We are unable to start to test ESDQ for Vision with Version 2022.1, When finished install module, only “Intel_Distribution_of_OpenVINO_toolkit_2022_1_0_Runtime” failed to install.
After looking back the processes information while running installation, below is the error message:
Even tried to reinstall the module with the command “./edgesoftware update <Failed Module ID(s)>” or re-run install command “./edgesoftware install” but still show same fail message as above.
Other notes:
- OS: Ubuntu 20.04LTS
- Kernel: 5.14 or higher
- Python 3.8.10 installed.
Hi All,
The development team is still looking into the issue, and they will address it in the next software release. At this time, I don't have an ETA for the next release. As a workaround, could you please try the following.
W: GPG error: https://repos.influxdata.com/ubuntu focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
E: The repository 'https://repos.influxdata.com/ubuntu focal InRelease' is not signed.
To fix this error, update the key per the following page and run the installation again (./edgesoftware install)
https://www.influxdata.com/blog/linux-package-signing-key-rotation
628cebcf18eee6002c24fb47 | Intel Distribution of OpenVINO toolkit 2022 1 0 Runtime | FAILED
OpenVINO fails to install because of the numpy version installed. Please run the following commands to uninstall openvino and numpy version and re-install manually. Please make sure to uninstall all versions of numpy.
$ python3 -m pip uninstall numpy openvino openvino-dev
WARNING: Skipping numpy as it is not installed.
$ python3 -m pip install numpy==1.19.5 openvino==2022.1.0 openvino-dev[tensorflow2,caffe,onnx]==2022.1.0
Once OpenVINO and numpy is install, do not run the installer again as it will install the latest numpy version again. Instead run the esdq tests. You will continue to see failed Intel Distribution of OpenVINO toolkit 2022 1 0 Runtime but the tests should pass.
Jesus
Hi PH_ROC,
Thank you for reporting the issue, I was able to reproduce from my side and have escalated the issue to the development team for further investigation.
In the meantime, I was able to install the previous version (6.1) of Intel® Edge Software Device Qualification for Vision. Could you please try this version and see if it works for you in the meantime?
Jesus
Hi JesusE,
Thank you for reply, I had test Vision v6.1, but test report shows "mediasdk_sample_encode with h265" failed.
May be need to submit another issue for it.
Hi PH_ROC,
For the MediaSDK issue, have you tried the following steps?
Jesus
Hi JesusE,
I do had try the steps as following link. The steps seems same as the link you provide.
https://www.intel.com/content/www/us/en/support/articles/000089952/software/iot-software.html
After follow the steps of above link, figure below is the "dmesg | grep guc" for the guc detail, and the test result still shows fail.
Hi @JesusE_Intel ,
Is there any update about this,
we have the same issue although trying to fix follow your link, it still has error in h265 encoding.
please refer to the attached report.
Hi PH_ROC and huang__shiuan-chi,
Apologies for the delay in our response, I had escalated this issue to the development team for further assistance.
Let me follow up with them to get the latest update. I Appreciate your patience.
Jesus
Is there any update about this?
Will the ESDQ project keep updating and going?
Hi All,
Jesus
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
