6614 Discussions
"RuntimeError: could not create a primitive" when compiling model
mf22
I tried deploying the following PyTorch Module to OpenVINO. The model exports to ONNX and Openvino but when trying to compile and use it I get the "RuntimeError: could not create a primitive" error.
Versions: I tried both openvino / openvino-dev 2022.2 and 2022.1, onnx 1.11.0; Ubuntu 20.04; CPU Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
class TemplateMatch(nn.Module):
    Custom Template Matching layer.
    Uses normalized correlation to find the best match.
        (Can be easily modified to use other metrics.)
    This is re-implemantation of OpenCV-s matchTemplate,
        with CCOEFF_NORMED metric.
    For testing of faster native deployment (Intel OpenVINO on CPU /
    integrated GPU).
    def __init__(self, templates, masks,
                 padding=0,  # 'valid'  # 0; changed from earlier versions
                 device='cpu'
        Inputs
        template - (l2-normalized !) template (only masked region !),
                   torch.Tensor
        mask - binary mask of the same shape as template
        super().__init__()
        self.template_shape = templates.shape
        in_ch, out_ch, k1, k2 = self.template_shape  # 1, nr_templates,
                                                     # (template size)
        self.template_sums = torch.sum(templates,  # .flatten(2, -1),
                # dim=-1).to(device)
                dim=(2, 3)).to(device)
        self.mask_sums = torch.sum(masks,  # .flatten(2, -1),
        self.device = device
        # Fixed convolution with ones; used for normalization
        self.conv_norm = nn.Conv2d(in_ch, out_ch, (k1, k2),
                                   padding=padding)
        self.conv_norm.weight = nn.Parameter(data=masks,
                                             requires_grad=False)
        # Leave default padding (zeros)
        self.correlation = nn.Conv2d(in_ch, out_ch, (k1, k2),
                                     padding=padding)
        # NOTE: template * mask should already be done before
        self.correlation.weight = nn.Parameter(data=templates,  # * masks
    def forward(self, input_):
        # get (masked) norms for all blocks (mask is included in conv_norm
        # definition)
        # NOTE: padding must be 0 i.e. 'valid for this'
        # NOTE: masks * ... is not necessary (template is already masked)
        # h, w = self.template_shape[2:]
        sums = self.conv_norm(input_)  # / self.mask_sums
        centers = torch.div(sums, self.mask_sums)  # sums / self.mask_sums
        norms = torch.sqrt(self.conv_norm(
            # torch.square(input_))
            input_ * input_)
            - sums * 2. * centers
            + self.mask_sums * centers * centers  # torch.square(centers)
        # Return correlation tensor
        # We only look at masked region implicitly (convolution kernel is
        # already masked)
        result = torch.div(
            self.correlation(input_) - self.template_sums * centers,
            norms)[0].flatten(1, -1)
        max_ind = torch.argmax(result, dim=-1)
        return result[:, max_ind], max_ind.to(torch.int32)
        # return torch.max(
        #     torch.div((self.correlation(input_) - self.template_sums * centers)
        #         , norms)[0].flatten(1, -1),  # remove batch dim
        #     dim=-1  # torch.tensor([0, 1])  # .to(self.device)
        # )  # , centers.shape
Wan_Intel
Hi Mf22,
Did you encounter the same error when using your ONNX model without utilizing the OpenVINO™ toolkit?
Could you share the following information with us for replication purposes?
·      PyTorch model
·      ONNX model
·      Intermediate Representation (IR)
·      Source code to compile and use the IR with OpenVINO™ toolkit
·      Source code to use the ONNX model without utilizing the OpenVINO™ toolkit
Wan
Wan_Intel
Hi Mf22,
Thanks for your information.
For your information, I’ve validated that your model was able to compile with OpenVINO™ toolkit.
On another note, ONNX model and IR work fine with Benchmark Python Tool.
ONNX:
IR:
Could you please provide the step to reproduce the error so we can replicate from our end?
