parameter supported of Convolution (CONV)
I read firmware features in release report below.
https://github.com/movidius/ncsdk/releases/tag/v2.04.00.06
In the first "Convolutions" says that: _The following cases have been extensively tested: 1x1s1,3x3s1,5x5s1,7x7s1, 7x7s2, 7x7s4_
I am using 5x5s2 CONV, I wonder if it's supported, too?
Is it not tested or not supported?
The other question:
In "Errata: 7th" says that: _Convolution may fail to find a solution for very large inputs._
How large is the "very large input" means?
Thank you.
