6594 Discussions
mvNCCompile throws :ValueError: 'net_output' is not in list
Hello everyone
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 208, in
args.old_parser, args.cpp, args)
File "/usr/local/bin/mvNCCompile", line 186, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 83, in load_network
input_data, expected_result = p.calculateReference(arguments)
File "/usr/local/bin/ncsdk/Controllers/Parsers/Caffe.py", line 209, in calculateReference
output = self.net.forward(start=first_layer, end=out_label)
File "/opt/movidius/caffe/python/caffe/pycaffe.py", line 105, in _Net_forward
end_ind = list(self._layer_names).index(end)
  • When looking in the .prototxt file, the last described node looks like this:
    layer {
    type: "Concat"
    bottom: "Mconv7_stage4_L2"
    bottom: "Mconv7_stage4_L1"
    top: "net_output"
    concat_param {
    axis: 1
so, a "net_output" exists.
Any idea on how to solve this issue is very much appreciated.
All the best,
Bastian
Hi @bastiank
Could you try to set the top parameter to the same name of the layer (See below)?
layer { name: "concat_stage7" type: "Concat" bottom: "Mconv7_stage4_L2" bottom: "Mconv7_stage4_L1" top: "concat_stage7" concat_param { axis: 1 } }
Jesus
