I can access 'localhost:8087/metadata' with just 1 EVAM
but can't access 'localhost:8087/metadata','localhost:8088/metadata' with multi_instance.
Hi Siyoung,
Could you please share additional information and steps taken to setup multiple instances? When you mentioned multi instances, are you referring to multiple EVAM instances or multiple ia_rest_export? If you can also share more information about what you are trying to accomplish, we should be able to provide you with some guidance.
Jesus
I want to use 3 EVAM and 3 ia_rest_export and with just 1 DataStore.
And I want to use metadata from 'localhost:8087/metadata', 'localhost:8088/metadata', 'localhost:8089/metadata'.
but with 'python3 builder.py -v 3', 'localhost:8087/metadata' returns just 'null' and 'localhost:8088/metadata', 'localhost:8089/metadata' return nothing.
Hi Siyoung,
I've reached out to the development team for additional guidance. I will let you know what I find out.
Jesus
Is there a particular use case you are building with python3 builder.py -v 3? For example: python3 builder.py -v 3 -f usecases/video-streaming-evam.yml
I am using
- ConfigMgrAgent
- EtcdUI
- EdgeVideoAnalyticsMicroservice/eii
- Visualizer/multimodal-data-visualization-streaming/eii
- DataStore
- RestDataExport
these containers.
Thanks Siyoung, we are setting up an environment to reproduce the issue. We will revert back as soon as possible.
![](/skins/images/8FB36532649328DCF5C664746EB8C19B/responsive_peak/images/icon_anonymous_message.png)
