xml file not getting created
VBura
Hi, I just got my NCS-2 and trying out an example on my windows machine. I was able to setup openVINO successfully but when I was trying a demo I see that the .xml file is not getting created. Can someone please help on why this is happening?
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>cd C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>demo_squeezenet_download_convert_run.bat
target_precision = FP16
Python 3.6.5
ECHO is off.
PYTHONPATH=C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;C:\Program Files (x86)\IntelSWTools\openvino\python\python3.6;C:\Program Files (x86)\IntelSWTools\openvino\python\python3;
[setupvars.bat] OpenVINO environment initialized
INTEL_OPENVINO_DIR is set to C:\Program Files (x86)\IntelSWTools\openvino
Python 3.6.5
ECHO is off.
Requirement already satisfied: pyyaml in c:\users\venku\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 1))
Requirement already satisfied: requests in c:\users\venku\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2))
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\venku\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2))
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\venku\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2))
Requirement already satisfied: certifi>=2017.4.17 in c:\users\venku\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2))
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\venku\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2))
You are using pip version 9.0.3, however version 19.3.1 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' command.
Download public squeezenet1.1 model
Models have been loaded previously. Skip loading model step.
Model path: C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\models\FP16\public\squeezenet1.1\squeezenet1.1.prototxt
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name squeezenet1.1 --output_dir C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\models\FP16 --cache_dir C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\ir\cache
################|| Downloading models ||################
========== Retrieving C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\models\FP16\public\squeezenet1.1\squeezenet1.1.prototxt from the cache
========== Retrieving C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\models\FP16\public\squeezenet1.1\squeezenet1.1.caffemodel from the cache
################|| Post-processing ||################
========== Replacing text in C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\models\FP16\public\squeezenet1.1\squeezenet1.1.prototxt
squeezenet1.1 model downloading completed
Waiting for 0 seconds, press a key to continue ...
Target folder C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\ir\FP16\public\squeezenet1.1 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\ir\FP16\public\squeezenet1.1 folder.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
Creating Visual Studio 16 2019 x64 files in C:\Users\venku\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- The C compiler identification is MSVC 19.23.28106.4
-- The CXX compiler identification is MSVC 19.23.28106.4
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.23.28105/bin/Hostx64/x64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.23.28105/bin/Hostx64/x64/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.23.28105/bin/Hostx64/x64/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.23.28105/bin/Hostx64/x64/cl.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check size of __int32
-- Check size of __int32 - done
-- Found InferenceEngine: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/inference_engine.lib (Required is at least version "2.1")
-- Performing Test HAVE_CPUID_INFO
-- Performing Test HAVE_CPUID_INFO - Success
-- Host CPU features:
--   3DNOW not supported
--   3DNOWEXT not supported
--   ABM not supported
--   ADX supported
--   AES supported
--   AVX supported
--   AVX2 supported
--   AVX512CD not supported
--   AVX512F not supported
--   AVX512ER not supported
--   AVX512PF not supported
--   BMI1 supported
--   BMI2 supported
--   CLFSH supported
--   CMPXCHG16B supported
--   CX8 supported
--   ERMS supported
--   F16C supported
--   FMA supported
--   FSGSBASE supported
--   FXSR supported
--   HLE supported
--   INVPCID supported
--   LAHF supported
--   LZCNT supported
--   MMX supported
--   MMXEXT not supported
--   MONITOR not supported
--   MOVBE supported
--   MSR supported
--   OSXSAVE supported
--   PCLMULQDQ supported
--   POPCNT supported
--   PREFETCHWT1 not supported
--   RDRAND supported
--   RDSEED supported
--   RDTSCP supported
--   RTM supported
--   SEP supported
--   SHA not supported
--   SSE supported
--   SSE2 supported
--   SSE3 supported
--   SSE4.1 supported
--   SSE4.2 supported
--   SSE4a not supported
--   SSSE3 supported
--   SYSCALL supported
--   TBM not supported
--   XOP not supported
--   XSAVE supported
-- TBB include: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/external/tbb/include
-- TBB Release lib: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/tbb.lib
-- TBB Debug lib: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Debug/tbb_debug.lib
-- Looking for pthread.h
-- Looking for pthread.h - not found
-- Found Threads: TRUE
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/venku/Documents/Intel/OpenVINO/inference_engine_samples_build
###############|| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ||###############
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\MSBuild.exe" Samples.sln /p:Configuration=Release /t:classification_sample_async /clp:ErrorsOnly /m
Microsoft (R) Build Engine version 16.3.1+1def00d3d for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
###############|| Run Inference Engine classification sample ||###############
        1 file(s) copied.
classification_sample_async.exe -i "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car.png" -m "C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\ir\FP16\public\squeezenet1.1\squeezenet1.1.xml" -d CPU
[ INFO ] InferenceEngine:
        API version ............ 2.1
        Build .................. 30677
        Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car.png
[ INFO ] Creating Inference Engine
        CPU
        MKLDNNPlugin version ......... 2.1
        Build ........... 30677
[ INFO ] Loading network files
[ ERROR ] Error loading xmlfile: C:\Users\venku\Documents\Intel\OpenVINO\openvino_models\ir\FP16\public\squeezenet1.1\squeezenet1.1.xml, File was not found at line: 1 pos: 0
Error
Venku
Luis_at_Intel
Hi Venku,
Thanks for reaching out, it looks like you have another thread already opened. Please take a look and track responses there to avoid duplication:
https://software.intel.com/en-us/forums/computer-vision/topic/830160.
Luis
VBura
Hi Luis, Sorry for the confusion. When I first posted the question, it stated that moderator has to approve my post. I waited for a couple of days and did not know if it was already approved by moderator. So I had to ask again. We can probably close this as Jesus replied to other post and looking into the issue.
Venku
