6594 Discussions
when I complie the graph_freeze.pb on the ncs ,it a problem as :
from ._conv import register_converters as _register_converters
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 259, in parse_tensor
input_data = np.random.uniform(0, 1, shape)
File "mtrand.pyx", line 1307, in mtrand.RandomState.uniform
File "mtrand.pyx", line 242, in mtrand.cont2_array_sc
TypeError: 'NoneType' object cannot be interpreted as an integer
The project graph_freeze.pb is on the web below:
https://github.com/ildoonet/tf-pose-estimation/tree/master/models/graph/mobilenet_thin
Can anyone can help me ?
It is the Mobilenet on the tensorflow.however ,I can't compile :'(
@wangrongxin
请问你找到这个问题的解决方法了吗?请指导,感激不尽!
Hi @neilwu
The error you are seeing has been discussed in another thread.
The error is due to the model using variable input sizes which is currently not supported on the NCSDK.
Hope this helps!
Jesus
Hi @Jesus_at_Intel
Thanks for the information.
After I change the model's variable input to a fixed size (432,368), the original error is gone.
But I met the problem like https://ncsforum.movidius.com/discussion/comment/2310/#Comment_2310.
The errors like this:
Fusing depthconv and conv in Openpose/MConv_Stage1_L1_1_depthwise/depthwise and Openpose/MConv_Stage1_L1_1_pointwise/Conv2D
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 630, in parse_tensor
prev_node.addBias( bias.astype(np.float16) )
AttributeError: 'int' object has no attribute 'addBias'
If there is any pose estimation demo that can run on Movidius? Please tell me about that.I am going to collapse.
Sincerely,
Neil
Hi @neilwu
I shared some info regarding the Pose Estimation example using the OpenVINO Toolkit.
https://ncsforum.movidius.com/discussion/1565/pose-estimation-performance#latest
Jesus
