6577 Discussions
benchmark_app fails when running with "-infer_precision CPU:bf16"
ClinB
Hi all:
I tried to run OpenVINO benchmark_app on my AWS EC2 instance but it failed running with option "-infer_precision CPU:bf16"
AWS instance:
  • Type: m7i-flex large
  • OS: Windows Server 2019 (AMI ID: ami-065b889ab5c33720e )
  • CPU: Intel Xeon Platinum 8488C, 1 core, 2 threads (Code name: Sapphire Rapids)
  • Memory: 8G
  • HDD: 30G
(I thought this CPU should support precision FP16 & FP32)
Model:
  • asl-recognition-0004
  • downloaded by "omz_downloader --name asl-recognition-0004 --precisions FP16 --output_dir myLocalPath"
What I did:
  • (create and activate python 3.8 environment)
  • pip install openvino==2022.3
  • pip install openvino-dev==2022.3
  • omz_downloader --name asl-recognition-0004 --precisions FP16 --output_dir myLocalPath
  • benchmark_app -infer_precision CPU:bf16 -m myLocalPath\asl-recognition-0004.xml
  • (then it failed)
Although precision of the model is FP16, I tried to set -infer_precision to CPU:f32, then it ran successfully.
I also downloaded asl-recognition-0004 FP32 ver. and benchmark_app still fails when running with "-infer_precision CPU:bf16"
It now seems benchmark_app always failed when running with option "-infer_precision CPU:bf16", no matter which precision of input model.
Sorry but I failed to find related documents about this case.
Best Regards
Clin B
Aznie_Intel
Hi Clin B,
I'm able to run both FP16 and FP32 infer_precision with Benchmark_App with the latest OpenVINO 2023.0 version. Please refer below:
1) benchmark_app -infer_precision CPU:bf16 -m \<Download_dir>\FP16\asl-recognition-0004.xml
FP16FP16
2)  benchmark_app -infer_precision CPU:f32 -m \<Download_dir>\FP32\asl-recognition-0004.xml
FP32FP32
Aznie
longfei98
I also have similar issue. It seems that different cpu type and windows kernel type have different behaviors. Sometimes it crashes, sometimes not. Strange issue.
Aznie_Intel
Hi Clin B and longfei98,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.t
Aznie
