Updated OpenVINO Dockerfile
mattiasmarder
Is there an updated and tested dockerfile that supports the openvino notebook project? The dockerfile https://github.com/openvinotoolkit/openvino_notebooks/blob/main/Dockerfile gives the below error.
Hairul_Intel
Hi mattiasmarder,
From my end, I was able to complete the steps for building the Docker image for OpenVINO Notebooks following this guide in Ubuntu 20.04:
Could you please share the following information so that we can investigate this issue from our end:
  • Operating System
  • Python version
Hairul
mattiasmarder
Copy from my command line with the details asked about:
(base) administrator@ccccccc:~/opensource/openvino_notebooks$ docker --version
Docker version 20.10.25, build 20.10.25-0ubuntu1~22.04.1
(base) administrator@ccccccc:~/opensource/openvino_notebooks$ python -V
Python 3.11.4
(base) administrator@ccccccc:~/opensource/openvino_notebooks$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.1 LTS
Release: 22.04
Codename: jammy
Hairul_Intel
Hi mattiasmarder,
Thank you for sharing the information.
According to the OpenVINO Notebooks GitHub page, the System Requirements for OpenVINO Notebooks are as follows:
We'd suggest for you to use the supported Python version (3.8 - 3.10) and see if the issue is resolved.
Hairul
Hairul_Intel
Hi mattiasmarder,
This thread will no longer be monitored since we have provided suggestion. If you need any additional information from Intel, please submit a new question.
Hairul
