I can access 'localhost:8087/metadata' with just 1 EVAM
but can't access 'localhost:8087/metadata','localhost:8088/metadata' with multi_instance.
Hi Siyoung,
Could you please share additional information and steps taken to setup multiple instances? When you mentioned multi instances, are you referring to multiple EVAM instances or multiple ia_rest_export? If you can also share more information about what you are trying to accomplish, we should be able to provide you with some guidance.
Jesus
I want to use 3 EVAM and 3 ia_rest_export and with just 1 DataStore.
And I want to use metadata from 'localhost:8087/metadata', 'localhost:8088/metadata', 'localhost:8089/metadata'.
but with 'python3 builder.py -v 3', 'localhost:8087/metadata' returns just 'null' and 'localhost:8088/metadata', 'localhost:8089/metadata' return nothing.
Hi Siyoung,
I've reached out to the development team for additional guidance. I will let you know what I find out.
Jesus
Is there a particular use case you are building with python3 builder.py -v 3? For example: python3 builder.py -v 3 -f usecases/video-streaming-evam.yml
I am using
- ConfigMgrAgent
- EtcdUI
- EdgeVideoAnalyticsMicroservice/eii
- Visualizer/multimodal-data-visualization-streaming/eii
- DataStore
- RestDataExport
these containers.
Thanks Siyoung, we are setting up an environment to reproduce the issue. We will revert back as soon as possible.
Hi Siyoung,
I apologize for the delay in our response. I wanted to check if the issue is still persistent and if you could check if the issue is still seen on the latest Intel Edge Insights System release version 1.5.
https://edgesoftware.intel.com/edgeinsightssystem/
Jesus
Hi Siyoung,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Peh
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
