openvino multiple source
Nexn
초급자
1,082 조회수
Could I know is it possible to capture the multiple live streams and run the different inference on the each soure (each streams) in open vino?
Thanks and regards,
Nexn.
0 포인트
5 응답
Aznie_Intel
중재자
1,031 조회수
Hi Nexn,
Thanks for reaching out. It is possible with the DL Streamer multi-stream pipeline, which contains multiple sub-pipelines, each processing one source. You may check these Video streams from multiple cameras.
I hope this helps you.
Aznie
0 포인트
Nexn
초급자
1,017 조회수
Hi Aznie,
Thanks for your response.
I need to run individual inference in all my multiple live rtsp streams.
In the (source 1) first stream , I want to detect persons only . In the (source 2) second stream, I want to detect other some sort of things rather than persons.
Is that possible in openvino?
Nexn.
0 포인트
Aznie_Intel
중재자
976 조회수
Hi Nexn,
Yes, you can perform multi-input and multi-object detection. However, the performance might drop significantly and might not work if too much input video is supplied. The Multi Camera Multi Target Python* Demo is a demo from Open Model Zoo that might suit your objective.
Aznie
0 포인트
Nexn
초급자
937 조회수
Hi Aznie,
I will try.
Thanks and regards,
Nexn.
0 포인트
Aznie_Intel
중재자
917 조회수
Hi Nexn,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
0 포인트
응답
