Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
410 Discussions
[Edge Control for Industrial] Encounter issue when running 'Benchmark_Linux_3.5.15.40.project'
Jonathan_Yeh
Hi there,
We've completed the setup for this lab. Please refer to below information in detail.
Now we're running this CODESYS project, and it seems to have another window pop-up to ask for project environment checkup. We would like to confirm:
   - Should we update the libraries and click 'Set All to Newest'
   - How to download the device description ?
Thank you.
  • Block Diagram
  • SW
SW
Version
Check
ECI Downloaded
1.5
CODESYS
3.5.16.40
ECI BSP for ECI B
Item
Check
ECS-B Log In
start-cyclictest results after BIOS tuned
CODESYS reinstalled
  • Run CODESYS
Jonathan
Jia-Shing_W_Intel
Hi Jonathan,
I don't think it's absolutely required to update the libraries but it's not a bad idea, in case CODESYS has bug fixes in them.
You can right click on the exclamation mark next to the device to download its device description.
Hope this helps.
Jia-Shing
Jia-Shing_W_Intel
Hi Jonathan,
Hope this helps.
Jia-Shing
Jonathan_Yeh
Hi Jia-Shing,
Thank you for your feedback.
Now the gateway and ECI target system can be recognized. I think we can proceed then.
Status Figure
Jia-Shing_W_Intel
Hi Jonathan,
I'm glad things worked out for you. Thank you for correcting the title to ECI!
Jia-Shing
JesusE_Intel
