mvNCCheck error
Hello,here!
to check the mobilenet, I run the follow commands ,
mvNCCheck mobilenet_deploy.prototxt -w mobilenet.caffemodel -s 12 -in input -on conv1
just try to check the first conv1 layer,
and then I get this ,
Traceback (most recent call last):
File "/usr/local/bin/mvNCCheck", line 202, in
quit_code = check_net(args.network, args.image, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args)
File "/usr/local/bin/mvNCCheck", line 169, in check_net
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 103, in load_network
parse_ret = parse_caffe(arguments, myriad_conf)
File "/usr/local/bin/ncsdk/Controllers/CaffeParser.py", line 387, in parse_caffe
input_bottom = net.bottom_names[inputNodeName][0]
IndexError: list index out of range
I have tried other layers, then I get the same result,
Thanks for your time and looks for your reply!
OK I get it,
only set the -on [node_name] and do not set -in input, it can run normally
