Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
315 Discussions
ECI-A issue: hang when enter ACRN
HarrisLai
I followed the ECI-A install guide to create a bootable USB (have 2VMs, windows and linux) and then installed image to target uBuntu 18.04, and then reboot again to see the grup menu(one is Linux another is ACRN). when I enter ACRN, hang there and show booting 'ACRN' warnning: no console will be avaliable to OS as the attached.
My target:
coffee lake (i5-9500TE)
6 cores(s) / 6 Thread(s)
8GB RAM
Jia-Shing_W_Intel
I would recommend that you first start with hardware from the validated list so we know the hardware and BIOS combination supports ACRN.
The following platforms have been validated for ACRN with ECI 2.5:
If, with one of these platforms, you still run into this issue, you might want to double check your BIOS settings and make sure those that are ACRN-related are properly configured. This is a common reason that leads to this issue.
HarrisLai
Hi Jia-Shing_W,
On this coffee lake platform (i5-9500TE),
the BIOS is American Megatrends, Inc.
I can only see some settings as red block in the attached file. (These settings are what I use now).
ChunSheong_F_Intel
Hi Harris,
Which profile did you use when you are building the ECI-A image? Do you disable Hyperthreading on your bios?
Jia-Shing_W_Intel
Hi Harris,
I also find VT-d is used by ACRN. Without enabling it in BIOS, you also can get stuck at boot. Are you able to get help from the BIOS vendor to make these options exposed in the menu?
