6573 Discussions
"unsupported proxy configuration" error when executing ./run_openvino_workbench.sh
EngKean_L_Intel
encountered this error when executing ./run_openvino_workbench.sh.
Err:9 http://deb.debian.org/debian stretch/main amd64 Packages
  Unsupported proxy configured
Shubha_R_Intel
Dear Eng Kean Lee,
Kindly review the DL Workbench Documentation . There are specific instructions with regard to proxy settings.
Hope it helps,
Shubha
EngKean_L_Intel
the document only mention this:
Proxy Settings
If you are behind a corporate proxy, set environment variables before running DL workbench:
export https_proxy=<https_proxy>
export http_proxy=<http_proxy>
export no_proxy=<no_proxy>
The proxy setting have been configured in .bashrc, open a new terminal, and verified by echo $https_proxy.
The error persist when running ./run_openvino_workbench.sh.
Unsupported proxy configured: https://proxy.abc.abc.com:123  (this is not the actual proxy, modified it to hide the proxy in this forum)
can you provide an example proxy format setting?
Shubha_R_Intel
Dear Eng Kean Lee,
Can you kindly leave .bashrc out of the picture for the moment ? Simply set those environment variables in the shell.  Please find me and email me (since you work for Intel) and I will give you the proxy settings which I used to get DL Workbench up and running. If you are US-based then what I use should work for you also.
Shubha
