--scale_values and --mean_values of mo.py
timosy
When I quantize a model (and also train a model), I used scaling
g_normalize = torchvision.transforms.Normalize(
      mean=[0.5029, 0.4375, 0.3465],
      std=[0.2818, 0.2659, 0.2629]
train_dataset = torchvision.datasets.ImageFolder(
      "/datasetA/train/",
      torchvision.transforms.Compose([
            torchvision.transforms.RandomResizedCrop(224),
            torchvision.transforms.RandomHorizontalFlip(),
            torchvision.transforms.ToTensor(),
            g_normalize
In this case, do I also have to use the same values with "--scale_values" and "--mean_values" option when I convert the model to IR. or, it's not necessary to add these options?
IntelSupport
Community Manager
Hi Hep77to,
Thanks for reaching out.
It is not necessary if the input pre-processing operations are part of the model. In this case, the application will not pre-process the input data as a separate step and it will be embedded into the model itself. You can find more details in When to Specify Mean and Scale Values.
Aznie
IntelSupport
Community Manager
Hi Hep77to,
Aznie
timosy
Its nice explanation! thanks
IntelSupport
Community Manager
Hi hep77to,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
