6597 Discussions
relocation R_X86_64_32 against symbol `excep' use -fPIE
visi
mdk/common/components/kernelLib/MvCV/kernels/accumulateFp16/unittest run with make all gives :-
Generating: /home/mdk_release_R13.8_myriadx-general_release/mdk/common/components/kernelLib/MvCV/kernels/absoluteDiff/unittest/run/absoluteDiff_unittest
/usr/bin/ld: ../../../../../../../packages/movidius/pcModel/moviCompile/compilerIntrinsics/lib/linux64/libintrinsics.a(half.o): relocation R_X86_64_32 against symbol `excep' can not be used when making a PIE object; recompile with -fPIE
/usr/bin/ld: ../../../../../../../packages/movidius/pcModel/moviCompile/compilerIntrinsics/lib/linux64/libintrinsics.a(moviFloat32.o): relocation R_X86_64_32S against `.rodata' can not be used when making a PIE object; recompile with -fPIE
collect2: error: ld returned 1 exit status
Peh_Intel
Hi visi,
We would like to request more information from you so that we can duplicate it on our side.
Which source you are referring to build Myriad Development Kit (MDK)?
Peh
visi
Hi Peh
I am using mdk_release_R15.4_myriadx-general_release in Ubuntu20.04 and ma2085 chip.
visi
Peh_Intel
Hi visi,
Please be informed that Movidius Development Kit is beyond of our support scope, but Intel do have specific team that handles MDK enquiries via Intel Premier Support platform.
The company name that you used for profile registration has IPS account enabled. Hence, please submit the ticket at http://premiersupport.intel.com for better supportability.
We are sorry for the inconvenience caused.
Do check your access to the system and come back to us if you face the accessibility issue.
Peh
Peh_Intel
Hi visi,
This thread will no longer be monitored since we have provided the proper channel regarding MDK inquiries. If you need any additional information from Intel, please submit a new question.
Peh
