6594 Discussions
run demo object_detection_demo_yolov3_async.py by using camera error: E: [xLink] Write failed header
ghostman
hi sir,
run demo object_detection_demo_yolov3_async.py by using camera error: E: [xLink] Write failed header as the attached picture below, but run this demo by using local video file or rtsp ip-camera successfully.
could you tell the root cause or some suggestiong / solutions,pls? tksissue01.png
Sebastian_M_Intel
Hello ghostman,
We would like to inform you that we have a forum for these specific issues and products, so we are moving it to the "Intel® Distribution of OpenVINO™ Toolkit" forum so you can get better support for this matter.
Sebastian M
Intel Customer Support Technician
ghostman
hi Sebastian M,
         Thanks for your reply, but where and when can i get better support for this matter?
Adli
Hi ghostman,
Thank you for reaching out to us. Did you use a built-in camera or a USB camera for the demo? If possible, could you share additional information regarding:
  • the OpenVINO version used to run the demo
  • specify USB version on your device if you are using a USB camera for the demo
Adli
Adli
Hi ghostman,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Adli