Wan
mf22
Hi @Wan_Intel ,
thank you for your feedback.
torch -> onnx:
torch.onnx.export(
            model.cpu() if dynamic else model,  # --dynamic only compatible with cpu
            im.cpu() if dynamic else im,
            f,
            verbose=False,
            opset_version=opset,
            training=torch.onnx.TrainingMode.TRAINING if train else torch.onnx.TrainingMode.EVAL,
            do_constant_folding=not train,
            input_names=['images'],
            output_names=['output'],
            dynamic_axes={
                'images': {
                    0: 'batch',
                    2: 'height',
                    3: 'width'},
                'output': {
                    0: 'batch',
                    1: 'anchors'}
            } if dynamic else None)
onnx -> Openvino IR:
import openvino.inference_engine as ie
f = str(file_).replace('.pt', f'_openvino_model{os.sep}')
cmd = f"mo --input_model {file_.with_suffix('.onnx')} --output_dir {f} --data_type {'FP16' if half else 'FP32'}"
subprocess.check_output(cmd.split())  # export
Output of
benchmark_app -m model.xml
is:
[Step 1/11] Parsing and validating input arguments
[ WARNING ]  -nstreams default value is determined automatically for a device. Although the automatic selection usually provides a reasonable performance, but it still may be non-optimal for some cases, for more information look at README.
[Step 2/11] Loading OpenVINO
[ WARNING ] PerformanceMode was not explicitly specified in command line. Device CPU performance hint will be set to THROUGHPUT.
[ INFO ] OpenVINO:
         API version............. 2022.1.0-7019-cdb9bec7210-releases/2022/1
[ INFO ] Device info
         CPU
         openvino_intel_cpu_plugin version 2022.1
         Build................... 2022.1.0-7019-cdb9bec7210-releases/2022/1
[Step 3/11] Setting device configuration
[ WARNING ] -nstreams default value is determined automatically for CPU device. Although the automatic selection usually provides a reasonable performance, but it still may be non-optimal for some cases, for more information look at README.
[Step 4/11] Reading network files
[ INFO ] Read model took 5.35 ms
[Step 5/11] Resizing network to match image sizes and given batch
[ INFO ] Network batch size: 1
[Step 6/11] Configuring input of the model
[ INFO ] Model input 'images' precision f32, dimensions ([...]): 1 1 975 1714
[ INFO ] Model output 'output' precision f32, dimensions ([...]): 1 1
[ INFO ] Model output '30' precision i32, dimensions ([...]): 1
[Step 7/11] Loading the model to the device
[ ERROR ] could not create a primitive
Traceback (most recent call last):
  File "/home/proto-touchpad/app/code/vindija/venv/lib/python3.8/site-packages/openvino/tools/benchmark/main.py", line 298, in run
    compiled_model = benchmark.core.compile_model(model, benchmark.device)
  File "/home/proto-touchpad/app/code/vindija/venv/lib/python3.8/site-packages/openvino/runtime/ie_api.py", line 266, in compile_model
    super().compile_model(model, device_name, {} if config is None else config)
 Versions are as mentioned above: Openvino 2022.1, onnx 1.11.0.
network = ie.read_model(model=model_file,
                        weights=Path(model_file).with_suffix('.bin'))
executable_network = ie.compile_model(model=network,
                                      device_name="CPU"
gives the same error as above.
The models are here: https://drive.google.com/drive/folders/1SBqaClQOiZRn3LU9zJYOa-FtbgTS9BeO?usp=sharing
Code used for inference:
from time import time
from pathlib import Path
import numpy as np
#from PIL import Image
# OpenVINO
# from openvino.inference_engine import (IECore as Core,
#                                        # Tensor
# API v2.0
from openvino.runtime import Core, Tensor
import psutil
# from memory_profiler import profile
from config import POS
range_w, range_h = POS[0]
IMGSZ = (range_h[1] - range_h[0],
         range_w[1] - range_w[0])
print(f'IMGSZ: {IMGSZ}')
DTYPE = np.float32  # TODO: set np.float16?
CACHE_DIR = Path.cwd().joinpath('openvino_cache')
MODE = 0o771
CACHE_DIR.mkdir(mode=MODE, parents=True,
                exist_ok=True)
class OpenVINOWrapper():
    YOLO wrapper class for OpenVINO inference engine.
    def __init__(self, model_files=None,
                 img_shape=IMGSZ,
                 batch_size=1,
                 dtype=DTYPE,  # np.float32,  # float16
                 cache_dir=CACHE_DIR,
                 device='cpu',
                 EXT='.onnx',  # '.xml',
                 num_threads=None):
        YOLO wrapper, for OpenVINO inference.
