6584 Discussions
same output for all inputs: Neural compute stick 2
Lam__Carson
I have a custom model that I converted to a .onnx file and used mo.py to convert to a .xml and .bin file
plugin = IEPlugin(device=device)
net = IENetwork(model=model_xml, weights=model_bin)
exec_net = plugin.load(network=net)
res = exec_net.infer(inputs={input_blob: images})
when device= "CPU" , the inference works fine and I get correct outputs in the form of 2 dimensional vectors,
However when I used my Neural compute stick 2 by making device="MYRIAD"  I get the same output vector for every image I input
array([[ 0.01548004, -0.02479553]], dtype=float32)
case number reference of this chat 04029608
the onnx file is created from pytorch from a FP32 model and converted to FP16 by the model optimizer mo.py using --data_type=FP16
Hyodo__Katsuya
Innovator
@Lam, Carson I may not be useful because I do not know what your model is like. When running "mo.py", try the following option. --disable_fusing or --disable_gfusing or --disable_fusing --disable_gfusing
Lam__Carson
Hi Hyodo, Katsuya,
Thank you for the reply, I tried all 3 of your suggestion, but I get the same result, I guess one difference is that with both --disable_fusing --disable_gfusing the result is a different output than before, but it still gives the same output regardless of the input image. I used pytorch to make a modified densenet121 from torchvision and modified the initial convolution to be 3 convolutions to take take a 896 sized input instead of 224. Thanks
Yuanyuan_L_Intel
@Lam, Carson
I think you can try to use the corss_check_tool to check the pre-layer difference between CPU and ncs2. That might give us some insights of where the major difference comes from. Please check the doc <INSTALL_DIR>/deployment_tools/documents/_docs_IE_DG_Croos_Check_Tool.html for details about how to use corss_check_tool.
