Very low accuracy on FP32
whung6
I'm recently trying on the accuracy test for mobilenet-v1-1.0-224. After I downloaded the model from the model_downloader to create .prototxt and .caffemodel file. I used the model_optimizer to create .xml and .bin for FP32 format, however, when I ran the accuracy_check.py code, the accuracy is very low. Is there anything I did wrong, FP32 should have a high accuracy instead.
For model_downloader:
$ python3 downloader.py --name mobilenet-v1-1.0-224 --output_dir ~/models
For model_optimizer:
$ python3 mo.py --input_model ~/models/public/mobilenet-v1-1.0-224/mobilenet-v1-1.0-224.caffemodel --input_proto ~/models/public/mobilenet-v1-1.0-224/mobilenet-v1-1.0-224.prototxt --data_type FP32 --output_dir ~/models/public/mobilenet-v1-1.0-224/ --input_shape [1,3,224,224] --input data --mean_values data[103.94,116.78,123.68] --scale_values data[58.8235294117647] --output prob --framework caffe --reverse_input_channels
For accuracy_check:
 python3 accuracy_check.py --config /opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/configs/mobilenet-v1-1.0-224.yml -m /home/ubuntu/models/ -s /home/ubuntu/imagenet/val/ -a /home/ubuntu/imagenet/annotations/imagenet -td CPU -e /opt/intel/openvino_2019.3.376/deployment_tools/inference_engine/lib/intel64/ -M /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/ -tf dlsdk -tt I8 -d /opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/accuracy_checker/dataset_definitions.yml
My mobilenet-v1-1.0-224.yml:
models:
 - name: mobilenet-v1-1.0-224-cf
  launchers:
   - framework: caffe
    model:  public/mobilenet-v1-1.0-224/mobilenet-v1-1.0-224.prototxt
    weights: public/mobilenet-v1-1.0-224/mobilenet-v1-1.0-224.caffemodel
    adapter: classification
  datasets:
   - name: imagenet_1000_classes
    preprocessing:
     - type: resize
     - type: crop
     - type: normalization
      mean: 103.94, 116.78, 123.68
      std: 58.8235294
  launchers:
   - framework: dlsdk
    tags:
     - FP32
    model:  public/mobilenet-v1-1.0-224/mobilenet-v1-1.0-224.xml
    weights: public/mobilenet-v1-1.0-224/mobilenet-v1-1.0-224.bin
   - framework: dlsdk
    tags:
     - FP16
    model:  public/mobilenet-v1-1.0-224/FP16/mobilenet-v1-1.0-224.xml
    weights: public/mobilenet-v1-1.0-224/FP16/mobilenet-v1-1.0-224.bin
   - framework: dlsdk
    tags:
     - I8sm
    model:  public/mobilenet-v1-1.0-224/I8sm/mobilenet-v1-1.0-224_i8.xml
    weights: public/mobilenet-v1-1.0-224/I8sm/mobilenet-v1-1.0-224_i8.bin
   - framework: dlsdk
    tags:
     - I8
    model:  public/mobilenet-v1-1.0-224/I8/mobilenet_v1_1.0_224_frozen_i8.xml
    weights: public/mobilenet-v1-1.0-224/I8/mobilenet_v1_1.0_224_frozen_i8.bin
  datasets:
    data_source: /home/ubuntu/imagenet/val/ILSVRC2012_img_val
    annotation:  /home/ubuntu/imagenet/annotations/imagenet.pickle
    dataset_meta: /home/ubuntu/imagenet/annotations/imagenet.json
    annotation_conversion:
     converter: imagenet
     annotation_file: /home/ubuntu/imagenet/val.txt
     labels_file:   /home/ubuntu/imagenet/synset_words.txt
     has_background: True
    subsample_size: 2000
    #has_background: True
    preprocessing:
     - type: bgr_to_rgb
     - type: resize
     - type: crop
      std: 58.8235294
    metrics:
     - name: accuracy@top1
      type: accuracy
      top_k: 1
     - name: accuracy@top5
      type: accuracy
      top_k: 5
Result:
Processing info:
model: mobilenet-v1-1.0-224
launcher: dlsdk
launcher tags: FP32
device: CPU
dataset: imagenet_1000_classes
OpenCV version: 4.1.2-openvino
IE version: 2.1.custom_releases/2019/R3_ac8584cb714a697a12f1f30b7a3b78a5b9ac5e05
Loaded CPU plugin version: 2.1.32974
2000 objects processed in 19.012 seconds
accuracy@top1: 0.15%
accuracy@top5: 0.80%
David_C_Intel
Hi whung6,
Thank you for reaching out, we are still working on this issue.
We will contact you as soon as possible.
David C.
A Contingent Worker at Intel
David_C_Intel
Hi whung6,
I apologize for the delay in our response. The development team has made changes to the Accuracy Checker Tool and introduced a Post-Training Optimization tool in the latest OpenVINO™ toolkit 2020.1 release.
Could you try using the two tools with the new release and let us know if you continue to see the same behavior?
You can download the OpenVINO™ toolkit 2020.1 release from the download page.
David C.