        Inputs
        w - model file (.xml) or corresponding folder
        assert model_files is not None, "Models must be provided."
        w, h = img_shape
        input_shape = (batch_size, 1, h, w)  # input is Sobel-gradient image
        self.dtype = dtype
        ie = Core()
        available_devices = ie.available_devices
        print(f'AVAILABLE DEVICES: {available_devices}')
        ie.set_property({'CACHE_DIR': cache_dir})
        # ie.set_config(config={'cache_dir': str(cache_dir)},
        #         device_name="CPU")
        self.executable_networks = []
        self.output_layers = []
        for model_file in model_files:
            if not Path(model_file).is_file():  # if not *.xml
                # get *.xml file from *_openvino_model dir
                model_file = next(Path(model_file).glob(f'*{EXT}'))
            print(f'model file: {model_file}')
            # network = ie.read_network(model=model_file,
            #                           weights=Path(model_file).with_suffix('.bin'),
            # APi v2.0
            print(f'NETWORK: {network}')
            # executable_network = ie.load_network(network,
            #                                      "CPU",
            #                                      num_requests=1)
                                                  device_name="CPU"
            self.executable_networks.append(executable_network)
            self.output_layers.append(next(iter(executable_network.outputs)))
        nthreads = compiled_model.get_property("INFERENCE_NUM_THREADS")
        nireq = compiled_model.get_property("OPTIMAL_NUMBER_OF_INFER_REQUESTS")
        print(f'Num. threads for inference: {nthreads}\n'
              f'Optimal number of infer requests: {nireq}')
        # Initialize i.e. declare batch
        self.input_shape = (len(model_files), *input_shape)
        self.batch = np.zeros(self.input_shape, dtype=self.dtype)
    @property
    def input_shapes(self):
        return [self.input_shape]  # * len(self.executable_networks)
    @property
    def inputs_memory(self):
        return self.batch
    # @profile
    def execute(self):  # , batch):
        Inference.
        Use async execution.
        See:
            https://docs.openvino.ai/latest/openvino_docs_OV_UG_Infer_request.html#doxid-openvino-docs-o-v-u-g-infer-request
        Inputs
        Outputs
        y - output tensor
        elapsed_time
        mem_info
        st_time = time()
        # Infer requests for async inference?
        # TODO: check multiple networks implementation
        infer_requests = []
        # add sub-networks/models, see above, for every pin location
        for ind, executable_network in enumerate(self.executable_networks):
            infer_request = executable_network.create_infer_request()
            # infer_request = executable_network.requests[0]
            infer_request.set_input_tensor(Tensor(array=self.inputs_memory[ind], shared_memory=False))
            # input_blobs = infer_request.input_blobs
            # data = input_blobs["images"].buffer
            # Original I64 precision was converted to I32
            # assert data.dtype == np.int32
            # Fill the first blob ...
            # data = self.inputs_memory[ind]
            # infer_request.set_callback()
            # Run asynchronously and wait for result
            # infer_request.start_async()  # run_async()
            # result = infer_request.infer()
            # infer_requests.append(result)  # infer_request)
            infer_requests.append(infer_request)
        outputs = []
        for infer_request in infer_requests:
            # infer_request.wait()
            # Get output
            y = infer_request.get_output_tensor().data  # [self.output_layer]
            # Get output blobs mapped to output layers names
            # output_blobs = infer_request.output_blobs
            # y = output_blobs["output"].buffer
            # assert y.dtype == np.int32
            # Process output data
            outputs.append(y)  # infer_request.get_output_tensor()[self.output_layer])
        # y = self.executable_network(self.inputs_memory)[self.output_layer]
        elapsed_time = time() - st_time
        mem = psutil.virtual_memory()
        mem_info = [mem.free, mem.total]
        # return y, elapsed_time, mem_info
        return outputs, elapsed_time, mem_info
    # Define __enter_ and __exit__ just because engine will be used as context
    def __enter__(self):
        return self
    def __exit__(self, exc_type, exc_value, exc_tb):
        pass
Code used for inference with ONNX:
import numpy as np
import onnxruntime
import psutil
DTYPE = np.float32
class ONNXWrapper():
                 img_shape=IMGSZ,
                 batch_size=1,
                 num_threads=None):
        Inputs
        w, h = img_shape
        self.dtype = dtype
        self.networks = []
                model_file = next(Path(model_file).glob('*.onnx'))
            # ONNX runtime
            providers = ['CPUExecutionProvider']  # ['CUDAExecutionProvider', 'CPUExecutionProvider']
            session = onnxruntime.InferenceSession(str(model_file),
                                                   providers=providers)
            # meta = session.get_modelmeta().custom_metadata_map  # metadata
            # if 'stride' in meta:
            #     stride, names = int(meta['stride']), eval(meta['names'])
            self.networks.append(session)
        # No several models here
    @property
    @property
        return self.batch
    # @profile
        Inference.
