Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
413 Discussions
Industrial surface defect detection: Failed to install Model optimisation
Nitish_
Hello everyone,
I  am trying the run the Industrial surface defect reference implementation on my Ubuntu 18.04. Unfortunately, model optimizer is not installing and giving me error. Please check the screenshot.
I adopted the same process as given here:  https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/industrial-surface-defect-detection.html
Will appreciate your suggestion/recommendation/insights.
JesusE_Intel
Hi Nitish_,
The issue seems to be related to OpenCV (see below), are you running Ubuntu 18.04 in a virtual environment? If so, please try to install it on a system running Ubuntu 18.04 natively.
* FATAL ERROR:                          *
* This OpenCV build doesn't support current CPU/HW configuration *
* Use OPENCV_DUMP_CONFIG=1 environment variable for details   *
Required baseline features:
  ID= 2 (SSE) - OK
  ID= 3 (SSE2) - OK
  ID= 4 (SSE3) - OK
  ID= 5 (SSSE3) - OK
  ID= 6 (SSE4.1) - OK
  ID= 8 (POPCNT) - NOT AVAILABLE
  ID= 7 (SSE4.2) - OK
terminate called after throwing an instance of 'cv::Exception'
 what(): OpenCV(4.5.1-openvino) ../opencv/modules/core/src/system.cpp:626: error: (-215:Assertion failed) Missing support for required CPU baseline features. Check OpenCV build configuration and required CPU/HW setup. in function 'initialize'
Ref. Can't solve OpenCV build error due to no POPCNT support on CPU · Issue #18932 · opencv/opencv (github.com)
Jesus
JesusE_Intel
Hi Nitish_,
Thank you for reporting, I was able to reproduce the issue from my side. Looking at my logs, OpenVINO Model Optimizer failed to install after onnx was not able to install. As a workaround, could you try to manually install onnx and run the ./edgesoftware install again?
pip3 install onnx==1.7.0
Jesus
Nitish_
Hi Jesus,
Despite installling onnx , the same problem persists. Could you pls let me know the command to  view logs that may help to resolve this issue? Model optimiser is not going beyond 66%.
Nitish
JesusE_Intel
Hi Nitish,
Could you share your logs with me? Logs can be found in the /var/log/esb-cli/<reference_implenetation> directory.
Jesus
Nitish_
Hi Jesus,
Please find the install.log file.
Nitish
JesusE_Intel
Hi Nitish_,
* FATAL ERROR:                          *
  ID= 2 (SSE) - OK
  ID= 3 (SSE2) - OK
  ID= 4 (SSE3) - OK
  ID= 5 (SSSE3) - OK
  ID= 6 (SSE4.1) - OK
  ID= 7 (SSE4.2) - OK
Jesus
Nitish_
Hi Jesus,
Thank you :). The issue got resolved by following reference details.
Ref: https://www.virtualbox.org/ticket/20005
Nitish
JesusE_Intel
Hi Nitish,
You're welcome! If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jesus
