opencv- default build settings
nano
Dear Community,
when building openvino from source it automatically installs opencv. The build of opencv is highly customizable. I have my own opencv build that includes parts of opencv-contrib. To make sure I link opencv correctly to openvino, what are the default build settings openvino uses for opencv?
Cheers,
Iffa_Intel
Greetings,
By default, the required version of OpenCV packages is downloaded automatically by the CMake-based script. If you already have one installed OpenCV/ already configured in your env, you may need to clean the  OpenCV_DIR environment variables before running the cmake command, otherwise they will not be downloaded and the build may fail if incompatible versions were installed.
If the CMake-based build script can not find and download the OpenCV package that is supported on your platform, or if you want to use a custom build of the OpenCV library, refer to the Use Custom OpenCV Builds section for details.
You may refer to this wiki for further info: https://github.com/openvinotoolkit/openvino/wiki/BuildingForLinux
Sincerely,
Iffa
Iffa_Intel
Greetings,
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
