test exemples on an Intel refrence card
najjar__fida
Jeffrey_M_Intel1
The easiest place to start is with inference engine samples such as the classification sample.
First step is to flash/program your Arria10 to prepare it.
aocl program ac10 bitstream.aocx
You may need to set some environment variables
export CL_CONTEXT_COMPILER_MODE_ALTERA=3
export DLA_AOCX=<PATH_TO_AOCX_FILE>.aocx
export LD_LIBRARY_PATH=<AOCL_INSTALL_DIR>/hld/host/linux64/lib:<AOCL_INSTALL_DIR>/hld/board/a10_ref/linux64/lib:$LD_LIBRARY_PATH
You will also need an IR file transformed from your original format with Model Optimizer.
After that, run the sample as on CPU/GPU but with FPGA as the device type.
The links you sent appear to be for the DLIA project, which is similar but not the same as Arria10 -- so they may not apply to your HW.
CVSDK is still in beta.  More examples and getting started info are in development for FPGA.  Please watch for more in the next release.
Rob_Mueller-Albrecht
Dear Fida,
the two documents you are looking for are part of a limited access pilot program. They are thus not publicly accessible. I recommend you get in-touch with your local Intel field representative who can help get your company added for consideration for the next upcoming program which will start soon.
Thanks, Rob
