_elimination.AssignSubElimination'>
[ 2020-05-06 17:08:48,375 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.assign_elimination.AssignElimination'>
[ 2020-05-06 17:08:48,470 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.assign_elimination.AssignAddElimination'>
[ 2020-05-06 17:08:48,572 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.tf.assign_elimination.AssertElimination'>
[ 2020-05-06 17:08:48,642 ] [ DEBUG ] [ assign_elimination:81 ]  Assert op was removed Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Assert/Assert
[ 2020-05-06 17:08:48,643 ] [ DEBUG ] [ assign_elimination:81 ]  Assert op was removed MultipleGridAnchorGenerator/assert_equal/Assert/Assert
[ 2020-05-06 17:08:48,644 ] [ DEBUG ] [ assign_elimination:81 ]  Assert op was removed Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Assert/Assert
[ 2020-05-06 17:08:48,673 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'>
[ 2020-05-06 17:08:48,767 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.pass_separator.FrontFinish'>
[ 2020-05-06 17:08:48,790 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'>
[ 2020-05-06 17:08:48,966 ] [ DEBUG ] [ eliminate:66 ]  The following nodes are seeded as output reachable:
detection_boxes/sink_port_0
detection_classes/sink_port_0
detection_multiclass_scores/sink_port_0
detection_scores/sink_port_0
num_detections/sink_port_0
raw_detection_boxes/sink_port_0
raw_detection_scores/sink_port_0
[ 2020-05-06 17:08:49,395 ] [ DEBUG ] [ eliminate:136 ]  Removing the following dead nodes: 2793
2793/Output_0/Data_
2796
2796/Output_0/Data_
BoxPredictor_0/Reshape/shape/ExpandDims_
BoxPredictor_0/Reshape/shape/ExpandDims_2843
BoxPredictor_0/Reshape/shape/ExpandDims_2844
BoxPredictor_0/Reshape/shape/ExpandDims_2845
BoxPredictor_0/Reshape_1/shape/ExpandDims_
BoxPredictor_0/Reshape_1/shape/ExpandDims_2836
BoxPredictor_0/Reshape_1/shape/ExpandDims_2837
BoxPredictor_1/Reshape/shape/ExpandDims_
BoxPredictor_1/Reshape/shape/ExpandDims_2900
BoxPredictor_1/Reshape/shape/ExpandDims_2901
BoxPredictor_1/Reshape/shape/ExpandDims_2902
BoxPredictor_1/Reshape_1/shape/ExpandDims_
BoxPredictor_1/Reshape_1/shape/ExpandDims_2935
BoxPredictor_1/Reshape_1/shape/ExpandDims_2936
BoxPredictor_2/Reshape/shape/ExpandDims_
BoxPredictor_2/Reshape/shape/ExpandDims_2920
BoxPredictor_2/Reshape/shape/ExpandDims_2921
BoxPredictor_2/Reshape/shape/ExpandDims_2922
BoxPredictor_2/Reshape_1/shape/ExpandDims_
BoxPredictor_2/Reshape_1/shape/ExpandDims_2905
BoxPredictor_2/Reshape_1/shape/ExpandDims_2906
BoxPredictor_3/Reshape/shape/ExpandDims_
BoxPredictor_3/Reshape/shape/ExpandDims_2820
BoxPredictor_3/Reshape/shape/ExpandDims_2821
BoxPredictor_3/Reshape/shape/ExpandDims_2822
BoxPredictor_3/Reshape_1/shape/ExpandDims_
BoxPredictor_3/Reshape_1/shape/ExpandDims_2858
BoxPredictor_3/Reshape_1/shape/ExpandDims_2859
BoxPredictor_4/Reshape/shape/ExpandDims_
BoxPredictor_4/Reshape/shape/ExpandDims_2890
BoxPredictor_4/Reshape/shape/ExpandDims_2891
BoxPredictor_4/Reshape/shape/ExpandDims_2892
BoxPredictor_4/Reshape_1/shape/ExpandDims_
BoxPredictor_4/Reshape_1/shape/ExpandDims_2929
BoxPredictor_4/Reshape_1/shape/ExpandDims_2930
BoxPredictor_5/Reshape/shape/ExpandDims_
BoxPredictor_5/Reshape/shape/ExpandDims_2848
BoxPredictor_5/Reshape/shape/ExpandDims_2849
BoxPredictor_5/Reshape/shape/ExpandDims_2850
BoxPredictor_5/Reshape_1/shape/ExpandDims_
BoxPredictor_5/Reshape_1/shape/ExpandDims_2925
BoxPredictor_5/Reshape_1/shape/ExpandDims_2926
MultipleGridAnchorGenerator/Meshgrid/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_1/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_1/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_10/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_10/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_11/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_11/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_12/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_12/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_13/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_13/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_14/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_14/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_15/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_15/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_16/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_16/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_17/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_17/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_2/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_2/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_3/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_3/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_4/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_4/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_5/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_5/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_6/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_6/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_7/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_7/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_8/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_8/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Meshgrid_9/ExpandedShape/ones
MultipleGridAnchorGenerator/Meshgrid_9/ExpandedShape_1/ones
MultipleGridAnchorGenerator/Shape
MultipleGridAnchorGenerator/Shape/Output_0/Data_
MultipleGridAnchorGenerator/Shape_1
MultipleGridAnchorGenerator/Shape_1/Output_0/Data_
MultipleGridAnchorGenerator/Shape_2
MultipleGridAnchorGenerator/Shape_2/Output_0/Data_
MultipleGridAnchorGenerator/Shape_3
MultipleGridAnchorGenerator/Shape_3/Output_0/Data_
MultipleGridAnchorGenerator/Shape_4
MultipleGridAnchorGenerator/Shape_4/Output_0/Data_
MultipleGridAnchorGenerator/Shape_5
MultipleGridAnchorGenerator/Shape_5/Output_0/Data_
MultipleGridAnchorGenerator/add_18
MultipleGridAnchorGenerator/add_18/Output_0/Data_
MultipleGridAnchorGenerator/add_18/x
MultipleGridAnchorGenerator/add_18/x/Output_0/Data_
MultipleGridAnchorGenerator/add_19
MultipleGridAnchorGenerator/add_19/Output_0/Data_
MultipleGridAnchorGenerator/add_20
MultipleGridAnchorGenerator/add_20/Output_0/Data_
MultipleGridAnchorGenerator/add_21
MultipleGridAnchorGenerator/add_21/Output_0/Data_
MultipleGridAnchorGenerator/add_22
MultipleGridAnchorGenerator/add_22/Output_0/Data_
MultipleGridAnchorGenerator/add_23
MultipleGridAnchorGenerator/add_23/Output_0/Data_
MultipleGridAnchorGenerator/assert_equal/All
MultipleGridAnchorGenerator/assert_equal/Assert/Assert/data_0
MultipleGridAnchorGenerator/assert_equal/Assert/Assert/data_1
MultipleGridAnchorGenerator/assert_equal/Assert/Assert/data_2
MultipleGridAnchorGenerator/assert_equal/Assert/Assert/data_4
MultipleGridAnchorGenerator/assert_equal/Const
MultipleGridAnchorGenerator/assert_equal/Const/Output_0/Data_
MultipleGridAnchorGenerator/assert_equal/Equal
MultipleGridAnchorGenerator/assert_equal/Equal/Output_0/Data_
MultipleGridAnchorGenerator/assert_equal/x
MultipleGridAnchorGenerator/assert_equal/x/Output_0/Data_
MultipleGridAnchorGenerator/stack/ExpandDims_
MultipleGridAnchorGenerator/stack/ExpandDims_2914
MultipleGridAnchorGenerator/stack_1/ExpandDims_
MultipleGridAnchorGenerator/stack_1/ExpandDims_2840
MultipleGridAnchorGenerator/stack_10/ExpandDims_
MultipleGridAnchorGenerator/stack_10/ExpandDims_2873
MultipleGridAnchorGenerator/stack_11/ExpandDims_
MultipleGridAnchorGenerator/stack_11/ExpandDims_2942
MultipleGridAnchorGenerator/stack_2/ExpandDims_
MultipleGridAnchorGenerator/stack_2/ExpandDims_2974
MultipleGridAnchorGenerator/stack_3/ExpandDims_
MultipleGridAnchorGenerator/stack_3/ExpandDims_2917
MultipleGridAnchorGenerator/stack_4/ExpandDims_
MultipleGridAnchorGenerator/stack_4/ExpandDims_2965
MultipleGridAnchorGenerator/stack_5/ExpandDims_
MultipleGridAnchorGenerator/stack_5/ExpandDims_2948
MultipleGridAnchorGenerator/stack_6/ExpandDims_
MultipleGridAnchorGenerator/stack_6/ExpandDims_2971
MultipleGridAnchorGenerator/stack_7/ExpandDims_
MultipleGridAnchorGenerator/stack_7/ExpandDims_2951
MultipleGridAnchorGenerator/stack_8/ExpandDims_
MultipleGridAnchorGenerator/stack_8/ExpandDims_2895
MultipleGridAnchorGenerator/stack_9/ExpandDims_
MultipleGridAnchorGenerator/stack_9/ExpandDims_2939
MultipleGridAnchorGenerator/strided_slice
MultipleGridAnchorGenerator/strided_slice/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice/stack
MultipleGridAnchorGenerator/strided_slice/stack/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice/stack_1
MultipleGridAnchorGenerator/strided_slice/stack_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice/stack_2
MultipleGridAnchorGenerator/strided_slice/stack_2/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_1
MultipleGridAnchorGenerator/strided_slice_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_1/stack
MultipleGridAnchorGenerator/strided_slice_1/stack/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_1/stack_1
MultipleGridAnchorGenerator/strided_slice_1/stack_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_1/stack_2
MultipleGridAnchorGenerator/strided_slice_1/stack_2/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_2
MultipleGridAnchorGenerator/strided_slice_2/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_2/stack
MultipleGridAnchorGenerator/strided_slice_2/stack/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_2/stack_1
MultipleGridAnchorGenerator/strided_slice_2/stack_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_2/stack_2
MultipleGridAnchorGenerator/strided_slice_2/stack_2/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_3
MultipleGridAnchorGenerator/strided_slice_3/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_3/stack
MultipleGridAnchorGenerator/strided_slice_3/stack/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_3/stack_1
MultipleGridAnchorGenerator/strided_slice_3/stack_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_3/stack_2
MultipleGridAnchorGenerator/strided_slice_3/stack_2/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_4
MultipleGridAnchorGenerator/strided_slice_4/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_4/stack
MultipleGridAnchorGenerator/strided_slice_4/stack/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_4/stack_1
MultipleGridAnchorGenerator/strided_slice_4/stack_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_4/stack_2
MultipleGridAnchorGenerator/strided_slice_4/stack_2/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_5
MultipleGridAnchorGenerator/strided_slice_5/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_5/stack
MultipleGridAnchorGenerator/strided_slice_5/stack/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_5/stack_1
MultipleGridAnchorGenerator/strided_slice_5/stack_1/Output_0/Data_
MultipleGridAnchorGenerator/strided_slice_5/stack_2
MultipleGridAnchorGenerator/strided_slice_5/stack_2/Output_0/Data_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_2954
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_2955
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_2956
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Assert/Assert/data_0
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Equal
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size/Shape/
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size/Shape//Output_0/Data_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size/Shape/ReduceProd/
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField/Size/Shape/ReduceProd//Output_0/Data_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Assert/Assert/data_0
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Equal
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size/Shape/
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size/Shape//Output_0/Data_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size/Shape/ReduceProd/
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/SortByField_1/Size/Shape/ReduceProd//Output_0/Data_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ones
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ones_1
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_2879
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size/ExpandDims_2959
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_1/size/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size/ExpandDims_2833
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_5/size/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/ExpandDims_2876
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/ExpandDims_2887
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/ExpandDims_2855
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/ExpandDims_2817
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_1
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_10
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_11
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_2
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_3
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_8
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/zeros_9
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/ExpandDims_2869
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/ExpandDims_2870
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1/ExpandDims_2968
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4/ExpandDims_
Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4/ExpandDims_2945
Postprocessor/BatchMultiClassNonMaxSuppression/ones
Postprocessor/BatchMultiClassNonMaxSuppression/ones/packed/ExpandDims_
Postprocessor/Decode/stack/ExpandDims_2883
Postprocessor/Decode/stack/ExpandDims_2884
Postprocessor/Tile/multiples/ExpandDims_
Postprocessor/Tile/multiples/ExpandDims_2827
Postprocessor/Tile/multiples/ExpandDims_2828
Postprocessor/stack/ExpandDims_
Postprocessor/stack/ExpandDims_2865
Postprocessor/stack/ExpandDims_2866
Postprocessor/stack_1/ExpandDims_2909
Postprocessor/unstack/Split/Output_2/Data_
Postprocessor/unstack/Squeeze_3469
Postprocessor/unstack/Squeeze_3469/value
Postprocessor/unstack/Squeeze_3469/value/Output_0/Data_
[ 2020-05-06 17:08:49,479 ] [ DEBUG ] [ class_registration:281 ]  Run replacer <class 'extensions.middle.PartialInfer.PartialInfer'>
[ 2020-05-06 17:08:49,540 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,540 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/unstack/Split/value
[ 2020-05-06 17:08:49,541 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,545 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,545 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,546 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,546 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,547 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/unstack/Split/value
[ 2020-05-06 17:08:49,547 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,548 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,548 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,549 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:49,549 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,549 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/unstack/Split/value
[ 2020-05-06 17:08:49,550 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,554 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,555 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,555 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:49,556 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,556 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/unstack/Split/value
[ 2020-05-06 17:08:49,557 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,557 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,558 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,558 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,559 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,559 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/get_center_coordinates_and_sizes/unstack/Split/value
[ 2020-05-06 17:08:49,559 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,560 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,560 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,561 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,561 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,561 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/unstack/Squeeze_3479/value
[ 2020-05-06 17:08:49,562 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,562 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,563 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,566 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,569 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,569 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/unstack/Squeeze_3477/value
[ 2020-05-06 17:08:49,570 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,570 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,571 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,571 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,572 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,572 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/unstack/Squeeze_3475/value
