6605 Discussions
pedestrian-and-vehicle-detector-adas-0001 in python version
rnd-amg
Hi team,
i already test  pedestrian-and-vehicle-detector-adas-0001 models in my rasp 4B + NCS but i cant customize the code, any python code version for this  pedestrian-and-vehicle-detector-adas-0001 model or may be you have some reference?
Regrads,
rnd
Hairul_Intel
Hi rnd,
If I understand you correctly, you were able to run pedestrian-and-vehicle-detector-adas-0001 using the Object Detection C++ demo as we've discussed in previous thread but were unable to customize the code.
And now, you've opened this thread to seek information regarding Python demo and its references, am I right?
If that's the case, Object Detection Python Demo is available from Open Model Zoo and supports pedestrian-and-vehicle-detector-adas-0001 model. Here is the link to the codes for Object Detection Python Demo.
However, you would not be able to run the Python demo using Raspberry Pi and NCS2, as the nGraph module is not included in the OpenVINO™ Toolkit for Raspbian OS Package. You have to build Open Source OpenVINO™ Toolkit for Raspbian OS in order to import the nGraph module. Follow this guide on Building Open Source OpenVINO™ toolkit for Raspbian* OS and Intel® Neural Compute Stick 2.
Hairul
rnd-amg
Hi @Hairul_Intel ,
Thanks for the reply
is it able if i run only a python file without models (.xml) file?
rnd
Hairul_Intel
Hi rnd,
No, the Python demo would not be able to run without model files. For your information, all of our code samples and application demos require model files for use in inferencing and producing results.
Watch our Inference Engine Python Sample | OpenVINO™ toolkit | Ep. 17 | Intel Software video to better understand how inferencing is done in a Python application.
On another note, refer to the following diagram which illustrates the typical OpenVINO™ workflow:
For a much simpler explanation in video format, watch our Full Inference flow | OpenVINO™ toolkit | Ep. 03 | Intel Software video.
Additionally, here is the full tutorial playlist OpenVINO™ toolkit | Tutorial Series | Intel Software to help you understand OpenVINO™ Toolkit better and utilize it effectively.
Hairul
Hairul_Intel
Hi rnd,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
