tensorflow make issue
pi@rpi3:~ $ cat /etc/issue
Raspbian GNU/Linux 9 \n \l
pi@rpi3:~ $ uname -a
Linux rpi3 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
mkdir -p ~/workspace
cd ~/workspace
git clone https://github.com/movidius/ncsdk.git
cd ~/workspace/ncsdk
make install
pi@rpi3:~/workspace/ncsdk/examples/apps/hello_ncs_py $ python3 ./hello_ncs.py
Hello NCS! Device opened normally.
Goodbye NCS! Device closed normally.
NCS device working.
(All is good up to this point. continuing on…)
make examples
-- Installing: /usr/local/bin/opencv_version
-- Set runtime path of "/usr/local/bin/opencv_version" to "/usr/local/lib"
make examples starting.
(cd examples; make)
make[1]: Entering directory '/home/pi/workspace/ncsdk/examples'
make -C apps/.
make[2]: Entering directory '/home/pi/workspace/ncsdk/examples/apps'
make -C hello_ncs_py/.
make[3]: Entering directory '/home/pi/workspace/ncsdk/examples/apps/hello_ncs_py'
nothing to make, use 'make run' to run.
make[3]: Leaving directory '/home/pi/workspace/ncsdk/examples/apps/hello_ncs_py'
make -C multistick_cpp/.
make[3]: Entering directory '/home/pi/workspace/ncsdk/examples/apps/multistick_cpp'
get_ilsvrc_aux.sh 100%
caffe_ilsvrc12.tar.gz 100%
ilsvrc_2012_mean.npy 100%
deploy.prototxt 100%
bvlc_googlenet.caffemodel 100%
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
Layer inception_5b/1x1 forced to im2col_v2, because its output is used in concat
Layer inception_5b/pool_proj forced to im2col_v2, because its output is used in concat
/usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
"Consider reducing your data sizes for best performance\033[0m")
make[4]: Leaving directory '/home/pi/workspace/ncsdk/examples/caffe/GoogLeNet'
making squeezenet
making prereqs
LICENSE 100%
making prototxt
making caffemodel
squeezenet_v1.0.caffemodel 100%
making compile
making multistick_cpp
making hello_ncs_cpp
making prereqs
making prototxt
making profile
mvNCProfile deploy.prototxt -s 12
mvNCProfile v02.00, Copyright @ Movidius Ltd 2016
__ WARNING: using empty weights __
making caffemodel
Downloading caffemodel file
bvlc_alexnet.caffemodel 100%
making check
mvNCCheck -w bvlc_alexnet.caffemodel -i ../../data/images/cat.jpg -s 12 -id 281 deploy.prototxt -M 110 -S 255 -metric top1
mvNCCheck v02.00, Copyright @ Movidius Ltd 2016
[Error 28] Caffe Error: MemoryError. Potential Cause: Available RAM not sufficient for Network to be loaded into Caffe
making compile
mvNCCompile -w bvlc_alexnet.caffemodel -s 12 deploy.prototxt
making cpp
making prereqs
making prototxt
making profile
making caffemodel
caffemodel file already exists
making check
Result: Validation Pass
making compile
making cpp
making prereqs
making prototxt
making profile
making check
making compile
making cpp
g++ cpp/run.cpp cpp/fp16.c -o cpp/run_cpp -lmvnc
make[3]: Leaving directory '/home/pi/workspace/ncsdk/examples/caffe/GoogLeNet'
make[2]: Leaving directory '/home/pi/workspace/ncsdk/examples/caffe'
make -C tensorflow/.
make[2]: Entering directory '/home/pi/workspace/ncsdk/examples/tensorflow'
make -C inception_v3/.
make[3]: Entering directory '/home/pi/workspace/ncsdk/examples/tensorflow/inception_v3'
test -f output/inception-v3.meta || ((wget http://download.tensorflow.org/models/inception_v3_2016_08_28.tar.gz && tar zxf inception_v3_2016_08_28.tar.gz && rm inception_v3_2016_08_28.tar.gz) && ./inception-v3.py)
--2018-01-19 10:18:25-- http://download.tensorflow.org/models/inception_v3_2016_08_28.tar.gz
Resolving download.tensorflow.org (download.tensorflow.org)… 216.58.216.208, 2607:f8b0:4009:809::2010
Connecting to download.tensorflow.org (download.tensorflow.org)|216.58.216.208|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 100885009 (96M) [application/x-tar]
Saving to: ‘inception_v3_2016_08_28.tar.gz’
inception_v3_2016_08_28.tar.gz 100%[================================================================================================================================>] 96.21M 2.79MB/s in 68s
2018-01-19 10:19:33 (1.41 MB/s) - ‘inception_v3_2016_08_28.tar.gz’ saved [100885009/100885009]
Traceback (most recent call last):
File "./inception-v3.py", line 4, in
import tensorflow as tf
ImportError: No module named 'tensorflow'
Makefile:41: recipe for target 'weights' failed
make[3]: *** [weights] Error 1
make[3]: Leaving directory '/home/pi/workspace/ncsdk/examples/tensorflow/inception_v3'
Makefile:12: recipe for target 'inception_v3/.' failed
make[2]: *** [inception_v3/.] Error 2
make[2]: Leaving directory '/home/pi/workspace/ncsdk/examples/tensorflow'
Makefile:12: recipe for target 'tensorflow/.' failed
make[1]: *** [tensorflow/.] Error 2
make[1]: Leaving directory '/home/pi/workspace/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
pi@rpi3:~/workspace/ncsdk $
So some ram issues (as it is on an RPI3), some warnings, but it seems to fail on the tensorflow build…
I was following the 'canned' process for a first install on a virgin RPI image.
any ideas?
  • just starting out with the movidius & tensorflow.
Thanks!!
hmm…
ramana.rachakonda
November 2017 0
@jwmac the issue with TF on RPi is that we don’t (yet) have an elegant why to install TF on RPi. The version that is available now has some incompatibilities with our toolset which we are updating.
Long story short, our tools should work if you install RPi 1.3 using source install. Also, if you install and compile and create graph files on a compatible machine (say Ubuntu 16.04 on Virtual Box on your PC), you can copy the graph file over (we have examples for inception with a precompiled graph file on our github) and run your application on RPi.
We are working on making this more homogeneous by working with TF. Thanks for your patience.
Did you fix this problem? I got the same error message