[ 2020-05-06 17:08:49,573 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,573 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,573 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,574 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,579 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,579 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/unstack/Squeeze_/value
[ 2020-05-06 17:08:49,580 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,580 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,580 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,581 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,581 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,582 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/unstack/Squeeze_/value
[ 2020-05-06 17:08:49,582 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,582 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,583 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,583 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:49,584 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,587 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/unstack/Squeeze_3467/value
[ 2020-05-06 17:08:49,588 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,588 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,591 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,592 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:49,592 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,593 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/unstack/Squeeze_/value
[ 2020-05-06 17:08:49,594 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,595 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,600 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,605 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:49,607 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,608 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/unstack/Squeeze_3463/value
[ 2020-05-06 17:08:49,610 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,614 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,614 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,615 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,615 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,616 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/unstack/Squeeze_3461/value
[ 2020-05-06 17:08:49,616 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,617 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,618 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,622 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,626 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,627 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/unstack/Squeeze_3459/value
[ 2020-05-06 17:08:49,627 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,628 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,629 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,631 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,632 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,636 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/unstack/Squeeze_/value
[ 2020-05-06 17:08:49,636 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,637 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,637 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,637 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,638 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,638 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/get_center_coordinates_and_sizes/unstack/Squeeze_3455/value
[ 2020-05-06 17:08:49,638 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,639 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,639 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,640 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,642 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,646 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/get_center_coordinates_and_sizes/unstack/Squeeze_3453/value
[ 2020-05-06 17:08:49,646 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,646 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,647 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,647 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,648 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,648 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/get_center_coordinates_and_sizes/unstack/Squeeze_3451/value
[ 2020-05-06 17:08:49,649 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,649 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,650 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,650 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,650 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,650 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/get_center_coordinates_and_sizes/unstack/Squeeze_/value
[ 2020-05-06 17:08:49,653 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,657 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,657 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,658 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:49,658 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,658 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3446
[ 2020-05-06 17:08:49,659 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,659 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,660 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,660 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,660 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,660 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3443
[ 2020-05-06 17:08:49,661 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,661 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,662 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,667 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,668 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,668 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3440
[ 2020-05-06 17:08:49,669 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,669 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,670 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,670 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,670 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,670 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3437
[ 2020-05-06 17:08:49,671 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,671 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,672 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,672 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,672 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,673 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3434
[ 2020-05-06 17:08:49,678 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,679 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,679 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,679 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,680 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,680 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3431
[ 2020-05-06 17:08:49,680 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,681 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,681 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,681 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,682 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,682 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3428
[ 2020-05-06 17:08:49,682 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,683 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,683 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,683 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,684 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,688 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3425
[ 2020-05-06 17:08:49,689 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,689 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,690 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,690 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,690 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,691 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3422
[ 2020-05-06 17:08:49,691 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,691 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,692 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,692 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,693 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,693 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3419
[ 2020-05-06 17:08:49,693 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,694 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,694 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,694 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,695 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,695 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3416
[ 2020-05-06 17:08:49,695 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,696 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,696 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,696 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,697 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,702 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3413
[ 2020-05-06 17:08:49,702 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,703 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,703 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,704 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,704 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,705 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3410
[ 2020-05-06 17:08:49,705 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,705 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,706 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,707 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,708 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,710 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3407
[ 2020-05-06 17:08:49,713 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,714 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,714 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,715 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,716 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,717 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3404
[ 2020-05-06 17:08:49,717 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,718 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,718 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,721 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,724 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,724 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3401
[ 2020-05-06 17:08:49,724 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,725 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,725 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,726 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,726 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,726 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3398
[ 2020-05-06 17:08:49,727 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,727 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,728 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,728 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,728 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,729 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3395
[ 2020-05-06 17:08:49,731 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,734 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,735 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,735 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,736 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,736 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3392
[ 2020-05-06 17:08:49,736 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,737 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,737 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,737 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,738 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,738 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3389
[ 2020-05-06 17:08:49,738 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,739 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,739 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,739 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,740 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,742 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3386
[ 2020-05-06 17:08:49,745 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,745 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,746 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,746 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,747 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,747 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3383
[ 2020-05-06 17:08:49,747 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,748 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,748 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,748 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,749 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,749 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3380
[ 2020-05-06 17:08:49,749 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,750 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,750 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,751 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,753 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,756 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3377
[ 2020-05-06 17:08:49,757 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,757 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,758 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,758 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,758 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,758 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3374
[ 2020-05-06 17:08:49,759 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,759 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,760 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,760 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,760 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,761 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3371
[ 2020-05-06 17:08:49,761 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,761 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,762 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,767 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,767 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,768 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3368
[ 2020-05-06 17:08:49,768 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,769 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,769 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,769 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,770 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,770 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3365
[ 2020-05-06 17:08:49,771 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,771 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,771 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,772 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,772 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,772 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3362
[ 2020-05-06 17:08:49,773 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,775 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,778 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,779 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1
[ 2020-05-06 17:08:49,780 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,780 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3359
[ 2020-05-06 17:08:49,781 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,781 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,782 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,782 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,783 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,783 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3356
[ 2020-05-06 17:08:49,783 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,783 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,786 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,789 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,789 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,790 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3353
[ 2020-05-06 17:08:49,790 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,791 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,791 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,792 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,792 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,792 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3350
[ 2020-05-06 17:08:49,792 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,793 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,793 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,794 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,794 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,794 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3347
