Hi:
When I follow this link Brain Tumor Segmentation (intel.com) to install the example, after finishing the verify the docker ce installation, the docker compose cannot be installed.
Even though, I have configured so much proxy, such as mirrors.aliyun.com, mirror.baidubce.com, and mirrors.huaweicloud.com and etc. It still cannot be continued.
So how could I do the installation in PRC? Thanks.
Hi gpt,
Thanks for reaching out. As you mentioned, this issue is specific to PRC users. Unfortunately, I am unable to replicate/reproduce your error as I am outside PRC. I would recommend trying to install Docker manually instead of installing from the edgesoftware installer. Please also take a look at the official docker documentation for some guidance on setting up mirrors. Hope this helps!
Registry as a pull through cache | Docker Documentation
Jesus
Hi gpt,
Jesus
