Dear,
The following command
python /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py --input_model saved_model.pb
results in
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: /home/bart/e27/cross/src/bart/very-deep-convnets-raw-waveforms/TF_Model/tf_model/saved_model.pb
- Path for generated IR: /home/bart/e27/cross/src/bart/very-deep-convnets-raw-waveforms/TF_Model/tf_model/.
- IR output name: saved_model
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
Model Optimizer version: 2019.3.0-408-gac8584cb7
[ WARNING ]
Detected not satisfied dependencies:
tensorflow: installed: 2.0.0, required: 2.0.0
Please install required versions of components or use install_prerequisites script
/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites_tf.sh
Note that install_prerequisites scripts may install additional components.
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] module 'tensorflow' has no attribute 'NodeDef'
[ ERROR ] Traceback (most recent call last):
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/main.py", line 298, in main
return driver(argv)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/main.py", line 243, in driver
import mo.pipeline.tf as mo_tf
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 33, in <module>
from mo.front.tf.extractor import get_tf_edges, tf_op_extractor, tf_op_extractors
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/front/tf/extractor.py", line 26, in <module>
from mo.front.tf.extractors.native_tf import native_tf_node_extractor
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/front/tf/extractors/native_tf.py", line 17, in <module>
from mo.front.tf.partial_infer.tf import tf_native_tf_node_infer
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/front/tf/partial_infer/tf.py", line 148, in <module>
is_input: bool = False):
AttributeError: module 'tensorflow' has no attribute 'NodeDef'
[ ERROR ] ---------------- END OF BUG REPORT --------------
Is this
Detected not satisfied dependencies: tensorflow: installed: 2.0.0, required: 2.0.0
an indication of an issue?
How do I solve the
[ ERROR ] Unexpected exception happened. [ ERROR ] Please contact Model Optimizer developers and forward the following information: [ ERROR ] module 'tensorflow' has no attribute 'NodeDef'
error?
Bart
Hi Bart,
What version of Tensorflow do you have installed? Try installing Tensorflow version 1.14.0.
Jesus