[ 2020-05-06 17:08:49,794 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,795 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,797 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,800 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,801 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,801 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3344
[ 2020-05-06 17:08:49,802 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,802 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,802 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,803 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,803 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,803 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3341
[ 2020-05-06 17:08:49,804 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,805 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,805 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,805 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,806 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,808 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3338
[ 2020-05-06 17:08:49,811 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,812 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,812 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,813 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,813 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,813 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3335
[ 2020-05-06 17:08:49,814 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,814 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,814 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,815 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,815 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,815 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3332
[ 2020-05-06 17:08:49,816 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,816 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,817 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,820 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,821 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,821 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3329
[ 2020-05-06 17:08:49,822 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,823 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,823 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,823 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,824 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,824 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3326
[ 2020-05-06 17:08:49,825 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,825 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,825 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,826 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,826 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,826 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3323
[ 2020-05-06 17:08:49,827 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,827 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,827 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,828 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,828 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,828 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3320
[ 2020-05-06 17:08:49,828 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,829 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,832 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,835 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,835 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,835 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3317
[ 2020-05-06 17:08:49,836 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,837 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,837 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,838 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,838 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,838 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3314
[ 2020-05-06 17:08:49,839 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,839 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,839 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,840 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,840 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,840 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3311
[ 2020-05-06 17:08:49,841 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,843 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,846 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,847 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,847 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,848 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3308
[ 2020-05-06 17:08:49,848 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,849 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,849 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,849 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,850 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,850 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3305
[ 2020-05-06 17:08:49,850 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,850 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,851 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,851 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,852 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,854 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3302
[ 2020-05-06 17:08:49,857 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,857 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,858 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,858 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,859 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,859 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3299
[ 2020-05-06 17:08:49,859 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,860 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,860 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,860 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,861 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,861 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3296
[ 2020-05-06 17:08:49,861 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,862 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,862 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,862 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,863 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,865 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3293
[ 2020-05-06 17:08:49,868 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,869 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,869 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,870 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,870 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,870 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3290
[ 2020-05-06 17:08:49,871 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,871 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,871 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,872 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,872 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,872 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3287
[ 2020-05-06 17:08:49,873 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,873 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,873 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,874 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,876 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,879 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3284
[ 2020-05-06 17:08:49,880 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,880 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,881 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,881 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,882 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,882 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3281
[ 2020-05-06 17:08:49,882 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,882 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,883 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,883 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,883 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,884 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3278
[ 2020-05-06 17:08:49,884 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,885 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,887 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,890 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,890 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,890 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3275
[ 2020-05-06 17:08:49,891 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,891 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,892 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,892 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,892 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,893 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3272
[ 2020-05-06 17:08:49,893 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,893 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,894 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,894 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,894 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,894 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3269
[ 2020-05-06 17:08:49,895 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,895 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,896 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,898 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,901 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,902 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3266
[ 2020-05-06 17:08:49,902 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,903 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,903 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,904 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,904 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,904 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3263
[ 2020-05-06 17:08:49,905 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,905 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,905 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,906 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,906 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,906 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3260
[ 2020-05-06 17:08:49,907 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,909 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,912 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,912 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,913 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,913 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3257
[ 2020-05-06 17:08:49,914 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,914 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,914 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,915 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,915 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,915 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3254
[ 2020-05-06 17:08:49,916 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,916 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,916 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,917 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,917 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,918 ] [ DEBUG ] [ infer:129 ]  Partial infer for 3251
[ 2020-05-06 17:08:49,920 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,923 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,924 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,925 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = -1.0
[ 2020-05-06 17:08:49,926 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,926 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_2/ExpandDims_2974/Dims
[ 2020-05-06 17:08:49,927 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,927 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,927 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,928 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,928 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,928 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_2/ExpandDims_/Dims
[ 2020-05-06 17:08:49,929 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,931 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,934 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,935 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,935 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,935 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_6/ExpandDims_2971/Dims
[ 2020-05-06 17:08:49,936 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,936 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,937 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,937 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,937 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,938 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_6/ExpandDims_/Dims
[ 2020-05-06 17:08:49,938 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,938 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,939 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,939 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,939 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,940 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1/ExpandDims_2968/Dims
[ 2020-05-06 17:08:49,945 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,945 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,946 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,946 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,946 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,947 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_1/ExpandDims_/Dims
[ 2020-05-06 17:08:49,947 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,947 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,948 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,948 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,948 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,949 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_4/ExpandDims_2965/Dims
[ 2020-05-06 17:08:49,949 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,949 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,950 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,950 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,950 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,953 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_4/ExpandDims_/Dims
[ 2020-05-06 17:08:49,956 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,956 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,957 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,957 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,958 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,958 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/values_1/ExpandDims_2962/Dims
[ 2020-05-06 17:08:49,959 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,959 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,960 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,960 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,960 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,960 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/values_1/ExpandDims_/Dims
[ 2020-05-06 17:08:49,961 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,961 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,961 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,964 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,967 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,968 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size/ExpandDims_2959/Dims
[ 2020-05-06 17:08:49,968 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,969 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,969 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,970 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,970 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,970 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice/size/ExpandDims_/Dims
[ 2020-05-06 17:08:49,970 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,971 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,971 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,972 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,972 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,972 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_2956/Dims
[ 2020-05-06 17:08:49,973 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,975 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,978 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,978 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,979 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,979 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_2955/Dims