        Inputs
        Outputs
        y - output tensor
        elapsed_time
        mem_info
        st_time = time()
        outputs = []
        print(f'net: {self.networks}')
        for ind, net in enumerate(self.networks):
            # ONNX runtime
            # io_binding = net.io_binding()
            # OnnxRuntime will copy the data over to the CUDA device if 'input' is consumed by nodes on the CUDA device
            # io_binding.bind_cpu_input(net.get_inputs()[0].name,
            #                           self.inputs_memory[ind])
            # io_binding.bind_output('output')  # [out_.name for out_ in net.get_outputs()])
            print(f'Running... Output names: {[out_.name for out_ in net.get_outputs()]}')
            # print(f'Input shape: {self.inputs_memory.shape, np.max(self.inputs_memory)}')
            out = net.run([out_.name for out_ in net.get_outputs()],
                          {net.get_inputs()[0].name:
                           self.inputs_memory[ind]})
            # net.run_with_iobinding(io_binding)
            # out = io_binding.copy_outputs_to_cpu()
            outputs.append(out)
        return self
        pass
mf22
Output of `benchmark_app -m model.xml`:
[ INFO ] OpenVINO:
         CPU
[ INFO ] Read model took 5.13 ms
  File ".../venv/lib/python3.8/site-packages/openvino/tools/benchmark/main.py", line 298, in run
  File ".../venv/lib/python3.8/site-packages/openvino/runtime/ie_api.py", line 266, in compile_model
Code used for inference using Openvino IR:
import numpy as np
# OpenVINO
#                                        # Tensor
# API v2.0
import psutil
MODE = 0o771
                exist_ok=True)
                 img_shape=IMGSZ,
                 batch_size=1,
                 device='cpu',
                 num_threads=None):
        Inputs
        w, h = img_shape
        self.dtype = dtype
        ie = Core()
            # APi v2.0
            #                                      "CPU",
            #                                      num_requests=1)
                                                  device_name="CPU"
    @property
    @property
        return self.batch
    # @profile
        Inference.
        See:
        Inputs
        Outputs
        y - output tensor
        elapsed_time
        mem_info
        st_time = time()
        infer_requests = []
        outputs = []
            # Get output
        return self
        pass
ONNX:
import numpy as np
import onnxruntime
import psutil
DTYPE = np.float32
                 img_shape=IMGSZ,
                 batch_size=1,
                 num_threads=None):
        Inputs
        w, h = img_shape
        self.dtype = dtype
        self.networks = []
            # ONNX runtime
    @property
    @property
        return self.batch
    # @profile
        Inference.
        Inputs
        Outputs
        y - output tensor
        elapsed_time
        mem_info
        st_time = time()
        outputs = []
            # ONNX runtime
            outputs.append(out)
        return self
        pass
ONNX inference works (although it is very slow for some reason).
mf22
Hi @Wan_Intel ,
thank you for the feedback.
I posted my answer several times, but it doesn't show up, I am not sure what is happening.
I uploaded the files here:  https://drive.google.com/drive/folders/1SBqaClQOiZRn3LU9zJYOa-FtbgTS9BeO?usp=sharing
Wan_Intel
Hi Mf22,
Thanks for sharing your information with us.
I encountered the same error "RuntimeError: could not create a primitive" when using your ONNX model with Benchmark Python Tool.
Could you please check if the following code is the right way to create your custom model?
import torch
from torch import nn
from torch.utils.data import DataLoader
from torchvision import datasets
from torchvision.transforms import ToTensor
import cv2
import numpy as np
    integrated GPU).
                 device='cpu'
        Inputs
                   torch.Tensor
        super().__init__()
                                                     # (template size)
                                   padding=padding)
                                     padding=padding)
        # definition)
            input_ * input_)
        # already masked)
        result = torch.div(
        # return torch.max(
image = cv2.imread("download.jpg")
image = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
print(image.shape)
input_imagex = np.expand_dims(image.transpose(1,0), 0)
print(input_imagex.shape)
input_image = np.expand_dims(input_imagex.transpose(0, 1, 2), 0)
print(input_image.shape)
x = torch.Tensor(input_image)
model = TemplateMatch(templates=x, masks=x)
print(model)
torch.save(model.state_dict(), "model.pth")
print("Saved PyTorch Model State to model.pth")
model.load_state_dict(torch.load("model.pth"))
y = torch.randn(1, 1, 276, 183)
torch_out = model(y)
torch.onnx.export(model, y, "model.onnx")
print("Saved model.pth to model.onnx")
Wan
Wan_Intel
Hi Mf22,
Just wanted to follow up and see if the code above was able to resolve your issue. If you still facing the same issue, you may get back to us.
Wan
Wan_Intel
Hi Mf22,
This thread will no longer be monitored since we have provided a suggestion.
If you need any additional information from Intel, please submit a new question.
Wan
