protobuf: not installed, required: 3.6.1 ?
Shintani__Eigo
Hi, I will convert googlenet-v4.caffemodel to IR, so I run mo.py as
python3 /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/mo.py --input_model ~/openvino_models/classification/googlenet/v4/caffe/googlenet-v4.caffemodel --scale 256 --mean_values [105,105,105] --output ~/openvino_models/ir/FP32/googlenet-v4
but error message appears,
Model Optimizer arguments:
Common parameters:
    - Path to the Input Model:     /home/shintani/openvino_models/classification/googlenet/v4/caffe/googlenet-v4.caffemodel
    - Path for generated IR:     /home/shintani/openvino_models/generate_IR/.
    - IR output name:     googlenet-v4
    - Log level:     ERROR
    - Batch:     Not specified, inherited from the model
    - Input layers:     Not specified, inherited from the model
    - Output layers:     /home/shintani/openvino_models/ir/FP32/googlenet-v4
    - Input shapes:     Not specified, inherited from the model
    - Mean values:     [105,105,105]
    - Scale values:     Not specified
    - Scale factor:     256.0
    - Precision of IR:     FP32
    - Enable fusing:     True
    - Enable grouped convolutions fusing:     True
    - Move mean values to preprocess section:     False
    - Reverse input channels:     False
Caffe specific parameters:
    - Enable resnet optimization:     True
    - Path to the Input prototxt:     /home/shintani/openvino_models/classification/googlenet/v4/caffe/googlenet-v4.prototxt
    - Path to CustomLayersMapping.xml:     Default
    - Path to a mean file:     Not specified
    - Offsets for a mean file:     Not specified
Model Optimizer version:     1.5.12.49d067a0
[ ERROR ]
Detected not satisfied dependencies:
Please install required versions of components or use install_prerequisites script
/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites_caffe.sh
Note that install_prerequisites scripts may install additional components.
This is on ubuntu 18.06, and I installed protobuf 3.6.1
$ protoc --version
libprotoc 3.6.1
How can I run this, or avoid this message ?
Best, Eigo
Saw__Joo
The suggested `pip install --upgrade protobuf==3.6.1` did not work for me on my fresh Ubuntu 18.04 LTS install.
What worked for me was download the 3.6.1 release tar ball from https://github.com/protocolbuffers/protobuf/releases.
tar -xf protobuf-all-3.6.1.tar.gz
cd protobuf-3.6.1
./configure
make
make check
sudo make install
cd ./python
python3 setup.py build
python3 setup.py test
sudo python3 setup.py install
Shubha_R_Intel
Hello Eigo. Did you run the install_prerequisites script first as the error indicates ?
Shintani__Eigo
Hi Shubha,
Yes. curiously in the case of squeezenet, it is successful.
$python3 /opt/intel//computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo.py --input_model ~/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel --output_dir ~/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe --data_type FP32
Common parameters:
    - Path to the Input Model:     /home/shintani/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel
    - Path for generated IR:     /home/shintani/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe
    - IR output name:     squeezenet1.1
    - Log level:     ERROR
    - Output layers:     Not specified, inherited from the model
    - Mean values:     Not specified
    - Scale factor:     Not specified
    - Path to the Input prototxt:     /home/shintani/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.prototxt
[ WARNING ]
    protobuf: installed: 3.0.0, required: 3.6.1
[ SUCCESS ] Generated IR model.
[ SUCCESS ] XML file: /home/shintani/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
[ SUCCESS ] BIN file: /home/shintani/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe/squeezenet1.1.bin
[ SUCCESS ] Total execution time: 1.67 seconds.
Best,
Eigo
Shubha_R_Intel
OK. This is interesting. Why not then try pip install --upgrade protobuf==3.6.1 ? Agreed you shouldn't have to do this. install_prerequsites.sh should take care of it. But can you try and see what happens ?
Shubha
Shintani__Eigo
Hi Shubha,
Great, it is successful after pip;
$ pip install --upgrade protobuf==3.6.1
Collecting protobuf==3.6.1
  Downloading https://files.pythonhosted.org/packages/3a/30/289ead101f94998d88e8961a3548aea29417ae0057be23972483cddebf4f/protobuf-3.6.1-cp37-cp37m-manylinux1_x86_64.whl (1.1MB)
    100% |████████████████████████████████| 1.1MB 3.5MB/s
Requirement already satisfied, skipping upgrade: setuptools in /home/shintani/anaconda3/lib/python3.7/site-packages (from protobuf==3.6.1) (40.6.3)
Requirement already satisfied, skipping upgrade: six>=1.9 in /home/shintani/anaconda3/lib/python3.7/site-packages (from protobuf==3.6.1) (1.12.0)
Installing collected packages: protobuf
Successfully installed protobuf-3.6.1
Best,
Eigo
Saw__Joo
cd protobuf-3.6.1
./configure
make
make check
sudo make install
cd ./python
Virgen__Francisco
Hello there!
I do have the a similar issue, It failed squeezenet1.1
[ ERROR ]
protobuf: not installed, required 3.6.1
I do have protobuf
ptotoc --version
libprotoc 3.11.1
Do I need to go back on version?
Luis_at_Intel
Hi Virgen, Francisco,
Please try what Saw, Joo did, which is to install protobuf==3.6.1 manually from source. Make sure you uninstall the version you have currently installed prior doing this, let us know if you run into issues.
Luis
SSola8
Most of the library are installed in roor directory. Please give it a try with sudo.
cd /opt/intel/openvino/deployment_tools/demo
./demo_squeezenet_download_convert_run.sh
Look closely the log text.