[ 2020-05-06 17:08:49,979 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,980 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,980 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,981 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,981 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,981 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_2954/Dims
[ 2020-05-06 17:08:49,982 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,982 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,982 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,983 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,983 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,983 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/sub_2/y/ExpandDims_/Dims
[ 2020-05-06 17:08:49,984 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,986 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,989 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,990 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:49,990 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,991 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_7/ExpandDims_2951/Dims
[ 2020-05-06 17:08:49,991 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,992 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,992 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,993 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:49,993 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:49,993 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_7/ExpandDims_/Dims
[ 2020-05-06 17:08:49,994 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:49,994 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:49,995 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:49,997 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,000 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,001 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_5/ExpandDims_2948/Dims
[ 2020-05-06 17:08:50,001 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,002 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,003 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,003 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,004 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,004 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_5/ExpandDims_/Dims
[ 2020-05-06 17:08:50,005 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,011 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,011 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,012 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,012 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,012 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4/ExpandDims_2945/Dims
[ 2020-05-06 17:08:50,013 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,013 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,014 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,014 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,014 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,015 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack_4/ExpandDims_/Dims
[ 2020-05-06 17:08:50,017 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,021 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,021 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,022 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,022 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,022 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_11/ExpandDims_2942/Dims
[ 2020-05-06 17:08:50,023 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,023 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,024 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,024 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,024 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,024 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_11/ExpandDims_/Dims
[ 2020-05-06 17:08:50,025 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,025 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,025 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,028 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,031 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,032 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_9/ExpandDims_2939/Dims
[ 2020-05-06 17:08:50,032 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,032 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,033 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,033 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,033 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,034 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_9/ExpandDims_/Dims
[ 2020-05-06 17:08:50,034 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,035 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,035 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,035 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,036 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,041 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape_1/shape/ExpandDims_2936/Dims
[ 2020-05-06 17:08:50,041 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,041 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,042 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,043 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,043 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,043 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape_1/shape/ExpandDims_2935/Dims
[ 2020-05-06 17:08:50,043 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,044 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,044 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,045 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,045 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,045 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape_1/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,045 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,046 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,048 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,051 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,052 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,052 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/ones/packed/ExpandDims_/Dims
[ 2020-05-06 17:08:50,053 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,053 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,054 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,055 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,055 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,055 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape_1/shape/ExpandDims_2930/Dims
[ 2020-05-06 17:08:50,056 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,056 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,056 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,057 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,062 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,062 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape_1/shape/ExpandDims_2929/Dims
[ 2020-05-06 17:08:50,063 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,064 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,064 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,064 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,065 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,065 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape_1/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,066 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,066 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,066 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,067 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,071 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,071 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape_1/shape/ExpandDims_2926/Dims
[ 2020-05-06 17:08:50,071 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,072 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,072 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,073 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,073 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,073 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape_1/shape/ExpandDims_2925/Dims
[ 2020-05-06 17:08:50,074 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,074 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,075 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,075 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,075 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,076 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape_1/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,076 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,076 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,077 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,077 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,078 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,078 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape/shape/ExpandDims_2922/Dims
[ 2020-05-06 17:08:50,079 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,082 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,086 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,086 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,087 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,087 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape/shape/ExpandDims_2921/Dims
[ 2020-05-06 17:08:50,087 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,088 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,088 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,089 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,089 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,089 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape/shape/ExpandDims_2920/Dims
[ 2020-05-06 17:08:50,089 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,090 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,090 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,091 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,093 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,096 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,096 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,096 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,097 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,098 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,098 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,098 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_3/ExpandDims_2917/Dims
[ 2020-05-06 17:08:50,099 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,099 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,100 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,100 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,100 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,101 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_3/ExpandDims_/Dims
[ 2020-05-06 17:08:50,107 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,107 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,108 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,108 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,109 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,109 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack/ExpandDims_2914/Dims
[ 2020-05-06 17:08:50,109 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,109 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,110 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,111 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,111 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,111 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack/ExpandDims_/Dims
[ 2020-05-06 17:08:50,111 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,112 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,117 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,117 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,117 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,118 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack_1/ExpandDims_2911/Dims
[ 2020-05-06 17:08:50,119 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,120 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,120 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,120 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,121 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,121 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack_1/ExpandDims_2910/Dims
[ 2020-05-06 17:08:50,121 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,122 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,124 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,127 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,128 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,128 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack_1/ExpandDims_2909/Dims
[ 2020-05-06 17:08:50,128 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,129 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,129 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,130 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,130 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,130 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack_1/ExpandDims_/Dims
[ 2020-05-06 17:08:50,131 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,131 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,131 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,132 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,132 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,132 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape_1/shape/ExpandDims_2906/Dims
[ 2020-05-06 17:08:50,133 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,137 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,138 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,138 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,139 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,139 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape_1/shape/ExpandDims_2905/Dims
[ 2020-05-06 17:08:50,139 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,140 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,140 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,141 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,142 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,142 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_2/Reshape_1/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,143 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,143 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,144 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,144 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,145 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,145 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape/shape/ExpandDims_2902/Dims
[ 2020-05-06 17:08:50,145 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,146 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,149 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,153 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,153 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,153 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape/shape/ExpandDims_2901/Dims
[ 2020-05-06 17:08:50,154 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,154 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,155 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,155 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,155 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,156 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape/shape/ExpandDims_2900/Dims
[ 2020-05-06 17:08:50,156 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,156 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,157 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,157 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,157 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,158 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_1/Reshape/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,163 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,163 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,164 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,164 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,165 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,165 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_5/size/ExpandDims_/Dims
[ 2020-05-06 17:08:50,166 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,166 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,166 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,167 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,167 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,168 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_8/ExpandDims_2895/Dims
[ 2020-05-06 17:08:50,168 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,169 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,174 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,175 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,176 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,176 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_8/ExpandDims_/Dims
