Error while trying to execute stream_ty_gn
Hello. I've successfully installed ncsdk and ran some examples, like stream_infer and caffe models. Now, I bought another movidius stick (I have two now), and tried to execute stream_ty_gn.
I'm getting the following error:
Running stream_ty_gn
Keys:
'Q'/'q' to Quit
'B'/'b' to inc/dec the Tiny Yolo box probability threshold
'I'/'i' to inc/dec the Tiny Yolo box intersection-over-union threshold
'G'/'g' to inc/dec the GoogLeNet probability threshold
Starting GUI, press Q to quit
actual camera resolution: 640.0 x 480.0
Traceback (most recent call last):
File "stream_ty_gn.py", line 596, in
sys.exit(main())
File "stream_ty_gn.py", line 544, in main
output, userobj = ty_graph.GetResult()
File "/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py", line 264, in GetResult
raise Exception(Status(status))
Exception: mvncStatus.TIMEOUT
I've already executed "make all" and "make opencv". Any ideas?
Thanks in advance.
@smancini Thank you for reporting this. During "make all", were there any problems? Please check to see if everything was able to build. Also just wondering if you are using a USB hub and if it is powered or unpowered.
@Tome_at_Intel Thanks for your answer. No problems during "make all". I tried using both movidius connected directly to the computer (last time, one was connected to a USB hub) and now it's working. I guess it is something to do with the USB hub.
@smancini I'm glad you got it solved. Cheers.
