python samples
Morishige__Akihito
When I run the python samples, error is occures as follows.
    from openvino.inference_engine import IENetwork, IEPlugin
ImportError: No module named 'openvino'
How do I download the openvimo module ?
Monique_J_Intel
Hi Akihito,
You may want to try setting up the OpenVINO environment variables:
source /opt/intel/computer_vision_sdk/bin/setupvars.sh
If that doesn't work then can you answer the following questions:
1.)What version of OpenVINO are you using?
2.)What is the command that you are using to run the sample?
Kind Regards,
Monique Jones
Monique_J_Intel
Hi Akihito,
Kind Regards,
Monique Jones
nikos1
Valued Contributor I
Yes, indeed, this is the typical error you get if you don't source setupvars.sh .  After sourcing runs fine here in R3,
Morishige__Akihito
 After sourcing setupvars.sh, sample works well.
Thanks a lot.
Michael_D_Intel2
I have the same problem but source setupvars.sh doesn't eliminate the problem. It is strange since I didn't have this problem but after I did a reboot and source the setupvars.sh the script which woked fine before now it gives me this:
movidius@movidius-desktop:~/intel/ncappzoo/caffe/vgg16$ ./source_setupvars.sh
[setupvars.sh] OpenVINO environment initialized
movidius@movidius-desktop:~/intel/ncappzoo/caffe/vgg16$ make run_py
making caffemodel
caffemodel file already exists
making prototxt
prototxt file already exists
making deps
making data
(cd ../../data/ilsvrc12; make)
make[1]: Entering directory '/home/movidius/intel/ncappzoo/data/ilsvrc12'
make[1]: Leaving directory '/home/movidius/intel/ncappzoo/data/ilsvrc12'
making compile
compiled model already exists
making run_cpp
python3 ../../apps/simple_classifier_py/simple_classifier.py -m VGG_ILSVRC_16_layers.xml -d MYRIAD -i ../../data/images/nps_electric_guitar.png;
Traceback (most recent call last):
  File "../../apps/simple_classifier_py/simple_classifier.py", line 24, in <module>
Makefile:143: recipe for target 'run_py' failed
make: *** [run_py] Error 1
Michael_D_Intel2
The following steps helped to get rid of all the errors and eliminate some extra steps:
1st step:
sudo rm /usr/bin/python
sudo ln -sfn /usr/bin/python3.5 /usr/bin/python
2nd step in .bashrc add these lines:
source /home/movidius/intel/computer_vision_sdk/bin/setupvars.sh
echo PYTHONPATH=$PYTHONPATH
So, now I don'’t have to worry what version of python is used because I forced it to 3.5 and is there every new terminal I open.
The source of setupvars.sh in .bashrc eliminates the step of sourcing every time you are in a new terminal.
lai__autumn
Hi, I'm run openvino demo:
python3 object_detection_demo_yolov3_async.py --labels /home/pi/Downloads/OpenVINO-YoloV3-master/coco.names -i /home/pi/Desktop/20190413_092723A.mp4 -m /home/pi/Desktop/frozen_darknet_yolov3_model.xml -d MYRIAD --cpu_extension /opt/intel/openvino/deployment_tools/inference_engine/lib/armv7l/libcpu_extension.so
error:
  File "object_detection_demo_yolov3_async.py", line 27, in <module>
How to solve it?
Thank you!
