6598 Discussions
when i use tow ncs on windows can not communication with ncs
I can communicate normally when I use one NCS, but there are communication errors when I use two NCS,I meet the error is -2 or -6 ,i read de error code this is can not communication with ncs ,and what can i do to solve it?
@tanke
http://libusb.sourceforge.net/api-1.0/grouplibusbmisc.html#gab2323aa0f04bc22038e7e1740b2f29ef
tow ncs = two ncs ?
In that case, I recommend using a self-powered USB HUB.
Sorry, I spelled the mistake.
Thank you very much for your answer. Now the problem seems to have been solved.