[ 2020-05-06 17:08:50,177 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,178 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,179 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,181 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,184 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,185 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape/shape/ExpandDims_2892/Dims
[ 2020-05-06 17:08:50,185 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,186 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,186 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,187 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,187 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,188 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape/shape/ExpandDims_2891/Dims
[ 2020-05-06 17:08:50,188 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,188 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,189 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,191 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,194 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,194 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape/shape/ExpandDims_2890/Dims
[ 2020-05-06 17:08:50,194 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,195 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,196 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,196 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,196 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,196 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_4/Reshape/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,197 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,197 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,198 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,198 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,199 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,201 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/ExpandDims_2887/Dims
[ 2020-05-06 17:08:50,204 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,204 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,205 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,205 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,206 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,206 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/ExpandDims_/Dims
[ 2020-05-06 17:08:50,207 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,207 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,208 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,208 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,208 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,209 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/stack/ExpandDims_2884/Dims
[ 2020-05-06 17:08:50,209 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,210 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,212 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,215 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,216 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,216 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/stack/ExpandDims_2883/Dims
[ 2020-05-06 17:08:50,217 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,217 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,218 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,218 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,218 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,219 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/stack/ExpandDims_2882/Dims
[ 2020-05-06 17:08:50,219 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,219 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,220 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,220 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,221 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,223 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Decode/stack/ExpandDims_/Dims
[ 2020-05-06 17:08:50,226 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,227 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,227 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,228 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,228 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,229 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_2879/Dims
[ 2020-05-06 17:08:50,229 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,229 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,230 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,231 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,231 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,232 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_/Dims
[ 2020-05-06 17:08:50,234 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,238 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,238 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,239 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,240 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,241 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/ExpandDims_2876/Dims
[ 2020-05-06 17:08:50,241 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,241 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,242 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,243 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,247 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,252 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/ExpandDims_/Dims
[ 2020-05-06 17:08:50,252 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,253 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,254 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,254 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,255 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,255 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_10/ExpandDims_2873/Dims
[ 2020-05-06 17:08:50,255 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,258 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,259 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,262 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,262 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,263 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_10/ExpandDims_/Dims
[ 2020-05-06 17:08:50,263 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,264 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,264 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,265 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,265 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,265 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/ExpandDims_2870/Dims
[ 2020-05-06 17:08:50,266 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,266 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,266 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,272 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,273 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,273 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/ExpandDims_2869/Dims
[ 2020-05-06 17:08:50,273 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,274 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,275 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,275 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,275 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,275 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/stack/ExpandDims_/Dims
[ 2020-05-06 17:08:50,276 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,276 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,277 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,277 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,278 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,278 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack/ExpandDims_2866/Dims
[ 2020-05-06 17:08:50,278 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,279 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,279 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,280 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,280 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,281 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack/ExpandDims_2865/Dims
[ 2020-05-06 17:08:50,284 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,287 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,289 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,290 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,290 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,291 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/stack/ExpandDims_/Dims
[ 2020-05-06 17:08:50,292 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,292 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,295 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,298 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,301 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,302 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1/ExpandDims_2862/Dims
[ 2020-05-06 17:08:50,302 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,303 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,304 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,304 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,304 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,305 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack/values_1/ExpandDims_/Dims
[ 2020-05-06 17:08:50,305 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,305 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,306 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,308 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,311 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,311 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape_1/shape/ExpandDims_2859/Dims
[ 2020-05-06 17:08:50,312 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,312 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,313 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,313 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,313 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,314 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape_1/shape/ExpandDims_2858/Dims
[ 2020-05-06 17:08:50,314 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,314 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,315 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,315 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,316 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,316 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape_1/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,316 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,316 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,317 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,320 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,322 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,323 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/ExpandDims_2855/Dims
[ 2020-05-06 17:08:50,323 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,323 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,324 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,324 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,324 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,325 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_4/ExpandDims_/Dims
[ 2020-05-06 17:08:50,325 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,326 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,326 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,326 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,327 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,327 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_1/size/ExpandDims_/Dims
[ 2020-05-06 17:08:50,327 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,328 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,330 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,333 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,333 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,334 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape/shape/ExpandDims_2850/Dims
[ 2020-05-06 17:08:50,334 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,335 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,335 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,336 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,336 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,336 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape/shape/ExpandDims_2849/Dims
[ 2020-05-06 17:08:50,337 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,337 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,337 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,338 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,338 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,338 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape/shape/ExpandDims_2848/Dims
[ 2020-05-06 17:08:50,339 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,341 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,344 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,345 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,345 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,345 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_5/Reshape/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,346 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,346 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,347 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,347 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,347 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,348 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape/shape/ExpandDims_2845/Dims
[ 2020-05-06 17:08:50,348 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,348 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,349 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,349 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,350 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,354 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape/shape/ExpandDims_2844/Dims
[ 2020-05-06 17:08:50,354 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,355 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,355 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,355 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,356 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,356 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape/shape/ExpandDims_2843/Dims
[ 2020-05-06 17:08:50,356 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,357 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,357 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,358 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,358 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,358 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,359 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,359 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,359 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,360 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,360 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,360 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_1/ExpandDims_2840/Dims
[ 2020-05-06 17:08:50,361 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,361 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,361 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,364 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,367 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,368 ] [ DEBUG ] [ infer:129 ]  Partial infer for MultipleGridAnchorGenerator/stack_1/ExpandDims_/Dims
[ 2020-05-06 17:08:50,368 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,369 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,369 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,370 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [3]
[ 2020-05-06 17:08:50,370 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,370 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape_1/shape/ExpandDims_2837/Dims
[ 2020-05-06 17:08:50,371 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,371 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,372 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,372 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,372 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,373 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape_1/shape/ExpandDims_2836/Dims
[ 2020-05-06 17:08:50,375 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,378 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,379 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,379 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,379 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,380 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_0/Reshape_1/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,380 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,380 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,381 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,381 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,382 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,382 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size/ExpandDims_2833/Dims
[ 2020-05-06 17:08:50,382 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,383 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,383 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,383 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,384 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,386 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Slice_4/size/ExpandDims_/Dims
