6597 Discussions
How to get YoloV4 speed comparable to OpenCV?
Brown_Kramer__Joshua
If I run a YoloV4 model with leaky relu activations on my CPU with 256x256 RGB images in OpenCV with an OpenVINO backend, inference time plus non-max suppression is about 80ms. If, on the other hand, I convert my model to an IR following https://github.com/TNTWEN/OpenVINO-YOLOV4, which is linked to from https://github.com/AlexeyAB/darknet, inference time directly using the OpenVINO inference engine is roughly 130ms, which does not even include non-max suppression, which is quite slow when implemented naively in python.
Unfortunately, OpenCV does not offer all of the control I would like for the models and inference schemes I want to try (e.g. I want to change batch size, import models from YOLO repositories other than darknet, etc.)
What is the magic that allows OpenCV with OpenVINO backend to be so much faster?
Vladimir_Dudnik
@Brown_Kramer__Joshua from your message it is not clear if you compare the same model or different models.
Zulkifli_Intel
Hello Josh Brown Kramer,
Do you have any feedback on the question from Vladimir?
SIncerely,
Zulkifli
Munesh_Intel
Hi Josh,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Munesh
