6584 Discussions
with image size, 1120*1120, model is freezing , works with 1024 size.
titir_s_Intel
I am using yolov3 model in my application. I converted my weights to .bin and .xml and I got not error.
Then while trying to inference, I am getting this error:
E: [global] [         0] [] XLinkOpenStream:1256   Got wrong package from device, error code = X_LINK_OUT_OF_MEMORY
E: [ncAPI] [         0] [] ncFifoAllocate:3250     can't open stream:  FIFO0 due to not enough memory on device
F: [global] [         0] [EventRead00Thr] dispatcherEventReceive:362       Duplicate id detected.
W: [global] [         0] [EventRead00Thr] dispatcherEventReceive:367       Failed to handle incoming event
W: [global] [         0] [EventRead00Thr] dispatcherEventReceive:367       WinUsb_WritePipe: System err 31
WinUsb_WritePipe failed with error:=31
E: [global] [         0] [Scheduler00Thr] dispatcherEventSend:1004 Write failed (header) (err -2) | event XLINK_WRITE_REQ
E: [xLink] [         0] [Scheduler00Thr] eventSchedulerRun:626     Event sending failedW: [global] [         0] [EventRead00Thr] dispatcherEventReceive:367   Failed to handle incoming event
F: [xLink] [         0] [Scheduler00Thr] dispatcherResponseServe:315       no request for this response: XLINK_WRITE_RESP 1
#### (i == MAX_EVENTS) XLINK_WRITE_RESP 1 303
0) header->id 266, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
1) header->id 267, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
2) header->id 268, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
3) header->id 269, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
4) header->id 270, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
5) header->id 271, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
6) header->id 272, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
7) header->id 273, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
8) header->id 274, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
9) header->id 275, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
10) header->id 276, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
11) header->id 277, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
12) header->id 278, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
13) header->id 279, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
14) header->id 280, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
15) header->id 281, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
E: [global] [         0] [] XLinkOpenStream:1256   16) header->id 282, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
E: [ncAPI] [         0] [] ncFifoAllocate:3250     17) header->id 283, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
18) header->id 284, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
can't open stream:  FIFO0 due to not enough memory on device19) header->id 285, header->type XLINK_CREATE_STREAM_REQ(3), curr->lQueue.q.isServed 4, EVENT_PENDING 1
20) header->id 286, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
21) header->id 287, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
22) header->id 288, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
23) header->id 289, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
24) header->id 290, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
W25) header->id 291, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
i26) header->id 292, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
n27) header->id 293, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
U28) header->id 294, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
s29) header->id 295, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
b30) header->id 296, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
_31) header->id 297, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
ReW32) header->id 298, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
F: [global] [         0] [EventRead00Thr] dispatcherEventReceive:362       adPipe: System err i33) header->id 299, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
2234) header->id 300, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
n
35) header->id 301, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
E: [xLink] [         0] [EventRead00Thr] eventReader:218   eventReader thread stopped (err -2)W: [global] [         0] [EventRead00Thr] dispatcherEventReceive:367    U
36) header->id 302, header->type XLINK_CREATE_STREAM_REQ(3), curr->lQueue.q.isServed 4, EVENT_PENDING 1
37) header->id 303, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
38) header->id 304, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 1, EVENT_PENDING 1
sb39) header->id 241, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
40) header->id 242, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
_Failed to handle incoming event41) header->id 243, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
WriteP42) header->id 244, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
i43) header->id 245, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
W: [global] [         0] [EventRead00Thr] dispatcherEventReceive:367       Failed to handle incoming event44) header->id 246, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
45) header->id 247, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
46) header->id 248, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
47) header->id 249, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
48) header->id 250, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
49) header->id 251, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
50) header->id 252, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
51) header->id 253, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
52) header->id 254, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
pe53) header->id 255, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
54) header->id 256, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
55) header->id 257, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
56) header->id 258, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
57) header->id 259, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
:58) header->id 260, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
 59) header->id 261, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
60) header->id 262, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
61) header->id 263, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
62) header->id 264, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
63) header->id 265, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
SWinUsby_WritePipe: System err 22
s
WinUsb_WritePipe failed with error:=22
tE: [global] [         0] [Scheduler00Thr] dispatcherEventSend:1004        eWrite failed (header) (err -2) | event XLINK_WRITE_RESP
m
eWrinUsb_WritrePipe: Syste 995
WinUsb_WritePipe failed with error:=995
WinUsb_ReadPipe: Systm err 22
E: [global] [         0] [Scheduler00Thr] dispatcherEventSend:1004 E: [global] [         0] [Scheduler00Thr] dispatcherEventSend:1013 eWrite failed (header) (err -2) | event XLINK_WRITE_RESP
Write failed -2
m