[ 2020-05-06 17:08:50,389 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,390 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,390 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,391 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,391 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,391 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_1/values_1/ExpandDims_/Dims
[ 2020-05-06 17:08:50,392 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,392 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,392 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,393 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,393 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,393 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Tile/multiples/ExpandDims_2828/Dims
[ 2020-05-06 17:08:50,394 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,394 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,394 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,397 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,400 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,400 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Tile/multiples/ExpandDims_2827/Dims
[ 2020-05-06 17:08:50,401 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,401 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,402 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,402 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,403 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,403 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Tile/multiples/ExpandDims_/Dims
[ 2020-05-06 17:08:50,403 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,404 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,404 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,405 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,405 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,405 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/values_1/ExpandDims_/Dims
[ 2020-05-06 17:08:50,405 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,406 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,408 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,411 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,412 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,412 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape/shape/ExpandDims_2822/Dims
[ 2020-05-06 17:08:50,412 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,413 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,413 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,413 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,414 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,414 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape/shape/ExpandDims_2821/Dims
[ 2020-05-06 17:08:50,414 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,415 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,415 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,416 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,416 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,416 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape/shape/ExpandDims_2820/Dims
[ 2020-05-06 17:08:50,416 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,417 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,421 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,423 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,423 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,424 ] [ DEBUG ] [ infer:129 ]  Partial infer for BoxPredictor_3/Reshape/shape/ExpandDims_/Dims
[ 2020-05-06 17:08:50,424 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,424 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,425 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,425 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,426 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,427 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/ExpandDims_2817/Dims
[ 2020-05-06 17:08:50,427 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,428 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,428 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,429 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,431 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,434 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/stack_5/ExpandDims_/Dims
[ 2020-05-06 17:08:50,434 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,435 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,437 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,437 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,438 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,438 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2813
[ 2020-05-06 17:08:50,439 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,440 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,442 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,445 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.5
[ 2020-05-06 17:08:50,446 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,446 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2811
[ 2020-05-06 17:08:50,446 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,447 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,447 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,448 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,448 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,448 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2809
[ 2020-05-06 17:08:50,449 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,449 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,450 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,454 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.5
[ 2020-05-06 17:08:50,455 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,455 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2807
[ 2020-05-06 17:08:50,455 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,456 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,456 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,457 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.5
[ 2020-05-06 17:08:50,457 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,457 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2805
[ 2020-05-06 17:08:50,458 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,458 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,459 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,459 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.5
[ 2020-05-06 17:08:50,459 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,460 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2803
[ 2020-05-06 17:08:50,460 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,460 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,461 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,461 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.5
[ 2020-05-06 17:08:50,461 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,461 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2801
[ 2020-05-06 17:08:50,462 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,462 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,463 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,466 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,468 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,469 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2799
[ 2020-05-06 17:08:50,470 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,470 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,471 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,471 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.5
[ 2020-05-06 17:08:50,472 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,472 ] [ DEBUG ] [ infer:129 ]  Partial infer for 2797
[ 2020-05-06 17:08:50,472 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,473 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,473 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,473 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,474 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,476 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Squeeze/Dims
[ 2020-05-06 17:08:50,479 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,479 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,480 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,480 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [2]
[ 2020-05-06 17:08:50,481 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,481 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/Squeeze/Dims
[ 2020-05-06 17:08:50,481 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,482 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,482 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,482 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,483 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,483 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/Squeeze/Dims
[ 2020-05-06 17:08:50,483 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,484 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,484 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,485 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,487 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,490 ] [ DEBUG ] [ infer:129 ]  Partial infer for Squeeze/Dims
[ 2020-05-06 17:08:50,490 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,491 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,491 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,492 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [2]
[ 2020-05-06 17:08:50,492 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,493 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/non_max_suppression/NonMaxSuppressionV3/Crop/Squeeze/value
[ 2020-05-06 17:08:50,493 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,493 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,494 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,494 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,494 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,495 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/non_max_suppression/NonMaxSuppressionV3/Unsqueeze_1/value
[ 2020-05-06 17:08:50,495 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,495 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,496 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,498 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [3], value = [ 1  1 -1]
[ 2020-05-06 17:08:50,501 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,502 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/non_max_suppression/NonMaxSuppressionV3/Unsqueeze_0/value
[ 2020-05-06 17:08:50,502 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,503 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,504 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,504 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,504 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,504 ] [ DEBUG ] [ infer:129 ]  Partial infer for add/y
[ 2020-05-06 17:08:50,505 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,505 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,506 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,506 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1.0
[ 2020-05-06 17:08:50,506 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,506 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_6/range/delta
[ 2020-05-06 17:08:50,507 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,509 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,512 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,512 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,513 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,513 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_6/range/start
[ 2020-05-06 17:08:50,513 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,514 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,514 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,514 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,515 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,515 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_5/range/delta
[ 2020-05-06 17:08:50,515 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,516 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,516 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,517 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,517 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,518 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_5/range/start
[ 2020-05-06 17:08:50,520 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,523 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,524 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,525 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,525 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,526 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_2/range/delta
[ 2020-05-06 17:08:50,527 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,527 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,528 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,529 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,531 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,535 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_2/range/start
[ 2020-05-06 17:08:50,535 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,537 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,538 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,538 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,538 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,539 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_1/range/delta
[ 2020-05-06 17:08:50,539 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,539 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,541 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,545 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,545 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,545 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_1/range/start
[ 2020-05-06 17:08:50,546 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,546 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,547 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,547 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,548 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,548 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/delta
[ 2020-05-06 17:08:50,548 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,549 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,549 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,549 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,550 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,554 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/start
[ 2020-05-06 17:08:50,555 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,555 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,556 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,556 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,556 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,557 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/iteration_counter
[ 2020-05-06 17:08:50,557 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,557 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,558 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,558 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,558 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,559 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Enter
[ 2020-05-06 17:08:50,559 ] [ DEBUG ] [ infer:130 ]  Op: Enter
[ 2020-05-06 17:08:50,559 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,560 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,560 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,561 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,561 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,561 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Merge
[ 2020-05-06 17:08:50,561 ] [ DEBUG ] [ infer:130 ]  Op: Merge
[ 2020-05-06 17:08:50,562 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,562 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,562 ] [ DEBUG ] [ infer:31 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2020-05-06 17:08:50,563 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,566 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2020-05-06 17:08:50,569 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,570 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/Const
[ 2020-05-06 17:08:50,570 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,571 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,571 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,571 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,572 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,572 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Enter_1
[ 2020-05-06 17:08:50,572 ] [ DEBUG ] [ infer:130 ]  Op: Enter
