question about build application in inference engine developer guide
rongrong__wang
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Integrate_with_customer_application_new_API.html
I wrote my inference codes according to this document.In the step Build your application, I can not understand it.I don't know how to build application.
Thanks!
Shubha_R_Intel
Dear rongrong, wang
First please use OpenVino 2019R2 if you haven't done so already.
It's really simple.
1) copy one of the sample folders C:\Program Files (x86)\IntelSWTools\openvino_2019.2.242\inference_engine\samples into a new one and rename it to your project
2) Change the CMakeLists.txt file to reflect your target (project) name
3)  run setupvars.bat (or *.sh) under bin
4) run build_samples_msvc.bat
Your new project will be built automatically. These instructions are for Windows but for Linux it will be similar.
Hope it helps,
A standalone project is a bit more complicated. I'd advise Open Source dldt for that. R2 should be added soon.  I have given extensive instructions on how to build a standalone project to github issue 173
Shubha
rongrong__wang
OK ,Thank you
