6594 Discussions
pytorch transforms.Compose to ov::preprocess::PrePostProcessor
Enlin
I have python code like below, how to convert to C++ and get same result.
I get different result beteen Python and C++ version
===python===
model = core.read_model(model=model_path)
compiled_model = core.compile_model(model=model, device_name='AUTO')
input_layer = model.input(0)
output_layer = compiled_model.output(0)
img = Image.open(IMAGE_PATH)
loader = transforms.Compose([
    transforms.ToTensor(),
    transforms.Normalize([0.5], [0.5]),
img_float = loader(img).float()
input_image = np.expand_dims(img_float, 0)
result = compiled_model([input_image])
===C++===
ov::preprocess::PrePostProcessor ppp(model);
ppp.input("input").tensor()
    .set_element_type(ov::element::u8)
    .set_layout("NHWC");
ppp.input().model()
    .set_layout("NCHW");
ppp.input("input").preprocess()
    .convert_element_type(ov::element::f32)
    .mean(0.5)
    .scale(0.5);
model = ppp.build();
ov::CompiledModel compiled_model = core.compile_model(model, device_name);
ov::InferRequest infer_request = compiled_model.create_infer_request();
infer_request.set_input_tensor(input_tensor);
infer_request.infer();
Enlin
after my test, they are equal totally:
python:
img = Image.open(image_path)
loader = transforms.Compose([transforms.ToTensor(),
                            transforms.Normalize([0.5], [0.5])])
input_tensor = loader(img)
c++
ppp.input("input_1").tensor()
ppp.input("input_1").preprocess().
.scale(255)
.mean(0.5)
.scale(0.5)
ppp.input().model()
Aznie_Intel
Hi Enlin,
Thanks for reaching out.
You may refer to the Integrate OpenVINO with Your Application documentation for the steps to implement OpenVINO™ Runtime inference pipeline in your application. The codes are available for Python, C++, and C.
Aznie
Enlin
Hi Aznie,
thanks for your reply. I did those steps from your recommand document before.
I can run inference in both python and c++ model. horever my points is I can not get same result from same model and same input between python and c++.
I guess this is cause by ppp, is that totally equal from those code:
    .mean(0.5)
    .scale(0.5);
Enlin
Aznie_Intel
Hi Enlin,
The incorrect result might be due to incorrect filling of tensor data in the preprocessing part of the C++ code. Ensure the channels when preprocessing the image match the channels of the model. You might miss the normalized part of your code.
 auto input_layer = model.get_method("input");
   auto output_layer = compiled_model.get_method("output");
   torch::transforms::Normalize transform({0.5}, {0.5});
Hope this helps.
Aznie
Aznie_Intel
Hi Enlin,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
Enlin
Hi Aznie,
I find the different result from c++ and python finally.
the input image is RGB grayscale png, in the pytorch:
====python
loader = transforms.Compose([transforms.ToTensor()])
print(input_tensor.shape)
the shape is (1, 120, 160) , and the Tensor data range is 0~1.0
====C++
I need to chage image to grayscal manually
OCVReader::OCVReader(const string& filename) {
img = cv::imread(filename);
if (isGrayscale(img)) {
  cv::cvtColor(img, img, cv::COLOR_BGR2GRAY);
FormatReader::ReaderPtr reader(image_path.c_str());
std::shared_ptr<unsigned char> input_data = reader->getData();
ov::Tensor input_tensor = ov::Tensor(input_type, input_shape, input_data.get());
//normalize data range to 1.0~0.0
.scale(255);
ppp.input().model()
then I can get same result from python and c++ in case of without additional IPP
horever, after I add normalize operation
==== python
==== C++
.scale(255)
.mean(0.5);
 the result is different.
 is there equally preprocess to pytorch transforms.Normalize([0.5], [0.5])] in C++ PrePostProcessor ?
thanks
Enlin
Enlin
python:
c++
.scale(255)
.mean(0.5)
.scale(0.5)
ppp.input().model()