[ 2020-05-06 17:08:50,573 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,573 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,573 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,574 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,574 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,575 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Merge_1
[ 2020-05-06 17:08:50,577 ] [ DEBUG ] [ infer:130 ]  Op: Merge
[ 2020-05-06 17:08:50,580 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,580 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,581 ] [ DEBUG ] [ infer:31 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2020-05-06 17:08:50,581 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,582 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2020-05-06 17:08:50,582 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,582 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_6/range/delta
[ 2020-05-06 17:08:50,583 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,583 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,583 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,584 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,584 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,584 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_6/range/start
[ 2020-05-06 17:08:50,585 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,585 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,585 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,586 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,588 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,591 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_6/strided_slice/stack_2
[ 2020-05-06 17:08:50,592 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,592 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,593 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,593 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,594 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,594 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_6/strided_slice/stack_1
[ 2020-05-06 17:08:50,594 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,595 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,595 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,595 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,596 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,596 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_6/strided_slice/stack
[ 2020-05-06 17:08:50,596 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,597 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,602 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,602 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,603 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,603 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_5/range/delta
[ 2020-05-06 17:08:50,603 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,603 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,604 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,604 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,605 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,605 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_5/range/start
[ 2020-05-06 17:08:50,606 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,606 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,607 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,607 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,607 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,608 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_5/strided_slice/stack_2
[ 2020-05-06 17:08:50,610 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,614 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,615 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,615 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,616 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,616 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_5/strided_slice/stack_1
[ 2020-05-06 17:08:50,617 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,618 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,618 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,619 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,621 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,625 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_5/strided_slice/stack
[ 2020-05-06 17:08:50,625 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,626 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,627 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,627 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,627 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,628 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/delta
[ 2020-05-06 17:08:50,628 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,628 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,629 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,629 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,629 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,631 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/start
[ 2020-05-06 17:08:50,635 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,636 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,636 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,636 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,637 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,637 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_2
[ 2020-05-06 17:08:50,638 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,638 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,638 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,639 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,639 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,639 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_1
[ 2020-05-06 17:08:50,640 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,642 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,645 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,645 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,646 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,646 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack
[ 2020-05-06 17:08:50,647 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,647 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,648 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,648 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,648 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,649 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/delta
[ 2020-05-06 17:08:50,649 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,649 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,650 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,650 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,650 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,653 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/start
[ 2020-05-06 17:08:50,656 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,656 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,657 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,657 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,658 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,658 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2020-05-06 17:08:50,658 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,659 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,659 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,659 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,660 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,660 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2020-05-06 17:08:50,660 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,661 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,662 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,664 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,667 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,667 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack
[ 2020-05-06 17:08:50,668 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,668 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,669 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,669 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,669 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,670 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/delta
[ 2020-05-06 17:08:50,670 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,670 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,671 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,671 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,672 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,672 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/start
[ 2020-05-06 17:08:50,672 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,672 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,675 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,678 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0
[ 2020-05-06 17:08:50,679 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,680 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_2
[ 2020-05-06 17:08:50,681 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,681 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,682 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,683 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,683 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,684 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_1
[ 2020-05-06 17:08:50,686 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,689 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,690 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,691 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,691 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,691 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack
[ 2020-05-06 17:08:50,692 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,692 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,692 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,693 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,693 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,693 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack_2
[ 2020-05-06 17:08:50,694 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,696 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,699 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,700 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,700 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,700 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack_1
[ 2020-05-06 17:08:50,701 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,701 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,702 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,702 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,702 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,703 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack
[ 2020-05-06 17:08:50,703 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,703 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,704 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,704 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,704 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,705 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/ones/Const
[ 2020-05-06 17:08:50,707 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,710 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,711 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,711 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 1
[ 2020-05-06 17:08:50,711 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,712 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice_1/stack_2
[ 2020-05-06 17:08:50,712 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,712 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,713 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,713 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,713 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,714 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice_1/stack_1
[ 2020-05-06 17:08:50,714 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,714 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,715 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,715 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [2]
[ 2020-05-06 17:08:50,715 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,716 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice_1/stack
[ 2020-05-06 17:08:50,720 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,720 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,721 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,722 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,722 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,722 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice/stack_2
[ 2020-05-06 17:08:50,723 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,723 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,724 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,724 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,724 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,725 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice/stack_1
[ 2020-05-06 17:08:50,725 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,725 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,726 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,726 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [1]
[ 2020-05-06 17:08:50,726 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,727 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/BatchMultiClassNonMaxSuppression/strided_slice/stack
[ 2020-05-06 17:08:50,727 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,727 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,728 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,728 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [1], value = [0]
[ 2020-05-06 17:08:50,728 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,729 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Cast_3/x
[ 2020-05-06 17:08:50,734 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,735 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,735 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,736 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 224
[ 2020-05-06 17:08:50,736 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,737 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Cast_3
[ 2020-05-06 17:08:50,737 ] [ DEBUG ] [ infer:130 ]  Op: Cast
[ 2020-05-06 17:08:50,737 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,738 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 224
[ 2020-05-06 17:08:50,738 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,738 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 224.0
[ 2020-05-06 17:08:50,739 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,739 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/truediv_1/reciprocal_
[ 2020-05-06 17:08:50,739 ] [ DEBUG ] [ infer:130 ]  Op: Pow
[ 2020-05-06 17:08:50,740 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,745 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 224.0
[ 2020-05-06 17:08:50,746 ] [ DEBUG ] [ infer:31 ]  input[1]: shape = [], value = -1.0
[ 2020-05-06 17:08:50,747 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,747 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.004464286
[ 2020-05-06 17:08:50,747 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,748 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Cast_2/x
[ 2020-05-06 17:08:50,749 ] [ DEBUG ] [ infer:130 ]  Op: Const
[ 2020-05-06 17:08:50,749 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,750 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,750 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 224
[ 2020-05-06 17:08:50,751 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,753 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Cast_2
[ 2020-05-06 17:08:50,757 ] [ DEBUG ] [ infer:130 ]  Op: Cast
[ 2020-05-06 17:08:50,758 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,758 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 224
[ 2020-05-06 17:08:50,759 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,759 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 224.0
[ 2020-05-06 17:08:50,760 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,760 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/truediv/reciprocal_
[ 2020-05-06 17:08:50,761 ] [ DEBUG ] [ infer:130 ]  Op: Pow
[ 2020-05-06 17:08:50,761 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-05-06 17:08:50,761 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 224.0
[ 2020-05-06 17:08:50,762 ] [ DEBUG ] [ infer:31 ]  input[1]: shape = [], value = -1.0
[ 2020-05-06 17:08:50,764 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2020-05-06 17:08:50,767 ] [ DEBUG ] [ infer:31 ]  output[0]: shape = [], value = 0.004464286
[ 2020-05-06 17:08:50,768 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-05-06 17:08:50,768 ] [ DEBUG ] [ infer:129 ]  Partial infer for Postprocessor/Cast_1
[ 2020-05-06 17:08:50,769 ] [ DEBUG ] [ infer:130 ]  Op: Cast
[ 2020-05-06 17:08:50,769 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ ERROR ]  Cannot infer shapes or values for node "Postprocessor/Cast_1".
