6574 Discussions
'openvino.inference_engine.ie_api.IENetwork' object has no attribute 'layers'
Adam_44
ubuntu 18.04
Python 3.7.3
I updated my OpenVINO from v2020.2.12 to v2021.2.185.
I faced 2 issues I couldn't solve:
1. I cannot visualize my yolo detection (cannot get layer params):
layer_params = YoloParams(self.network.layers[layer_name].params, out_blob.shape[2])
AttributeError: 'openvino.inference_engine.ie_api.IENetwork' object has no attribute 'layers'
2. And for the same reason I cannot check my model for unsupported layers:
unsupported_layers = [l for l in self.network.layers.keys() if l not in supported_layers]
Could you point me alternative solutions for these?
Thanks in advance!
Adli
Hi Adam_44,
Thank you for reaching out to us. 'ie_api.IENetwork.layers' is deprecated. The property has been removed in the 2021.2 release. Please refer to the following link: https://docs.openvinotoolkit.org/2021.1/ie_python_api/classie__api_1_1IENetwork.html
We suggest you use get_ops()/get_ordered_ops() methods from nGraph Python API for 2021.2 release. nGraph is the OpenVINO™ graph manipulation library, used to represent neural network models in the form of a computational graph. With nGraph Python APIs, you can create, inspect, and modify computational graphs.
You can use the nGraph function's get_ordered_ops method to get a topologically sorted list of its graph Nodes. Please refer to the following page for the examples.
Adli
Adli
Hi Adam_44,
Adli
Adam_44
Hi Adli,
Thank you for your answer! I managed to sort it out with the sources provided.
If anyone wants to run the object_detection_demo_yolov3_async from the earlier release, adding/changing the following lines worked for me:
import ngraph as ng
function = ng.function_from_cnn(self.network)
self.anchors = param['anchors']
mask = param['mask']
out_blob = out_blob.reshape(net.outputs[layer_name].shape)
params = [x._get_attributes() for x in function.get_ordered_ops() if x.get_friendly_name() == layer_name][0]
layer_params = YoloParams(params, out_blob.shape[2])
Adam_44
Benjamin1
Hi Adam , can you share me code of the object_detection_demo_yolov3_async.py  ?
It would help me a lot, I'm with the new version of OpenVIno and I can't solve the problem, thanks
Adam_44
Hi @Benjamin1,
Sure thing!
I created a gist:
https://gist.github.com/AdamGerzsai/d2b596729e127e449cbf2e6613411dd0
It is working for me, however I'd recommend you to study the object_detection_demo from the latest version for more sophisticated solution.
It has implementations for various different model architectures including yolo.
Precisely they are in 'python_demos/common/models' folder, which I couldn't find earlier.
Adli
Hi Adam_44,
Thank you for sharing your workaround. We highly value your contribution to this community.
Adli
Adli
Hi Adam_44,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Adli
venkatanil
hey did you find the solution for the 2nd question?
