problem with using accuracy checker
whung6
So I'd successfully convert my model into INT8 format, after this, I'm trying to use the accuracy checker to see whether my model will perform.
I ran the following command line
$ python3 accuracy_check.py \
--config /opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/configs/resnet-50.yml \
--models /opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/public/resnet-50/ \
--source /home/ubuntu/imagenet/val/ \
-a /home/ubuntu/imagenet/annotations/imagenet/ \
-td CPU \
-e /opt/intel/openvino_2019.3.376/deployment_tools/inference_engine/lib/intel64/libcpu_extension_avx2.so \
-M /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/ \
--definitions /opt/intel/openvino_2019.3.376/deployment_tools/tools/calibration_tool/configs/definitions.yml
however the result is
Result:
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a sy
nonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 _np_qint8 = np.dtype([("qint8", np.int8, 1)])
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a sy
 _np_quint8 = np.dtype([("quint8", np.uint8, 1)])
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a sy
 _np_qint16 = np.dtype([("qint16", np.int16, 1)])
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a sy
 _np_quint16 = np.dtype([("quint16", np.uint16, 1)])
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a sy
 _np_qint32 = np.dtype([("qint32", np.int32, 1)])
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a sy
 np_resource = np.dtype([("resource", np.ubyte, 1)])
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type'
as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type'
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type'
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type'
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type'
15:25:29 accuracy_checker WARNING: /usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type'
Processing info:
model: resnet-50-cf
launcher: caffe
device: CPU
dataset: imagenet_1000_classes
OpenCV version: 4.1.2-openvino
Traceback (most recent call last):
 File "accuracy_check.py", line 19, in <module>
  main()
 File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/main.py", line 202, in main
  model_evaluation_mode(config, progress_reporter, args)
 File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/main.py", line 218, in model_evaluation_mode
  model_evaluator = ModelEvaluator.from_configs(launcher_config, dataset_config)
 File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/evaluators/model_evaluator.py", line 57, in from_configs
  dataset = Dataset(dataset_config)
 File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/dataset.py", line 66, in __init__
  raise ConfigError('path to converted annotation or data for conversion should be specified')
accuracy_checker.config.config_validator.ConfigError: path to converted annotation or data for conversion should be specified
Clearly I'm missing something, but i can't figure out what is missing.
I also provide the file context below to make it easier to know my situation.​
resnet-50.yml:
models:
 - name: resnet-50-cf
  launchers:
   - framework: caffe
    model:  public/resnet-50/resnet-50.prototxt
    weights: public/resnet-50/resnet-50.caffemodel
    adapter: classification
  datasets:
   - name: imagenet_1000_classes
    preprocessing:
     - type: resize
      aspect_ratio_scale: greater
     - type: crop
     - type: normalization
      mean: 104, 117, 123
 - name: resnet-50
  launchers:
   - framework: dlsdk
    tags:
     - FP32
    model:  public/resnet-50/FP32/resnet-50.xml
    weights: public/resnet-50/FP32/resnet-50.bin
   - framework: dlsdk
    tags:
     - FP16
    model:  public/resnet-50/FP16/resnet-50.xml
    weights: public/resnet-50/FP16/resnet-50.bin
  datasets:
    preprocessing:
     - type: resize
     - type: crop
The definitions.yml file is from https://software.intel.com/en-us/forums/computer-vision/topic/807243
David_C_Intel
Hi whung6,
Thank you for contacting Intel Customer Support.
I am currently working on your inquiry, I will reply you back as soon as possible.
If you have any other questions, feel free to ask.
David C.
A Contingent Worker at Intel
whung6
David_C_Intel
Hi whung6,
I apologize for the delay in our response, looking further into the error message. It looks like you may need to update the definitions.yml to ensure data_source is pointing to the path to the directory with input data and the annotation is pointing to the pickle file.
Let us know if you need further assistance.
David C.
whung6
Thanks for the solution, I did mispoint to the wrong directory, after fixing the problem I can now work well.
