openvino C++
Arthur123
hello everyone!
I have a small question as to why model inference in python would use the
"net = ie.read_network(model,weights)" api to import model and parameters (.xml & .bin)
but In the c++ call samples:
"ie.compile_model"  only the .xml file is imported, isn't the weights file (.bin) needed?
Expecting someone to tell me why
thanks in advance!
Hairul_Intel
Hi Arthur123,
For your information, when loading a model in OpenVINO C++ API without specifying the bin_path, the core.read_model() will try to read a bin file with the same name as xml and if no bin file is found, it will load IR without weights.
You can refer the class ov::Core for more information on OpenVINO Runtime C++ API.
Hope this helps.
Hairul
Hairul_Intel
Hi Arthur123,
Hope this helps.
Hairul
Arthur123
Get it, thanks a lot!
Hairul_Intel
Hi Arthur123,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
