in the directory ncappzoo/apps/live-image-classifier ,i try to sudo make mobilenet,it have such error:
Exporting GraphDef file...
(cd model; python3 /home/workspace/code/ncappzoo/tensorflow/mobilenets/../tf_models/models/research/slim/export_inference_graph.py \
--alsologtostderr \
--model_name=mobilenet_v1 \
--batch_size=1 \
--dataset_name=imagenet \
--image_size=224 \
--output_file=mobilenet_v1_1.0_224.pb;)
Traceback (most recent call last):
File "/home/workspace/code/ncappzoo/tensorflow/mobilenets/../tf_models/models/research/slim/export_inference_graph.py", line 62, in <module>
from datasets import dataset_factory
File "/home/workspace/code/ncappzoo/tensorflow/tf_models/models/research/slim/datasets/dataset_factory.py", line 21, in <module>
from datasets import cifar10
File "/home/workspace/code/ncappzoo/tensorflow/tf_models/models/research/slim/datasets/cifar10.py", line 30, in <module>
slim = tf.contrib.slim
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/lazy_loader.py", line 53, in __getattr__
module = self._load()
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/lazy_loader.py", line 42, in _load
module = importlib.import_module(self.__name__)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/__init__.py", line 33, in <module>
from tensorflow.contrib import data
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/data/__init__.py", line 63, in <module>
from tensorflow.contrib.data.python.ops.error_ops import ignore_errors
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/data/python/ops/error_ops.py", line 20, in <module>
from tensorflow.contrib.data.python.ops import contrib_op_loader # pylint: disable=unused-import
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/data/python/ops/contrib_op_loader.py", line 24, in <module>
resource_loader.get_path_to_datafile("../../_dataset_ops.so"))
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/util/loader.py", line 56, in load_op_library
ret = load_library.load_op_library(path)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/load_library.py", line 58, in load_op_library
lib_handle = py_tf.TF_LoadLibrary(library_filename, status)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/errors_impl.py", line 516, in __exit__
c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.NotFoundError: /usr/local/lib/python3.5/dist-packages/tensorflow/contrib/data/python/ops/../../_dataset_ops.so: undefined symbol: _ZN6google8protobuf8internal9ArenaImpl10AddCleanupEPvPFvS3_E
Makefile:69: recipe for target 'export' failed
make[1]: *** [export] Error 1
make[1]: Leaving directory '/home/workspace/code/ncappzoo/tensorflow/mobilenets'
Makefile:26: recipe for target 'mobilenet' failed
make: *** [mobilenet] Error 2
another question:
sudo make run,it returns the following error:
ImportError: No module named caffe, so i add below code in Makefile:
ifneq ($(findstring movidius, $(PYTHONPATH)), movidius)
export PYTHONPATH:=/opt/movidius/caffe/python:$(PYTHONPATH)
endif
it works very well , i don't know if it is a bug for you.
- Tags:
- Tensorflow
@Tome_at_Intel @PINTO ,can you help me? now i found out that all tensorflow's examples were wrong with the same error:
please help me,thanks!
@PINTO thanks very much, i install tensorflow 1.9.0 and it works!
@PINTO but the NCSDK 2.05 only supports tensorflow <= 1.7.0, my device is Raspberrypi 3, I have to face the problem directly,
@zufeifei
I know that.
It is not officially supported, but please be relief so that it works.
I and luna are operation verified.
If you dislike that you are not officially supported, I will not recommend it.
There is no doubt that the behavior of Tensorflow 1.7.0 is unstable.
@PINTO thanks for your time, and does it mean that I could remove tensorflow-1.7.0 and install the tensoflow with version 1.9.0 to solve the problem
@PINTO OH! I operation verified,
sudo pip3 uninstall tensorflow
sudo pip3 install tensorflow
then the problem solved,
thank you for a lot!
