6598 Discussions
"No op named NonMaxSuppressionV2 in defined operations." in mvNCCompile
I am trying to compile my model which is based on Tensorflow Object Detection "rfcn_resnet101_coco_11_06_2017" (URL).
While using "mvNCCompile" command i am getting below error.
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 211, in parse_tensor
tf.import_graph_def(graph_def, name="")
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py", line 280, in import_graph_def
raise ValueError('No op named %s in defined operations.' % node.op)
ValueError: No op named NonMaxSuppressionV2 in defined operations.
Command which i used: mvNCCompile frozen_inference_graph.pb -in=image_tensor -on=detection_boxes,detection_scores,detection_classes,num_detections
