6571 Discussions
Failed to install: intel-openvino-runtime-ubuntu20-2021.4.582
PhaniMVS
Very nice morning sir.
ERROR - Failed to install: intel-openvino-runtime-ubuntu20-2021.4.582
When i extracted the package intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582_2021.4-582_amd64.deb
and rebuilt the package using  "sudo dpkg-deb --build --root-owner-group out"
"sudo dpkg -i out.deb" it successfully installs the gstreamer package.
Is there any issue with the generated package of intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582_2021.4-582_amd64.deb
Attached the install log files. Please advice.
Wan_Intel
Hi PhaniMVS,
For your information, I encountered the same error as you when installing intel-openvino-runtime-ubuntu20-2021.4.582.
However, I have successfully installed intel-openvino-runtime-ubuntu20-2021.4.689. I recommend you install intel-openvino-runtime-ubuntu20-2021.4.689 for new capabilities and performance improvements.
Steps to install Intel® Distribution of OpenVINO™ toolkit for Linux Using APT Repository is available at the following page:
https://docs.openvinotoolkit.org/2021.4/openvino_docs_install_guides_installing_openvino_apt.html#install_packages
Wan
Wan_Intel
Hi PhaniMVS,
Wan
PhaniMVS
Thankyou
Wan_Intel
Hi PhaniMVS,
You are welcome.
This thread will no longer be monitored since this issue has been resolved.
If you need any additional information from Intel, please submit a new question.
Wan
