6616 Discussions
mvNCCompile error for Inception-Resnet-V2 with tensorflow
Hi
I saw NCSDK 1.10.01 can support inception-resnet-v2. I train a "inception-resnet-v2" model with facenet.
But I want to covert this model to run in NCS, but I get the error during converting.
Please help me to check this or give a converting example for inception-resnet-v2 with tensorflow
My command is as below:
$mvNCCompile model-20171204-174419.meta -s 12 -in=input -on=InceptionResnetV2/Logits/Predictions/Reshape_1 -o inception-resnet-v2.graph
The error is as below:
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
WARNING:tensorflow:The saved meta_graph is possibly from an older release:
'model_variables' collection should be of type 'byte_list', but instead is of type 'node_list'.
Traceback (most recent call last):
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1327, in _do_call
return fn(*args)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1306, in _run_fn
status, run_metadata)
File "/usr/lib/python3.5/contextlib.py", line 66, in exit
next(self.gen)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/errors_impl.py", line 466, in raise_exception_on_not_ok_status
pywrap_tensorflow.TF_GetCode(status))
tensorflow.python.framework.errors_impl.NotFoundError: Unsuccessful TensorSliceReader constructor: Failed to find any matching files for model-20171204-174419
[[Node: save/RestoreV2_740 = RestoreV2[dtypes=[DT_FLOAT], _device="/job:localhost/replica:0/task:0/cpu:0"](_arg_save/Const_0_0, save/RestoreV2_740/tensor_names, save/RestoreV2_740/shape_and_slices)]]
During handling of the above exception, another exception occurred:
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 192, in parse_tensor
saver.restore(sess, path[:path.rfind('.')])
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1560, in restore
{self.saver_def.filename_tensor_name: save_path})
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 895, in run
run_metadata_ptr)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1124, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1321, in _do_run
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1340, in _do_call
raise type(e)(node_def, op, message)
Caused by op 'save/RestoreV2_740', defined at:
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 190, in parse_tensor
saver = tf.train.import_meta_graph(path)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1698, in import_meta_graph
**kwargs)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/meta_graph.py", line 656, in import_scoped_meta_graph
producer_op_list=producer_op_list)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py", line 313, in import_graph_def
op_def=op_def)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 2630, in create_op
original_op=self._default_original_op, op_def=op_def)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 1204, in init
self._traceback = self._graph._extract_stack() # pylint: disable=protected-access
NotFoundError (see above for traceback): Unsuccessful TensorSliceReader constructor: Failed to find any matching files for model-20171204-174419
I saw the** ncsdk 1.10.1 can support inception-resnet-v2 model with tensorflow.**
I trained this model for facenet, got some files for check point in tensorflow, and i want to covert it for NCS.
But I get some error, anyone help me to check what worng is?
Or is there a example for inception-resnet v2 with NCS?
My command:
$mvNCCompile model-20171204-174419.meta -s 12 -in=input -on=Predictions -is 160 160 -o Inception-resnet-v2.graph
**kwargs)
op_def=op_def)
Any luck getting this working?
I faced the same error. It was so trivial that it was embarrasing.
Just change the name of your meta file such that it ends with 'ckpt.meta', same extension as the checkpoint file
@rouyunpan We have some new sample code with FaceNet @ https://github.com/movidius/ncappzoo.