 E: [xLink] [         0] [Scheduler00Thr] eventSchedulerRun:626    F: [xLink] [         0] [Scheduler00Thr] dispatcherResponseServe:315       err no request for this response: XLINK_WRITE_RESP 1
Event sending failed22
#### (i == MAX_EVENTS) XLINK_WRITE_RESP 1 301
E: [xLink] [         0] [EventRead00Thr] eventReader:218   WeventReader thread stopped (err -2)
i2) header->id 268, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
n3) header->id 269, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
U4) header->id 270, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
s6) header->id 272, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
b7) header->id 273, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
_8) header->id 274, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
W9) header->id 275, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
r10) header->id 276, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
i11) header->id 277, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
t12) header->id 278, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
e13) header->id 279, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
P14) header->id 280, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
i15) header->id 281, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
p16) header->id 282, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
e17) header->id 283, header->type XLINK_CREATE_STREAM_REQ(3), curr->lQueue.q.isServed 4, EVENT_PENDING 1
: 18) header->id 284, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
S19) header->id 285, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
y20) header->id 286, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
s21) header->id 287, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
t22) header->id 288, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
e23) header->id 289, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
m24) header->id 290, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
 e25) header->id 291, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
26) header->id 292, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
r27) header->id 293, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
r28) header->id 294, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
 29) header->id 295, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
2230) header->id 296, header->type XLINK_READ_REL_REQ(2), curr->lQueue.q.isServed 4, EVENT_PENDING 1
32) header->id 298, header->type XLINK_READ_REQ(1), curr->lQueue.q.isServed 4, EVENT_PENDING 1
34) header->id 300, header->type XLINK_CREATE_STREAM_REQ(3), curr->lQueue.q.isServed 4, EVENT_PENDING 1
35) header->id 301, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
36) header->id 302, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 1, EVENT_PENDING 1
37) header->id 239, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
38) header->id 240, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
E: [global] [         0] [Scheduler00Thr] dispatcherEventSend:1004 40) header->id 242, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
E: [xLink] [         0] [Scheduler00Thr] eventSchedulerRun:626     43) header->id 245, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
Event sending failed45) header->id 247, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
Win47) header->id 249, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
U48) header->id 250, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
s49) header->id 251, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
b50) header->id 252, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
_52) header->id 254, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
W53) header->id 255, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
r54) header->id 256, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
i55) header->id 257, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
t56) header->id 258, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
e57) header->id 259, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
P58) header->id 260, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
i59) header->id 261, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
p61) header->id 263, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
e62) header->id 264, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
: Sy63) header->id 265, header->type XLINK_WRITE_REQ(0), curr->lQueue.q.isServed 4, EVENT_PENDING 1
sE: [xLink] [         0] [Scheduler00Thr] eventSchedulerRun:576    tem err Dispatcher received NULL event!22
E: [ncAPI] [         0] [] checkGraphMonitorResponse:1792  E: [global] [         0] [Scheduler00Thr] dispatcherEventSend:1004 XLink error, rc: X_LINK_ERROR
E: [xLink] [         0] [Scheduler00Thr] eventSchedulerRun:576     Dispatcher received NULL event!
E: [ncAPI] [         0] [] checkGraphMonitorResponse:1792  XLink error, rc: X_LINK_ERROR
Process Process-1:
Traceback (most recent call last):
  File "C:\Anaconda3\envs\openvinoR3.1\lib\multiprocessing\process.py", line 249, in _bootstrap
    self.run()
  File "C:\Anaconda3\envs\openvinoR3.1\lib\multiprocessing\process.py", line 93, in run
    self._target(*self._args, **self._kwargs)
Process Process-2:
  File "C:\Users\tsantra\PycharmProjects\parkinglot_ngs\ngs_smartpark-dev\cam_yolo\intel_parking_detection_yolo_openvino.py", line 1807, in myriadworker
    check_args(args, camId, imagedir, cam_state, cam_config, counter, processname)
  File "C:\Users\tsantra\PycharmProjects\parkinglot_ngs\ngs_smartpark-dev\cam_yolo\intel_parking_detection_yolo_openvino.py", line 1920, in check_args
    processImages(args,imagedir, cam_state, cam_config)
  File "C:\Users\tsantra\PycharmProjects\parkinglot_ngs\ngs_smartpark-dev\cam_yolo\intel_parking_detection_yolo_openvino.py", line 1391, in processImages
    park_db, park_info, model_yolo = initInferEngine(args, cam_config)
  File "C:\Users\tsantra\PycharmProjects\parkinglot_ngs\ngs_smartpark-dev\cam_yolo\intel_parking_detection_yolo_openvino.py", line 1108, in initInferEngine
    model_yolo = ObjectDetectYolo(args,park_info,CLASS_FILE, MODEL_CONFIG, MODEL_WEIGHTS, MODEL_XML)
  File "C:\Users\tsantra\PycharmProjects\parkinglot_ngs\ngs_smartpark-dev\cam_yolo\intel_parking_detection_yolo_openvino.py", line 556, in __init__
    self.exec_net = self.plugin.load(network=self.net, num_requests=2)
    self.run()
  File "ie_api.pyx", line 547, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 557, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: Failed to create input FIFO: NC_OUT_OF_MEMORY
E: [watchdog] [         0] [WatchdogThread] sendPingMessage:121    Failed send ping message: X_LINK_ERROR
E: [ncAPI] [         0] [] ncDeviceClose:1737      Device didn't appear after reboot
Same application works fine with image size 1024*1024.
Please help.
Sahira_Intel
Are you plugging in the NCS2 directly into your system or using some kind of powered USB hub? I have found that "FIFO: NC_OUT_OF_MEMORY" errors can be caused by power issues if you have a bigger image size. Can you please provide your model? If you would like to share it privately i can send you a PM and you can send it there.
Can you also provide some information about your system?
Sahira