[ ERROR ]  0
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function Cast.infer at 0x00000278FD6A6AF8>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ 2020-05-06 17:08:50,773 ] [ DEBUG ] [ infer:196 ]  Node "Postprocessor/Cast_1" attributes: {'pb': name: "Postprocessor/Cast_1"
op: "Cast"
input: "Preprocessor/map/TensorArrayStack_1/TensorArrayGatherV3"
attr {
  key: "DstT"
  value {
    type: DT_FLOAT
attr {
  key: "SrcT"
  value {
    type: DT_INT32
attr {
  key: "Truncate"
  value {
    b: false
, '_in_ports': {0: {'control_flow': False}}, '_out_ports': {0: {'control_flow': False}}, 'kind': 'op', 'name': 'Postprocessor/Cast_1', 'op': 'Cast', 'type': 'Convert', 'infer': <function Cast.infer at 0x00000278FD6A6AF8>, 'type_infer': <function Cast.type_infer at 0x00000278FD6A6A68>, 'dst_type': <class 'numpy.float32'>, 'in_ports_count': 1, 'out_ports_count': 1, 'dim_attrs': ['spatial_dims', 'channel_dims', 'axis', 'batch_dims'], 'shape_attrs': ['shape', 'pad', 'stride', 'output_shape', 'window'], 'IE': [('layer', [('id', <function Op.substitute_ie_attrs.<locals>.<lambda> at 0x0000027887AE7D38>), 'name', 'type', 'version'], [('data', [('destination_type', <function Cast.backend_attrs.<locals>.<lambda> at 0x0000027887AE7DC8>)], []), '@ports', '@consts'])], 'is_output_reachable': True, 'is_undead': False, 'is_const_producer': False, 'is_partial_inferred': False}
[ ANALYSIS INFO ]  Your model looks like TensorFlow Object Detection API Model.
Check if all parameters are specified:
        --tensorflow_use_custom_operations_config
        --tensorflow_object_detection_api_pipeline_config
        --input_shape (optional)
        --reverse_input_channels (if you convert a model to use with the Inference Engine sample applications)
Detailed information about conversion of this model can be found at
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Postprocessor/Cast_1" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
[ 2020-05-06 17:08:50,780 ] [ DEBUG ] [ main:324 ]  Traceback (most recent call last):
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\middle\passes\infer.py", line 134, in partial_infer
    node.infer(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\extensions\ops\Cast.py", line 56, in infer
    copy_shape_infer(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\front\common\partial_infer\elemental.py", line 33, in copy_shape_infer
    single_output_infer(node, lambda n: n.in_node().shape, value_infer)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\front\common\partial_infer\elemental.py", line 19, in single_output_infer
    node.out_node(0).shape = shape_infer(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\front\common\partial_infer\elemental.py", line 33, in <lambda>
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\graph\graph.py", line 203, in in_node
    return self.in_nodes(control_flow=control_flow)[key]
KeyError: 0
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 287, in apply_transform
    for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\middle\pattern_match.py", line 58, in for_graph_and_each_sub_graph_recursively
    func(graph)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\extensions\middle\PartialInfer.py", line 32, in find_and_replace_pattern
    partial_infer(graph)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\middle\passes\infer.py", line 198, in partial_infer
    refer_to_faq_msg(38)) from err
mo.utils.error.Error: Stopped shape/value propagation at "Postprocessor/Cast_1" node.
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\main.py", line 314, in main
    return driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\main.py", line 281, in driver
    ret_res = emit_ir(prepare_ir(argv), argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\main.py", line 226, in prepare_ir
    graph = mo_tf.driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 111, in driver
    class_registration.ClassType.BACK_REPLACER
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 324, in apply_replacements
    num_transforms=len(replacers_order))
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\utils\logger.py", line 124, in wrapper
    function(*args, **kwargs)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 303, in apply_transform
    )) from err
mo.utils.error.Error: Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Postprocessor/Cast_1" node.
I optimized several model before, but i cant figure out this Postprocessor/Cast_1 problem.
Any idea how i can optimize this model?
JAIVIN_J_Intel
Hi Adam,
Thanks for reaching out.
Which version of Tensorflow are you using?
Please refer to this comment on another thread regarding a similar issue and try modifying the ssd_v2_support.json accordingly.
If the issue still persists, could you please share your model and necessary files so that we can have a look. You can share these files privately in case you don't want to share them publicly.
Jaivin
Nemes__Adam
Hi Jaivin
Wow thanks a lot, changing ssd_v2_support.json line 59 to '"Postprocessor/Cast_1"' worked like a charm.
However here is the thing.
I worked on two enviroment simultaniusly one with tf 1.14.0 and the other tensorflow-gpu 1.15.0.
The model optimalization on the first one worked with the original ssd_v2_support.json file,
on the other i have to edit it.
So kinda weird,
Thanks again
Adam
JAIVIN_J_Intel
Hi Adam,
I'm glad that it worked.
Thank you for sharing your observations with the OpenVino community.
Jaivin
