6577 Discussions
openvino 2020.3 demo : multi_channel_face_detection_demo , GPU + yolov3 not work ..?
Yao__Kent
1. Environment: Ubuntu 18.04 and demo app from Openvino 2020.3
2. After running multi_channel_face_detection_demo -d GPU yolov3 model  , the output shows   => "Can't get ngraph::Function. Make sure the provided model is in IR version 10 or greater" . But running multi_channel_face_detection_demo -d HDDL or  -d CPU  with the same yolov3 model , it can work .
3. Another app : interactive_face_detection_demo -d GPU with face-detection-retail-0004 mode , it can work, (i think the GPU device  may work normally... )
4. I build the yolov3 model by using parameters below:
mo.py --data_type=FP16 --output_dir.\\FP16\\--input_model.\\Generic_Models\tensorflow-yolo-v3\frozen_darknet_yolov3_model.pb --batch 1 --tensorflow_use_custom_operations_config.\\Generic_Models\tensorflow-yolo-v3\yolo_v3.json
what is wrong with yolov3 model ?? or other reason?
Max_L_Intel
Hi @Yao__Kent
There's a known issue with object_detection_demo_yolov3_async, and seems it is supposed to be the same ngraph function error message for multi_channel_object_detection_demo_yolov3 too.
The fix for the first one should be implemented in the next software release, and the hot fix has been already posted here https://github.com/eizamaliev/open_model_zoo/commit/929d673e1176ce99f8d49d1e86ff31f2a4f25c74
With regards to Multi Channel version of Object Detection yolov3 demo, we have shared this information with developers team.
Thanks for reporting this.
Yao__Kent
Sorry,
The title update: multi_channel_object_detection_demo_yolov3
Munesh_Intel
Hi Kent,
Greetings to you.
We are currently investigating this issue, and will get back to you at the earliest.
Munesh
Max_L_Intel
Hi @Yao__Kent
Max_L_Intel
This should already be fixed in OpenVINO 2020.4 release.
